Old Dec 23, 2009, 07:08 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
wow old thread, i should rebuild the delta with a better motor and battery. maybe some of the 1.5g linear servos too
derk is offline Find More Posts by derk
Old Dec 26, 2009, 08:31 PM
flyingwing12 is offline
Find More Posts by flyingwing12
Master of Flying Wings......
Joined Jul 2008
Boeing 747
Dont get too antsy as i got, this stuff adds up to my flying lesson money.
I may ( hate to say it) hold off for a while.
when your 15 you dont have money, its that simple
flyingwing12 is offline Find More Posts by flyingwing12
Old Dec 27, 2009, 02:12 AM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
Would just 2 EDF's work, and the other 2 are dummies? It would save weight, and probably be powerful enough. 4 is overkill.
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 28, 2009, 07:13 AM
thewildweasel is offline
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
Has anone tried out these yet? 32mm df, complete with feigao inrunner and inlet ring, 130g thrust claimed on 3s and only 28.50.
Here's a link to the site http://www.kpaero.com/ProductReport....gory1=electric, and here's their data sheet;
DF 32
Bore diameter 32 mm
Outside diameter 33.5 mm
Length 47.5 mm
Length with intake 71.2 mm
Weight with 7.35 KV Feigao motor 26.5gms.
LiPoly Battery Thrust gms. Volts Amps
2 x 250 mAh .....64 ...........6.46 .....3.7
2 x 350 mAh .....68 ...........6.73 .....4.1
3 x 400 mAh .....130 ..........9.91 .....7.8
2 cells @ 6.53 volts 47740 rpm
3 cells @ 9.22 volts 63820 rpm
For the price it seems to be pretty good. They also sell the df unit on its own for 9.50.
thewildweasel is offline Find More Posts by thewildweasel
Old Jan 07, 2010, 10:53 PM
Hawaii
Joined Oct 2009
I don't have much experience with EDF's, but it seems that their thrust to weight ratio of the edf unit itself is quite low… Or am I just making incorrect assumptions? 4 example an APO5 micro brushless motor weights 5g, and puts out 110g of thrust, but this edf, weighs 30g, and gives 85g max.
Old Jan 07, 2010, 11:20 PM
flashkick is offline
Find More Posts by flashkick
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
edf's are extremelly unefficient. someone will probably chime in as to why.
flashkick is offline Find More Posts by flashkick
Old Jan 07, 2010, 11:28 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Diameter, or lack thereof.
But that means they can spin and move air very quickly for a given power input allowing high flight speeds.
They can also be mounted inside a fuselage for scale effect.
Props will almost always do the job better at model scales, but EDFs offer a certain "cool factor".
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Jan 08, 2010, 12:36 AM
Hawaii
Joined Oct 2009
I see. So you are giving up efficiency for looks. I would go the same way, but I like 3D.
Old Jan 08, 2010, 08:51 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Actually, you are giving up raw thrust for higher efflux speed. It is like starting your car out in high gear - it doesn't produce the torque but eventually goes faster than leaving it in low.
Mike Taylor is offline Find More Posts by Mike Taylor
Old Jan 10, 2010, 08:46 PM
Hawaii
Joined Oct 2009
I gotcha.
Old Jan 11, 2010, 06:37 AM
gbd1 is offline
Find More Posts by gbd1
A10jockey
Joined Dec 2009
A10 Twin 30mm
Hi,
This A10 is from EPP as follows :
Span 500mm
Flying Weight 105 Grams
Uses 2 GWS EDF30 with 5Gram outrunners (rewound)
1* CC 10A ESC
300ma 2S lipo (20C)
2* 4.7g servos
Has nose wheel steeing(from Aileron servo)
Flys great outdoors but needs concentration indoors.
The other an F9F 30mm fan 15" Span
uses 3mm depron 2*4.7g servos , cc esc,
70 grms
waiting for test flight.
GBD1
gbd1 is offline Find More Posts by gbd1
Old Jan 11, 2010, 07:45 PM
Hawaii
Joined Oct 2009
I like F9F, very cool. How did you cut them? YOU FLY FUTABA? Tee Hee! Just kidding, but an AR6400 would look nice in there.
Old Jan 12, 2010, 06:54 AM
gbd1 is offline
A10jockey
Joined Dec 2009
The A10 is hot wire cut in Epp wing has lots of undercamber, I treated myself to a CNC router last year I now use this most of the time for depron normally use a 1mm dia cutter at 25000 rpm. The F9f is actually scaled down from an earlier 55mm fan design.
I race pylon and Futaba has never let me down !!!
GBD1
Old Jan 12, 2010, 07:11 PM
Hawaii
Joined Oct 2009
Cool. I used to be futaba, but I switched in August because it looked like they had better 2.4ghz stuff. IKD. How do you cut w/hot wire? Do you need a machine?
Old Jan 13, 2010, 03:38 AM
gbd1 is offline
A10jockey
Joined Dec 2009
You need to make templates from something like PCB board or glass board(if you are looking to reproduce) or simply draw out the parts on material. Then using a hot wire cutter
either follow the template or your drawn parts.
See [URL="http://www.diytools.co.uk/diy/Main/sp-53-7077-37688-proxxon-27080-hot-wire-cutter-thermocut.asp"
As for wings templates need to be made for the root and tip sections again wire cut using a hand held wire cutting bow,look up foam wing cutting on Youtube there is lots of info.
Cheers
GBD1
micro EDF: how much pitch? steve glass Electric Ducted Fan Jet Talk 6 Oct 17, 2002 01:00 PM
Dime-store glider/GWS Micro EDF conversion... rlinscheid Electric Ducted Fan Jet Talk 9 Jan 19, 2002 08:33 AM
MiG-15 for EDF 50: micro EDF action! Thomas B Parkflyers 2 Dec 27, 2001 08:27 AM
micro edf opualuan Electric Ducted Fan Jet Talk 8 Sep 30, 2001 05:23 PM
homebuilt micro edf berniep1 Electric Ducted Fan Jet Talk 20 Aug 07, 2001 12:18 AM
