Old Aug 13, 2007, 10:29 AM
mr. arthur1234 is offline
Find More Posts by mr. arthur1234
mre airtime, thn sober :P
mr. arthur1234's Avatar
holland
Joined Oct 2006
Yippee!
new beginner trainer.....acrobatic too
hello,
i give you the newest aileron trainer
the '',klompen kannon vlieger,''.
it is a high wing bipe, this makes is easy for beginners to learn...
profile not yet designed but here are the first scetch'es.
with a brushless this could be a nice profile too
i hope people will apreciate this new bird
1234,
flying is life
mr. arthur1234 is offline Find More Posts by mr. arthur1234
Old Aug 13, 2007, 10:31 AM
holland
Joined Oct 2006
possible setup?
the set-up?
Old Aug 13, 2007, 11:40 AM
SpleenRippa is offline
Find More Posts by SpleenRippa
Yes, right there.
SpleenRippa's Avatar
Comox, BC, CAN
Joined Jul 2003
I wonder, though- how aerobatic will it really be with all the weight hanging underneath both wings :-\
SpleenRippa is offline Find More Posts by SpleenRippa
Old Aug 13, 2007, 12:31 PM
holland
Joined Oct 2006
i believe if the control surfaces are big enough a beginner should get a rol or two out of it
remember i dont mean 3d plane, its a beginners aircraft (so good for beginner acrobatics)
Old Aug 13, 2007, 07:10 PM
Xptical is offline
Find More Posts by Xptical
Your user title is suggestive,
Xptical's Avatar
United States, GA, Carrollton
Joined Apr 2006
It'll never work.
For one, you need to set the lower wing incidence a few degrees above the upper wing. If the plane stalls, the lower wing will stall first.
Second, the wing is on a pylon. The first mild nose-in, the wings will pop off. They'll probably tear the fuse or the pylon.
The tail needs to provide some down incidence. As the airspeed drops, the tail will provide less downforce. This will lower the AoA for the wings.
Your wings may be too close together.
Just design a conventional bipe. Make the top wing a bit larger than the bottom. Make the top wing 2-degrees incidence and the bottom should be 3-degrees. Mount the battery, ESC, and RX low in the fuse. The lower equipment will keep the CoG down. That'll make it more stable.
Xptical is offline Find More Posts by Xptical
Old Aug 14, 2007, 12:48 AM
holland
Joined Oct 2006
maybe a 3 wing setup ?
one more under the other two?
Old Aug 14, 2007, 12:49 AM
holland
Joined Oct 2006
i just took the wingdragon design and added a nother wing
F/S New Hitec Trainer Cord Lv2Fly Aircraft - Electric - Airplanes (FS/W) 2 Jul 12, 2003 11:33 AM
First flight of a new aileron trainer! Er... I mean... Hellcat! Video coming soon Martin Hunter Parkflyers 46 Jun 25, 2003 07:06 PM
Need new "trainer" switch for 8UAFs Andy W Power Systems 5 Jun 26, 2002 02:17 PM
New Futaba trainer cords / jacks Johnfish Power Systems 4 Mar 07, 2002 03:48 PM
My new jet trainer for EDF 300 kwan Electric Ducted Fan Jet Talk 3 Jun 26, 2001 06:54 AM
