Old Oct 13, 2010, 10:28 PM
superek4 is offline
Find More Posts by superek4
Joined Aug 2008
Originally Posted by Barak1001 View Post
Same one I hv
superek4 is offline Find More Posts by superek4
Old Oct 13, 2010, 10:29 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
So what issue are you having? Other than it being a bit sensitive to vibration when it's on the the chopper I've got no complaints about mine.
Even works great as a web cam if you install the drivers for it.
Barak1001 is offline Find More Posts by Barak1001
Old Oct 14, 2010, 12:17 AM
superek4 is offline
Joined Aug 2008
Dun know is it charge yet or recording anot?
Old Oct 14, 2010, 12:21 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
The charge light never goes out on mine. I usually just let it charge a couple of hours and unplug it.
You have to hold down the button closest to the lense in order to get it to start recording. Once it blinks it's recording. If the light is solid it isn't recording. If the light is off it is.
Old Oct 14, 2010, 12:33 AM
superek4 is offline
Joined Aug 2008
There's a camera mode too right? What I worried is instead of video I take pics lol
Old Oct 14, 2010, 01:28 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
Holding down the button till it starts blinking is the key. If you press and release the button it just takes a picture.
Old Oct 14, 2010, 01:39 AM
superek4 is offline
Joined Aug 2008
Ok I will try. Btw do u guys put led for nite flying? I fly nite alot. I was thinking to put a red led. Front or back better? Just soulder a led with ohm right?
Old Oct 14, 2010, 01:43 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
I found that in order to fly at night you pretty much need a minimum of 3 LED. I flew with the v3 version of this light kit:
http://lazertoyz.ncweb.net/RCLights.html
Here's some videos with it on my chopper:
Lama V4 with light kit. (1 min 5 sec)
Lama V4 Night Flight (0 min 45 sec)
I modified the kit and added a blue LED wired into the tail that was run off of the same power as the green LED. They both had the same forward amperage so it worked out fine.
The second video it is pitch black outside. The video is taken from about 35 feet away, so you can see just how bright the lights are.
Old Oct 14, 2010, 02:07 AM
superek4 is offline
Joined Aug 2008
Very nice but did it affect the flight time? Us$29 is quite alot a light system.
Old Oct 14, 2010, 02:17 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
No it didn't effect the flight time. 20mah is what all the lights draw together. An average flight for my brushless chopper was 15 minutes. During 15 minutes the lights would draw 5mah.
There are 900 seconds in 15 minutes. 5mah is .55555555 (to infinity) percent of 900mah. According to my calculator that means that the 15 minute flight would be reduced by 5 seconds by using the lights.
Edit:
That was using the 20mah estimate on the site. If you figure in the max amperage the LED can draw, it works out to 80mah between 4 LED. Now take that 80mah and divide by 4 (1/4 of an hour). That leaves you with 20mah over the 15 minute flight. Now divide 15 by 900 (percentage of total power) and you get 0.022222222222222222222222222222222. Multiply your total flight time by the percentage used and you get 19.9999999999999999999999999998 seconds. So in a worst case scenario the flight time on a 900mah battery will be reduced by about 20 to 30 seconds on a brushless setup!
For a brushed setup figure a nominal 12 minute flight. 80mah works out to 16mah over your 12 minute flight (80/5). 16mah/900mah = 1.7777777777777777777777777777778% power usage over the flight. 720 times that = 12.79 seconds lost flight time.
Old Oct 14, 2010, 02:26 AM
superek4 is offline
Joined Aug 2008
Nice so how much u paid for it?
Old Oct 14, 2010, 02:33 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
$29.95 as listed on the site.
This kit is extremely light weight and well worth the money. The strobe effect on the year of the chopper works extremely well and lights are easy to see up to around 200 to 250 feet (yeah I've had my chopper up that high at night).
Old Oct 14, 2010, 02:54 AM
superek4 is offline
Joined Aug 2008
Lol I dun think I will fly so high. Btw your lama 4 has all the conversion? N you are using which tx?
Old Oct 14, 2010, 02:55 AM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
That's no longer my Lama v4, it's my neighbor down the road's. I used a DX7 and an AR6100 receiver (same thing I use on my current 450).
Edit:
My Lama didn't have a "brushless kit". I used 2900kv Turnigy motors, 6 amp Turnigy Plush ESC, a Turnigy vtail mixer, and a Telebee GR201 gyro with it.
Old Oct 14, 2010, 03:34 AM
superek4 is offline
Joined Aug 2008
That's wat I m upgrading to bl motors from hobbyking, I got two 6amp hobbywing esc n GR302-AD/8471 Turnigy Head Lock & Standard Gyro. Was thinking of turnigy 6 channel or Spektrum 6xe.
Wat u think?
Sold Lama parts. Xtreme tial/blades/etc. GFBurke Aircraft - Electric - Helis (FS/W) 3 Feb 14, 2007 05:58 PM
Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew kookboy Aircraft - Electric - Helis (FS/W) 5 Jan 07, 2007 02:26 AM
