Barak1001 Great! Thanks guys. Both of these places a very close by. Mike |
Ohio
Joined Apr 2008
Ohio
Joined Apr 2008
Thanks! Zoandar |
I'm not aware of a Loctite product for plastic as the product line is made to set in anaerobic conditions in the presence of metallic ions (between metal to metal threads in the abscence of O). Regards |
http://www.loctiteproducts.com/produ...ID=17&SubID=40 I also came up with many more hits so, it must be pretty common. Mike. This might be the ticket: http://mro2go.com/Merchant2/merchant..._Code=51242540 Loctite 425 |
Ohio
Joined Apr 2008
Yeah, the old man again
CA = CyanoAcrylate. Also known as "superglue". Common adhesive used in this hobby for many materials. Between steel screws and plastic it works well and is removable but it does chemically alter the surface of the plastic. Better for "one-time" assemblies that you don't intend to disassemble. RTV silicone really is better for anything that needs to be serviced, does not alter the surface of plastic and is easily removed with friction or a razor. Regards |
Portland, OR USA
Joined Feb 2008
http://www.henkelna.com/cps/rde/xchg...UID=0000000I29 From the manufacturers webpage... Quote:
Maybe I should have posted in more detail. The discussion was around anaerobic Loctite threadlockers such as "Blue", "Red" and "Green". The "Loctite" BRAND includes the above, as well as MANY adhesives, epoxies and sealants. Yes, 425 is intended for a plastic to steel application, but as you can see from the link you provided, the primary ingredient is cyanoacrylate. Which was the first option I mentioned as a solution. Yes, there is a "Loctite" product that works, but it is the same thing as a $1.99 vial of superglue from the drugstore. Regards |
Portland, OR USA
Joined Feb 2008
![]() The fact only you mentioned green shows the direction of your mindset. My take is we were discussing Loctite threadlockers, not specifically anaerobic threadlockers, especially since plastic was the was the object of the inquiry and I had already mentioned that you shouldn't use purple or blue on plastic. ![]() Earl |
Thanks for the answer on "CA." Did a search on this thread and came up with a bunch of "CA's" I jumped over to rcuniverse and there is a cool search tool and found out it is glue. I just glued the two pieces of CD plastic to my battery holder the other day using elmers Stix-All. A lot of adhesives I was looking at stated "adheres to most plastics" and some stated to just three types of plastic. Stix-All states "adheres to plastic, glass, metals, wood." Also it is "solvent free-no VOCs." Sounded good to me. The real test of course will be after a crash to see how it holds up. Pretty sure I paid $5.49 (something in that area).
Mike |
Anaerobic threadlockers were the only thing being discussed. And I mentioned red, blue and green. Not just green (which I never even need). I've applied many gallons of both red and blue in various applications over the past 25 years. Whatever your take is, Loctite, as a BRAND, has probably a hundred different glues, adhesives, sealants AND anaerobic threadlockers. So does Permatex and a bunch of other brands. I've already posted that Loctite 425 will work fine, just as any CA glue will. If you want to suggest that posters need to track down 425 somewhere to lock a screw in plastic, when any vial of superglue from any store will do the same thing, I would posit that your assumptions are more tightly constrained than mine. Regards |
Portland, OR USA
Joined Feb 2008
Why is it so hard for you to just say "Thanks, I didn't realize Loctite had a product they called a threadlocker for plastics", instead of going into this diatribe to cover your mistake?
No one said CA wouldn't work, again the question was "Do you know of such a product? I'd like to learn more about Loctite for plastic." |
| Thread Tools | |
| Sold Lama parts. Xtreme tial/blades/etc. | GFBurke | Aircraft - Electric - Helis (FS/W) | 3 | Feb 14, 2007 04:58 PM |
| Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew | kookboy | Aircraft - Electric - Helis (FS/W) | 5 | Jan 07, 2007 01:26 AM |
