Old Nov 18, 2002, 05:26 PM
helimatt is offline
Find More Posts by helimatt
helimatt's Avatar
NJ
Joined Feb 2002
Need help with wing and electronics access . . .
Tyson - great video of the Brewster. I am one of the people that has been inspired by your successes with the FG plans. I am well on my way through building a 31" wingspan FW-190.
I have three questions that I hope yourself or someone else can help me with, as I near completion:
1) How did you attach the wing to the fuse? Is it permanent or removable? How do you access the battery / electronics? Remove the wing, or did you cut a hatch around the canopy?
2) I followed the FG plans to the letter, which on the FW-190 calls for making the top of the wing in two sections. I see from your website you used one section on your FW-190. I have not glued the wing up yet, so I could cut another wing top if need be. Is there an advantage to using one piece, or can I continue to use the two separate halves that I already cut, painted, and taped ( I assume you modified the FG plans here for a reason!).
3) How critical is the spar placement? 25% from leading edge? 30% from leading edge? Can one do better than form the airfoil by eye here, or is that good enough?
Scratchbuilder - I assume you are trying to scale up the plans. I had the same problem you did. I just took the screen shot from Adobe, and pasted it into MS Paint. I then printed it out, took some measurements, and used the MS Paint Image -> Scale / Skew function to blow the plans up as needed. They come out pretty blurry, but I found that if you are careful when transfering them to depron, then work out quite well nevertheless. My fuse went together without a hitch doing it this way.
helimatt is offline Find More Posts by helimatt
Old Nov 18, 2002, 11:34 PM
Tyson is offline
Find More Posts by Tyson
Mie oo Karjala poikii
Tyson's Avatar
Ruokolahti, Finland
Joined Apr 2001
Re: Need help with wing and electronics access . . .
On FW-190 and Spitfire the wing is glued to fuse. On P-51 it is attached with rubberbands.
There is a hole (as in FG plans) under the canopy.
FW-190 wing is built out of two separate halves, check out Spitfire construction pictures for details:
http://www.careliawin.com/tyson/RCSpit.htm
I've been using using That-Looks-About-Right method with a great success.
-=Mike=-
Tyson is offline Find More Posts by Tyson
Discussion Need help with wing gEcky Flying Wings 7 Jan 19, 2006 09:45 AM
Need help with wing lamination dst 3D Flying 0 Dec 11, 2005 07:00 PM
Need help with wing Thickness questions, and other tips morphideous Modeling Science 8 Nov 10, 2005 06:40 PM
Need Help with Rotofly Electronics finadk Micro Helis 1 Aug 01, 2005 10:10 PM
Need Help With Wing Warrior Zipper ArcherAce Foamies (Kits) 15 Sep 19, 2003 01:36 AM
