As far as the blades from the link - they can be used for a V4 (I did that years ago with my own V4). However, they cant be used in original length ... they must be cut down shorter than the original V4 blades, but it works.
For the inner shaft and the blade strikes, I tend to second Tony - an extended inner is the "safest" way to 'no blade strikes'. But with a really hard blade (like the CF reinforced Acro blades) the risk of blade strike even with a stock length inner shaft is a lot lower than with any other blades I have tried (maybe the CF blades I want to test for the V4 when I am back are an alternative ... who knows) |
Latest blog entry: The WLToys V912
First you mention tbe...then you say the heli spins. Is it spinning on its vertical axis or doing big circles in the air? Jim By the way, welcome
Joined Sep 2011
![]() I'm holding the chassis (body off) and can feel it wanting to spin around the drive shafts, I assumed that was toilet bowl but maybe not (not familiar with the terminology yet). The torque that I'm feeling as I hold it and apply throttle tells me that if I let it go, it'd just spin in circles around its center axis (the shafts). I can't seem to figure out how to get the 4-in-1 to dial it out but I'm assuming it's a discrepancy between how fast the two motors are spinning, or how fast the shafts are. I can't see that there's any binding anywhere, the gears move freely off-power (with the expected resistance from the motors) so I don't know what to do. I'm a beginner with helicopters (have spent years with off-road), just learning the ropes. |
Ok cool,
That narrows it down. It's not toilet bowl. You have to adjust the proportional on the 4in1. Turn the prop (with a small flat screwdriver) toward the direction the heli wants to spin in. You have to keep going in small increments till you get it nice and steady. Keep in mind as the battery runs down the heli will want to yaw (spin on its axis) because the motors will draw different current amounts etc. After you get the spinning adjusted...try to fly it. If the tail wobbles back and forth...you will have to adjust the gain. Let us know how you do. Also...are you using the stock body or do you have a pod and boom? If you are removing the stock body and trying to fly it it will spin. The tail portion of the body acts as a weight and the gyro "senses" that lack of weight etc and without it it won't fly correctly. Jim |
Urgent Notice!
I'm sure there is a forum here about this... but I'm going to post it here.
I have no idea if you've seen this... It could affect us all in the long run. The AMA, Tower Hobbies and others have sent this to me... Please read it... Thanks! http://www.theblaze.com/stories/feds...n-and-capitol/ Buzz |
![]() Mike. |
FreeJack, welcome. You may have a slipping rotor. I would check for that before adjusting the brick. Did you at least mark/remember where the dials were before you started trying to dial it out? Hope we can get ya hooked up. Flying them is more fun than working on them. But, honestlly, I enjoy that part too. Happy Flyin. Lee
| Thread Tools | |
| Sold Lama parts. Xtreme tial/blades/etc. | GFBurke | Aircraft - Electric - Helis (FS/W) | 3 | Feb 14, 2007 04:58 PM |
| Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew | kookboy | Aircraft - Electric - Helis (FS/W) | 5 | Jan 07, 2007 01:26 AM |
