http://www.rc711.com/shop/index.php?cPath=21
I buy from them all the time, they've always shipped relatively quickly (7 to 10 days from Hong Kong to the US), and they one time I had an issue with my order they refunded the money without question. |
http://www.helidirect.com/index.php?cPath=29_223 (i've seen cheaper prices but never had dealings with them). As far as spare parts, the more the merrier PTC fuse harness (EFLH1206)...very important! Heavy duty skids Plenty of stock blades, A&B ( I use hardened blades from rchelicoptershop.com) but, a lot of guys on the boards here like the xtreme. There are differrent types so maybe someone might jump in and point you in the blade direction. Inner shafts (2 maybe-EK1-0315) you can always up-grade later. Extra Li-Po battery. Screw Sets (EK1-0573) Here is the page for Lama parts (Helidirect) http://www.helidirect.com/index.php?cPath=38_235_265 You'll feel like a kid in the candy store I'm sure someone will add to this. Stay away from Xheli Mike PS: Your in the right place...Welcome
Hi all
Got my Xtreme blades today. Not advertising but I got them here in the UK from this eBay shop. http://myworld.ebay.co.uk/aliciajayelectrical I note they are slightly longer and have a nice profile. Fitted them and found they make the heli a bit hard to fly indoors. Had a quick try outside (windy tonight) and they seem good. Only thing I am not sure about is them being white! I kind of like to see my blades in action. So, I know one member suggested colouring them but what other ideas are there? What about marking the tips top and bottom side? You can see my outdoor flight from yesterday here. http://www.youtube.com/watch?v=Cy0qldngc0A This was with stock blades. Cheers Mike |
Ohio
Joined Apr 2008
Pretoria!! Wow! It says we are 8,000 miles apart. Amazing. Have you lived there long? I was born and raised right here in Ohio where I live now. Aside from Canada, I haven't been outside the US. I guess the price-controlled nature of Esky stuff prevents a lot of US LHS from wanting to carry their brand. But it sure seems like there are a lot of us flying Esky models. It must be really nice to be able to get parts from a store that close. I don't like waiting for parts on order, so I bought a lot of spare things that are commonly reported to break when in the "newbie" stage of learning I am in. Up until now I have been lucky that I had a spare for everything I broke on the Lama. But since I got my HBFP, I haven't flown the Lama as much. Once I got to fly outside, the thought of flying indoors just isn't as appealing, and flying the Lama outside reveals its serious lack of forward authority. I have been thinking about ordering some not-clipped-off servo horns for it and trying to get some more ability for flying around outside. This time of year, when a high-pressure cell is in our area, we get little to nop wind, and I have a lot of fir trees around my lot, we are very protected from wind. If I could get the Lama to where it moves along fairly well, I would fly more. I can use a slight breeze to my advantage and fly it by tacking like a sailboat. That drives it forward pretty quick. But when the air is still, it really doesn't move forward very fast, even with full idle-up and full trim forward on the TX. |
Hey mikesndbs....Time to take those training wheels off Love the Who Mike |
Rate mode gyros simply stop uncommanded yaw and the tail ends up wherever the rate gain decides it has stopped unwanted yaw. A HH gyro will do the same, but instantly RETURNS the tail to the heading it was at PRIOR to uncommanded yaw. Regards |
Joined Jun 2008
I received my order kit from helipal.com yesterday, only 5 days from order to I received it.
With the new hardened blades I made a test flying outside. First test was with stock setup but the weights pulled off the flybar, this made the heli faster, but resulted in blade strikes when I turned. The new blades took some nasty dings but didnīt break. Then I installed the complete turbokit, had to sand the blades down a bit, as the alu grips are much tighter than the stock plastic ones, and I had to make the links from the servos to the swashplate 3 full turns longer to level it. Then outside again to test. The heli could not fly very fast even though I tried to pull the weigths off the adjustable flybar. With the weigths closer to the center the heli would fly forward and stop in a swinging motion. Do I need the longer servo horns for the turboshaft to work, or just install the stock flybar without weigths ? In all the videos I can see lamaīs speeding around, but mine is damn slow
I have my weights set at 2 inches from the inside edge of the weight to the tip of the outer shaft.
That seems to be the sweet spot for me. I ordered a set of e-flite servo horns and have my left servo in the 3rd hole and my right servo in the 2nd hole. Seem to work great. As far as forward speed goes if the wind is blowing you'll have to give the helicopter lots of throttle in order to go forward, which will also cause it to rise. So you'll have to balance out forward speed vs gaining altitude by controlling the throttle. After a little bit of practice you should get the hang of it. As far as the pendulum effect, my chopper does the same thing. What you need to do is practice slowly easing the stick back to transition from forward flight. Rather than just letting go of it. |
Joined Jun 2008
What I donīt understand is that why was the heli faster with the stock setup, maybe I should try to move the swashplate a bit forward. I really hope the servo horns are in the mail today, so I can get that speed up. |
I've got this flybar. The disadvantage of this flybar is that it's heavier than stock, so it requires more power to spin up.
I'd suggest buying this flybar when he gets some more made. It's carbon fiber so you don't have to worry about it bending from the slightest bump. It's also lighter than the stock flybar that came on the chopper. The turbo kit in question probably came with a metal swashplate? I'd suggest testing how much movement the new swash has. Take your outer shaft out of the chopper. Put the metal swash on it while holding the shaft in your hand. Now move it around in different directions while spinning the upper part of the swashplate that has the balls on it. I'm not sure about the swash from that kit, but the CNC purple swash I have has less possible movement than my stock swash. So I decided to use the stock swash instead. (Speaking of, if anyone wants a purple CNC kit, I've got an entire kit that I didn't use one single part out of.) |
| Thread Tools | |
| Sold Lama parts. Xtreme tial/blades/etc. | GFBurke | Aircraft - Electric - Helis (FS/W) | 3 | Feb 14, 2007 04:58 PM |
| Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew | kookboy | Aircraft - Electric - Helis (FS/W) | 5 | Jan 07, 2007 01:26 AM |
