Hi Mike --
I use a Turnigy 2213 20 turn on my Seawind, from Hobbyking. My guess is that it is about the same or very slightly more powerful than the stock 2830 Rimfire recommended for the plane. Works great for me with the stock 8x6 prop. I have other planes with the Towerpro 2408-21 on them and I can confirm it won't be enough. You won't run into any wing-tip grabs on water if you keep the elevator in full-up position while on the water. Dave |
Finlande
Joined Dec 2007
I believe this is a much better motor from HC and for the same price:
http://www.hobbycity.com/hobbycity/s..._23A_Outrunner Or this one to stay lighter: http://www.hobbycity.com/hobbycity/s..._19A_Outrunner I have been flying all summer with both of them and I can tell you they can give you 250 W for the first one and 200 W for the second one with an APC SF 9x6 cut down to 8x6 , best prop to my mind. Thoses two motors never got warm at thoses power levels. I would recommand the first heavier motor which gives you more power and a little additionnal speed and the excess weight isn't a problem at all. I use the cheap winforces batteries 3S-1500 25 C with only 100 g and the 3s-2450-25C because they are lighter , cheaper and give as much power as any other brands : http://stores.shop.ebay.com/CyberPor...Q_scZ1QQ_sopZ1 I love the most this plane with the heavier motor and the heavier batteries ( 189 g) because landing speed is much higher which makes landings more beatifull to my mind. The plane has more authority in the air with more weight and aerobatics abilities are about the same. If you want to float in the air , then the lighter motor and thoses 100 g batteries are perfect. Didn't see the previous post that came while I was typing but glad to see that we agree on the same motor. Still my advise is to get the heavier one Hope this helps PS read my post 1057 for datas about the lighter motor and it would be better to use a 40 A ESC because there is absolutely no cooling in that plane and the ESC gets hot if you keep WOT for too long . I am using the cheap 40 A supersimple from Hobby City that is just working fine. |
Mike, the motor from Heads Up RC will work fantastic. I have the 2830-10 on mine, which was a 1050kv motor that they have since replaced with the one you were looking at. It's very comparable to the recommended Rimfire motor, and provides great power on 3S with a 8x6, and even better with a 9x6. Be cautious with a 9x6, as hard landings can cause the 9x6 to make light cosmetic damage to the top of the wing if it makes contact. The 8x4x3 prop will likely not do very well on that motor for this airplane. I've been using, or experimenting with, a MAS 8x5x3, and while it provides great thrust, the pitch speed is no where high enough for this model. I find myself having to fly at near full throttle most of the time to keep the plane above stall speed. An 8x4x3 is likely to only be worse, although you are carrying smaller batteries than I do, so stall speed will be less, going down from a 5" pitch to a 4" pitch is likely to make it a wash. If you really want to use the 3 bladed prop, you'd need to get a hotter motor that can turn higher rpm's with a prop of that load, but it's also going to need to handle higher amps that turning a 3 bladed prop will naturally draw.
Heads Up RC is great, the prices are good, and it will be in your mailbox in 2 or 3 days. If you decide to go with that, I'd say start with the 8x6, get good with the plane, then step up to the 9x6 for greater power. Here's a post I did several months back where I posted test data with this motor and several different props if you are interested. http://www.rcgroups.com/forums/showp...&postcount=836 |
Mike,
I've been using this Hacker A20 series motor on my Seawind upgrade: http://www.aero-model.com/motordetai...es=A20&style=L It pulls more amps than the standard Rimfire, but it has lots more power. On a fresh 2200 3-cell Lipo pack it pulls almost 18 amps and measures 200 watts spinning a 9x6E APC prop. I know the Hacker is a little pricey, but you may be able to find a HK copy that would be close. Eric is right about the fuselage clearnace though. Using the 9x6E prop has left some minior beauty marks on my Seawind. McD |
Latest blog entry: LEDs on my T-28
I couldn't find Corrosion X at any local store. So I ended up ordering it from the company. Well mine came from the dist. in Michigan. So I got mine, it was a bit more with shipping, yet I got lots left and I am sure that I will use it for other things. I have already used it on the boat switches which seem to always go bad. Also bulbs on the boat and the connections between the car and boat trailers.
Well I use it between the car and all the trailers that I own. Sure is better than WD-40 for that. Actually I would use Corrosion X in my plane even though I had planned to fly from grass for a while. One of these days you will have the urge to see what it will do from water. That will do it. You will be hooked for sure. Conehead Orrin Eldred Honor, Mi. |
Latest blog entry: Pictures of Toledo
Joined Aug 2006
Chadwell |
Joined Nov 2005
GREAT thread.
Read all the info I could before oredering the SW. I picked up the Seawind last thursday and flew it this last monday morning out in front of the house on the lake(Rainy Lake, MN). VERY impressed with the way this bird flies! Taxi'd around the dock to get the feel of it and then opened the throttle a bit more and did some figure 8's out in the lake. Lake had a nice walleye chop on it so figured what the heck...a went for it!!! I put the plane into the wind gave it full up elev, brought the throttle up slowly and the SW tracked like it was on rails! When it started to rise about 10 feet off the water, I let off the elev. a tad and it climbed like a dream. Only needed a couple clicks on the elev. to trim it out. Have flown it a dozen times in the last 3 days and very happy with it..fly's almost like a trainer...great job on this one! Had to add that I've been flying r/c since 88. |
Great Video! Kudos to Riki for keeping up with the plane. Gotta love that Seawind.
McD |
| Thread Tools | |
| Discussion Seawind By great Planes | postusaf | Fuel Plane Talk | 9 | Jun 03, 2012 06:08 PM |
| Rant Electrifly C-50 Brush ESC by GREAT PLANES | guapoman2000 | Power Systems | 24 | Mar 02, 2009 04:32 AM |
| Question Seawind by great planes | postusaf | Waterplanes | 1 | May 14, 2006 11:32 PM |
| Great Planes ElectriFly PT-Electric Trainer Kit 56" | markmm | Electric Plane Talk | 14 | Oct 04, 2005 03:08 PM |
| F/S Electric Cub by Great Planes Wing 59" | Butch777 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 25, 2005 04:58 PM |
