Old Aug 12, 2007, 02:30 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Help!
Lipo discharger for storage
Is there a product I could buy that will automaticly discharge my lipos to the correct voltage for storage? I have a apachea 2500 charger with a hyperion lba6 balancer. It now seens that I need to discharge them as im not able to get out and fly weekly. Ive tried to find about this in threads but havent had much luck. thanks for your help Robert
eckace1 is offline Find More Posts by eckace1
Old Aug 12, 2007, 05:27 PM
Probedude is offline
Find More Posts by Probedude
Probedude's Avatar
Ventura, CA
Joined Jul 2006
Look on this website for PLDaniels Lipo discharger.
Edit:
Here it is http://www.rcgroups.com/forums/showthread.php?t=704489
Probedude is offline Find More Posts by Probedude
Old Aug 12, 2007, 05:45 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Thanks probedude went to there website but they were out of stock. Is there anything else out there or could i just use my wattmeter and discharge running one of my planes static ? Robert
Old Aug 12, 2007, 05:46 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
why not run them down with the plane ESC cutoff setting
hall woo is offline Find More Posts by hall woo
Old Aug 12, 2007, 06:03 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
hall woo my cc35 is set to 3.3v per cell would that be to low? Robert
Old Aug 12, 2007, 06:26 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
I'm pretty sure lipos need to be stored at 3.85v per cell. I would run them down with your watt meter hooked up. Easy enough.
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Aug 12, 2007, 11:51 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Mountain Models shows 14 of them in stock at this time. http://www.mountainmodels.com/produc...roducts_id=506
I just got one from Brian. Intial tests show it works just as intended - bringing each cell down to about 3.9V
It discharges each cell through the balance plug (be sure to get the accessory lead to make up an adapter unless you have the balance lead used on the ElectriFly Power Series and CSRC V2 and many Chinese-sourced packs on your batteries).
BEC is offline Find More Posts by BEC
Old Aug 13, 2007, 02:54 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
FWIW, I use my Triton on Nimh discharge setting with an 11.4 cutoff. Hook it up and walk away and never have to worry about over-discharge. If I have several batteries that are charged to the same voltage level, I'll parallel them and discharge them all at once to 11.4V cutoff. The packs usually recover to 11.5-11.6V after discharging. Perfect for storage.
mrforsyth is offline Find More Posts by mrforsyth
Old Aug 13, 2007, 04:21 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Thanks BEC Ill get one from mountain models also might have to pick up another plane also as there planes are great. I have a dandy thinking about a switchback
Old Aug 13, 2007, 06:20 PM
BEC is offline
BEC
BEC
BEC's Avatar
Joined Jan 2001
If you've a Dandy Sport or GT you'll find the Switchback Sport or "3D" very familiar both in the build and in flying - since the SB and Dandy use the same wings.
Old Aug 13, 2007, 06:26 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
BEC I have the sport should i just get the gt wing? I thought the high wing dandy as compared to the low wing switchback made a difference. Thanks for the input Robert
Old Aug 13, 2007, 06:31 PM
BEC is offline
BEC
BEC
BEC's Avatar
Joined Jan 2001
<offtopic> They fly quite similarly but there is some difference. Sport to Sport it is not huge. I've not flown the symmetrical wing on the SB so can't say there. The Sport wing suits my flying desires better than the GT wing for the Dandy. What to get kind of depends on what you want to do differently than you can/do with the DS </offtopic>
Old Aug 13, 2007, 06:59 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Sorry to be off topic But thanks for the info on the topic that I started
New Product PLDaniels Lipo Normaliser - For storage and Shipping Inflexo Batteries and Chargers 196 Jul 17, 2009 09:17 PM
Question Discharger for LiPos (3.85V for storage & long life) Joe Minton Batteries and Chargers 11 Aug 14, 2006 02:11 PM
Discussion LiPo Discharge for storage jihlein Batteries and Chargers 10 Apr 10, 2006 08:11 PM
Discharger for Lipo batteries glide Batteries and Chargers 2 Apr 17, 2005 02:26 AM
I want Lipo's for this weekend. Where can I get them basmntdweller Batteries and Chargers 5 Jan 22, 2003 07:50 PM
