Old Aug 14, 2007, 02:36 AM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Best way to test radio distance?
Whats the best way to test the range of your radio and receiver? Is there any way other then trial and crash?
I wanted to try some different ways to run the antenna
BowerR64 is offline Find More Posts by BowerR64
Old Aug 14, 2007, 08:13 AM
mattbroomer2000 is offline
Find More Posts by mattbroomer2000
West Sussex
Joined Aug 2005
Depends what equipment your using.
With my transmitter the model goes out of sight before it even thinks of loosing range so no need to worry.
Try testing range with the transmitter ariel down (this will reduce distance) and the model on the floor (no motor connected for safety) then try your configurations of antenna for furthest range.
mattbroomer2000 is offline Find More Posts by mattbroomer2000
Old Aug 14, 2007, 08:51 AM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Thanks, i remembered there is a radios section and they posted me to some links.
Yeah put the antenna down the walk back away from it till you start to lose signal. They said somthig like 8X that distannce is the distance you can go.
Ill have to try it.
Old Aug 14, 2007, 08:53 AM
TachyonDriver is offline
Find More Posts by TachyonDriver
21st Century Space Cowboy
TachyonDriver's Avatar
Chipping, Lancs, UK
Joined Oct 2006
It helps if you have a colleague holding the heli (motors disconnected!) so that you can communicate when you're moving the sticks or not.
Tach.
TachyonDriver is offline Find More Posts by TachyonDriver
Old Aug 14, 2007, 09:24 AM
hihptsi is offline
Find More Posts by hihptsi
hihptsi's Avatar
Illinois
Joined Apr 2005
Tach.
with my fpv aircraft i regularly fly up to a mile away with a full length berg7p and a futaba 7CAP...(over farmland of course )
i know its not what your asking but just to give you guys a idea how well the berg operates properly installed with a full length.
hihptsi is offline Find More Posts by hihptsi
Discussion Bad a123 cell: Best way to test with 1010C UAVProducts Batteries and Chargers 0 Mar 04, 2007 07:38 PM
The best way to test the current on brushless SuperHornet Pusher Prop Jet Models 2 Jun 12, 2005 07:41 AM
What is the best way to test a plane when alone. TeamTEOR Electric Plane Talk 9 Aug 08, 2004 10:05 AM
What's the best way to glide test a new model? EABiker Parkflyers 6 Jul 14, 2004 04:05 PM
Best way to test battery charge? mism42 Electric Plane Talk 5 Dec 22, 2001 06:24 PM
