Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old Aug 13, 2007, 10:20 PM   #1
Achieving Air Superiority
Gold Member
modfly's Avatar
oh no, not another stick!
Yes..its SLOW STICK time...This one has been around for a while and has had many different configuratios...however the one I have in here now is the best IMO..that is if you like slow flight....I have many fast planes and sometimes I just want a slow relaxing predictable flying plane flight to escape into...this plane is the KING of slow for its size...People add brushless this and that and lipo this and that..I like this setup as I can literally fly any crappy battery I have laying around and it will fly like a champ When I fly this thing people stop there cars and watch with there mouth open! It just seems weird that something this big could fly so slow...in a head wind I can fly it like a kite staying in one spot for a long time..it is a seriously cool plane..thanks GWS!
Edit..Plane has many hours flight time on airframe
  • Name: battery.jpg
Description: currently running a 6cell ni-mh pack @4.5oz from a sky fly..but also can run a 800mah 2cell @ 1.54oz for super slow flight.. currently running a 6cell ni-mh pack @4.5oz from a sky fly..but also can run a 800mah 2cell @ 1.54oz for super slow flight.. 56.2 KB · Views: 464
  • Name: side2.jpg
Description: this plane has about 350 flights and the airframe is still original..Went through about 5 motors so far...my flights average 18minutes so 105 hours flight time on this airframe.. this plane has about 350 flights and the airframe is still original..Went through about 5 motors so far...my flights average 18minutes so 105 hours flight time on this airframe.. 49.5 KB · Views: 305
  • Name: engine.jpg
Description: 370 motor with 4.5-1 ratio with prop saver, GWS 11.47\11.80 SF prop..This is from a Great Planes Red Bull profile plane..The motor casing is connected to aluminum stick and is also grounded to negative source battery..eliminates all motor noise.. 370 motor with 4.5-1 ratio with prop saver, GWS 11.47\11.80 SF prop..This is from a Great Planes Red Bull profile plane..The motor casing is connected to aluminum stick and is also grounded to negative source battery..eliminates all motor noise.. 40.2 KB · Views: 290
  • Name: tail-wheel.jpg
Description: oops...that tail wheel is about rolled out.. oops...that tail wheel is about rolled out.. 46.6 KB · Views: 263
  • Name: radio.jpg
Description: New Futaba micro rx setup with high quality servos..5 amp Blue Arrow ESC..This is the 4th radio setup and the lightest! New Futaba micro rx setup with high quality servos..5 amp Blue Arrow ESC..This is the 4th radio setup and the lightest! 46.1 KB · Views: 274
  • Name: side.jpg
Description: This plane will fly walking speed with the 800mah 2cell lipo..lands like a feather..will fly in a very small space.. This plane will fly walking speed with the 800mah 2cell lipo..lands like a feather..will fly in a very small space.. 49.6 KB · Views: 276
  • Name: radio.jpg
  • Name: radio-bott.jpg
Description: radio gear bottom view.. radio gear bottom view.. 69.0 KB · Views: 195
  • Name: regulator.jpg
Description: My ESC has been modified with an external 7805 5v regulator..uses the frame as a heat sink plus connects source negative voltage to aluminum stick..the motor frame is also electrically connected to the stick..this mod Allows this plane to fly to a speck! My ESC has been modified with an external 7805 5v regulator..uses the frame as a heat sink plus connects source negative voltage to aluminum stick..the motor frame is also electrically connected to the stick..this mod Allows this plane to fly to a speck! 53.1 KB · Views: 192
  • Name: ss-ESC.jpg
Description: 5 amp Blue Arrow ESC..mounted so its heat sink is flush to the SS frame for further cooling.. 5 amp Blue Arrow ESC..mounted so its heat sink is flush to the SS frame for further cooling.. 40.3 KB · Views: 158
  • Name: antenna.jpg
Description: this keeps the antenna wire from touching the stick..every little bit helps for MAX range..also the 2 collars are for final adjustment of tail feathers.. this keeps the antenna wire from touching the stick..every little bit helps for MAX range..also the 2 collars are for final adjustment of tail feathers.. 49.9 KB · Views: 287
modfly is offline Find More Posts by modfly   Reply With Quote
Old Aug 14, 2007, 02:03 AM   #2
my karma ranover my dogma
galaxiex's Avatar
That's pretty neat!
how did it fly w/ the stock motor etc, (assuming you flew it stock at all) lol
If it's nice and slow stock, I may have to get one... I too, have alot of batt packs laying around. (how does that happen? I've only been at this a little while...)
Edit; I looked at the slow V but I don't like V tails... dunno why, just don't... maybe cuz it just seems like a "cheap" 3 ch... 2.5 ch???
galaxiex is offline Find More Posts by galaxiex   Reply With Quote
Old Aug 14, 2007, 02:36 AM   #3
Gold Member
modfly's Avatar
This setup is not to far from stock except the motor gearing and motor its self..this motor is a little higher impedance than stock and the gearing is a bit lower..its tuned for 3.75 amps WOT and will cruise at 2amps..The stock plane with 300 is tuned for about 5amps..Get one galaxiex..you will like it..it will become one of your standard fliers..very slow in stock trim...most people jack them up and over power them and such..best to fly it as intended...slow..I guess alot of people just don't get it or there bored and just want to change it...I say get more planes and leave this one alone! Enjoy as is
edit. I don't particularly see any advantage to a v-tail..I have one..A FB commander 2..and its a little slow to respond when the throttle is off and gliding..
Old Aug 14, 2007, 06:51 AM   #4
Phantom Mechanic
PhantomII's Avatar
I have just ordered the Slow Stick with the 400 motor from Tower. I am planning on using my GWS 720 mah 9.6v 8 cell. Will this be ok? It weighs 4.5 oz, and I have a micro rx with one micro and one nano servo. what do you think?
PhantomII is offline Find More Posts by PhantomII   Reply With Quote
Old Aug 14, 2007, 01:01 PM   #5
Gold Member
modfly's Avatar
Yep...that will work just fine..the stick will have some real power with that setup..the servo mounts require that both servos be matched in size is the only problem I see with your radio gear...
Old Aug 14, 2007, 04:01 PM   #6
Gold Member
modfly's Avatar
SS Battery mount and wing LE position.
Here is some info on switching from ni-mh to lipo..and setting up Leading edge so that many different battery's can be used..With the motor I'm using I can even switch in a 3cell lipo for for some vertical 3d type flight..that is another reason I used this motor\ gear ratio..
  • Name: lipo.jpg
Description: 2 cell 800 mah lipo..mount is simply moved forward for 1.5oz lipo..this will also give the SS stock COG.. 2 cell 800 mah lipo..mount is simply moved forward for 1.5oz lipo..this will also give the SS stock COG.. 58.1 KB · Views: 227
  • Name: frame.jpg
  • Name: nicad.jpg
Description: 6 cell 1000 mah ni-mh pack with JST adapter. 6 cell 1000 mah ni-mh pack with JST adapter. 56.8 KB · Views: 164
  • Name: nicad-mount.jpg
Description: battery mounts shown in 4.5oz ni-mh position..I use a screw to hold wing mount in postion.. battery mounts shown in 4.5oz ni-mh position..I use a screw to hold wing mount in postion.. 43.1 KB · Views: 165
  • Name: LE1.jpg
Description: LE to stick frame edge..150mm or 15cm.. LE to stick frame edge..150mm or 15cm.. 58.5 KB · Views: 179
  • Name: LE2.jpg
Description: 15cm from LE to front edge of motor mount..This is the optimum setting and allows big battery changes by moving battery mount.. 15cm from LE to front edge of motor mount..This is the optimum setting and allows big battery changes by moving battery mount.. 59.4 KB · Views: 162
Old Aug 14, 2007, 04:13 PM   #7
Gold Member
modfly's Avatar
SS Landing gear Mod..
this gives the SS pickup truck like hauling capability with NO prop damage on landing..even with a heavy battery..
  • Name: lg1.jpg
Description: new axle simply collard on..hex head collar fasteners hold everything in place.. new axle simply collard on..hex head collar fasteners hold everything in place.. 48.5 KB · Views: 231
  • Name: lg2.jpg
Description: I got tired of the plane smacking the prop on the pavement on landing when I had a heavy battery installed..axle wire is same diameter as LG wire..works excellent..have not scuffed a prop since.. I got tired of the plane smacking the prop on the pavement on landing when I had a heavy battery installed..axle wire is same diameter as LG wire..works excellent..have not scuffed a prop since.. 48.6 KB · Views: 213
Old Aug 14, 2007, 04:18 PM   #8
Gold Member
modfly's Avatar
SS Wing mod
Ok...this is the most simple and effective thing you can do to improve the strength of the wings..epoxy the 2 halves together rite in the center..thats it..thats all thats needed IMO.
  • Name: wing-mod1.jpg
Description: epoxy the 2 halves together..keeps dihedral rite on and greatly strengthens wing.. epoxy the 2 halves together..keeps dihedral rite on and greatly strengthens wing.. 43.2 KB · Views: 220
  • Name: wing-mod-2.jpg
Description: forget tape! it does not hold good enough..this also increases load capability like for loops.. forget tape! it does not hold good enough..this also increases load capability like for loops.. 50.6 KB · Views: 203
Old Aug 14, 2007, 06:02 PM   #9
Gold Member
modfly's Avatar
Prop selection + GWS motor equivalent
I use the Red Bull engine\gearbox as its the most versatile and has a prop saver..no bent shafts either..2cell, 3cell lipo, 6cell ni-hh is what I run in this plane..7 or 8 cell packs could also be used..The GWS equivalent is a "C" ratio with a GWS-350 motor..
  • Name: motor.jpg
Description: Red Bull engine\gearbox can run on 2\3cell lipos with the correct prop for each pack..The RB prop is a 10.33 and is for 3 cells with this gearing. Red Bull engine\gearbox can run on 2\3cell lipos with the correct prop for each pack..The RB prop is a 10.33 and is for 3 cells with this gearing. 46.9 KB · Views: 168
  • Name: engine.jpg
Description: 11.47-for 2 cell lipo...11.80 for 6cell 7.2v 11.47-for 2 cell lipo...11.80 for 6cell 7.2v 40.2 KB · Views: 147
  • Name: rear.jpg
Description: Edge 540 profile 3D "Red Bull" from great planes..very good flying plane..can fly pretty slow too..but thats for another thread..has a very good brushed power system.. Edge 540 profile 3D "Red Bull" from great planes..very good flying plane..can fly pretty slow too..but thats for another thread..has a very good brushed power system.. 54.3 KB · Views: 204
Old Aug 14, 2007, 06:11 PM   #10
Phantom Mechanic
PhantomII's Avatar
Cool......I will have to pull a micro servo from another plane that is not being flown right now. Thanks for the info.
Old Aug 14, 2007, 09:09 PM   #11
galaxiex's Avatar
Say Modfly, in the pic showing the wing epoxyed together, is that a piece of aluminum tubing on the LE?
Old Aug 14, 2007, 09:17 PM   #12
Gold Member
modfly's Avatar
yes..and it works real good..aluminum joiner and 2 fiber glass rods keep everything in order..this is a well designed plane..I just got in from flying it with the 800mah lipo..
Old Aug 14, 2007, 09:25 PM   #13
Gold Member
modfly's Avatar
Floater mode
In floater mode the plane will fly at walking speed with nose up..however, it is very unstable in the wind this way...so this is only good for little or no wind conditions..
  • Name: lipo.jpg
Description: Floater configuration..Here the plane balances were the manual states or stock COG..the SS will fly very slow and literally float with this balance point but is no good for wind.. Floater configuration..Here the plane balances were the manual states or stock COG..the SS will fly very slow and literally float with this balance point but is no good for wind.. 58.1 KB · Views: 195
Old Aug 14, 2007, 09:37 PM   #14
Gold Member
modfly's Avatar
Flying the SS in wind.
with the heaver battery, if you do a COG check, the plane will tilt forward 45 degrees at the COG..this allows wind flying and acrobatic moves like loops and inverted flight..or what ever you can think off..yes nose heavy..you will have to adjust elevator trim for level flight.I have flown in 20mph gusts over the winter and the plane was stable..when the plane lands and is blown over then you know the wind is blowing. So the hardest part is to keep the plane from being damaged after landing!
  • Name: battery.jpg
Description: with the 4.5 oz battery and mount moved back, plane is ready for wind flying or no wind..It just wont be as slow..this also makes the plane faster and able to do some acrobatic moves like inverted flight and loops.. with the 4.5 oz battery and mount moved back, plane is ready for wind flying or no wind..It just wont be as slow..this also makes the plane faster and able to do some acrobatic moves like inverted flight and loops.. 56.2 KB · Views: 215
Old Aug 17, 2007, 12:03 PM   #15
Phantom Mechanic
PhantomII's Avatar
My Slow Stick arrives today!!! I have found two hs81 servos so I should be fine!!!! The build starts!!
Oh No! It's another (Peter Rake) Waco SRE build! tim hooper Scale Electric Planes 176 Dec 09, 2009 02:55 PM
Build Log Oh no, please ... not another Wight Quadruplane!! edi Scale Electric Planes 86 Mar 04, 2007 02:13 PM
Discussion Oh no! Not another stick and tissue LRF Robster Indoor and Micro Models 47 Sep 21, 2006 11:22 PM
Oh no! It's another bitcar conversion! LemurFemur Indoor and Micro Models 92 Mar 09, 2004 01:20 AM
GP3300 data....no, it's not 40 amp sjslhill Batteries and Chargers 11 Dec 15, 2002 09:33 AM
Congratulations SimpleM!
