Old Sep 17, 2007, 09:43 PM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Seawind Review has been published. Take a look here:
http://www.rcgroups.com/forums/showthread.php?t=703822
Mike McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Sep 17, 2007, 10:18 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
Originally Posted by JustinG
It was WINDY yesterday (15+ with gusts to 25) but our club had a float fly at the local Veteran's Center and I was itching to maiden my Seawind. I picked it up a few weeks ago but haven't had a chance to fly it until now.
Flying the recommended Rimfire 28-30-950 motor with a CC Thunderbird 18 and ThunderPower 1320. Plopped it in the water, taxied around a little bit, let it weathervane into the wind and slowly accelerated... got up on step, hit the elevator, and it was airborne in no time, flew great!
The motor has tons of power for this plane. Didn't have any trouble taking off from the water, it kept pretty level on its own (I did take care to laterally balance it beforehand). Water rudder wasn't terribly effective but good enough... I found that the key was to get up enough speed and hold up elevator to keep the rudder in the water while taxiing. I didn't have dual rates set up, I was flying with the high settings, and it was a bit twitchy, so on the next flight I added a decent amount of expo, especially on the elevator, and the controls were much more comfortable. Inside of the plane stayed dry, no problems there either.
The wind and choppy water were absolute non-issues! It handled the wind with flying colors, I and everyone there was just amazed that it flew so well in such crummy conditions.
Loved it! Can't wait to get it on the water again! Can't say enough good things about it...
You swine.. Ive just gotta get one after that report and Mikes Review , it will cost me a fortune to get it shipped to Aussie... ...
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Sep 17, 2007, 10:32 PM
kingsflyer's Avatar
Joined Sep 2005
Son, you might as well order 2 or 3. If you've got to pay the shipping, you might as well get more than one. You are going to want a backup and after your flying buds see yours, they will pay most any price to get one of their own.
Mike McD
Old Sep 18, 2007, 12:31 AM
Joined Nov 2002
Yeah right , I'll get half a dozen so I can recover the shipping cost for them all , ...
Old Sep 18, 2007, 09:42 AM
bullwinkle9 is offline
Find More Posts by bullwinkle9
Fort Payne, Al
Joined Aug 2004
silicon sealing for seawind
Hi guys; dumb question, but never had this happen before; I was sealing my seawind wing seat and canopy with silicon cement; used generic "saran wrap" as release and the silicon stuck to the wrap and not so well to the foam; Any suggestions?
George
bullwinkle9 is offline Find More Posts by bullwinkle9
Old Sep 18, 2007, 09:15 PM
kingsflyer's Avatar
Joined Sep 2005
I've chosen not to seal my wing saddle at all. I use Corrosion-X on all my electronic components and don't mind if a few drops of water get inside the plane. Even with multiple touch & goes, I've never had more that a teaspoon of water get in the plane.
Mike McD
Old Sep 18, 2007, 10:11 PM
coolboarder is offline
Find More Posts by coolboarder
Plane on the Brain
coolboarder's Avatar
Joined Apr 2005
0 drops of water inside
http://www.rcgroups.com/forums/showp...&postcount=112
coolboarder is offline Find More Posts by coolboarder
Old Sep 18, 2007, 10:27 PM
no stick is offline
Find More Posts by no stick
Ohio
Joined May 2003
Well, I can verify this thing runs upside down. "Dumb Thumbs" overracted 30' up and did a roll header. Canopy came off, but the motor could be spurt started and I brought it back to shore. Being under water the prop could not get any RPM vs air. I used corrosionX on everything and all was ok.
Ed
no stick is offline Find More Posts by no stick
Old Sep 19, 2007, 01:39 PM
Tomas Dunker is offline
Find More Posts by Tomas Dunker
Tomas Dunker's Avatar
Sweden
Joined Mar 2006
After a hard landing (on grass) I find strange marks on the wing directly under the propeller (see pic.) The distance between propeller tip and ving is 15 mm. Is it possible for the propeller to reach the wing I wonder?
If I try to press the motor pod down, rather hard, the propeller tip still dont reach the wing.
After the hard landing, no crack (fracture) was find anywhere outside or inside the fuselage.
Can anyone explanin how that happend!?
//Tomas Dunker from Sweden trying to wright English...
Tomas Dunker is offline Find More Posts by Tomas Dunker
Old Sep 19, 2007, 02:23 PM
Plane on the Brain
Joined Apr 2005
the prop....
been there done that
Old Sep 19, 2007, 02:25 PM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Sure looks like the prop! Bet the fuselage flexed on the hard landing. A little light weight spackle will fix that in no time.
Pete
peterv is offline Find More Posts by peterv
Old Sep 19, 2007, 02:58 PM
UAVPilot is offline
Find More Posts by UAVPilot
Foam Floats Better
UAVPilot's Avatar
The Big Country of TX.
George
Try wax paper instead.
My guess is that it peeled the layer of paint off the foam. Now that it's gone, the silicon should stick better. Although I thought silicon would eat foam?
Don't know, didn't seal mine and haven't had any water in it yet after dozens of flights off water, so I will leave it alone.
UAVPilot is offline Find More Posts by UAVPilot
Old Sep 19, 2007, 07:43 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Silicone shouldn't bother foam. It's the vinegar (acetic acid) it gives off that you smell. Tough on metals (corrosion) and electronics but not plastics.
Petefoss is offline Find More Posts by Petefoss
Old Sep 19, 2007, 08:56 PM
no stick is offline
Ohio
Joined May 2003
Wing tip
My threaded nut in the wing became stripped and in was hard to remove because the screw would not come even with the bottom of the wing. I solved the problem by epoxying a plastic wall anchor in the wing bottom. See attached picture. Now I can unthread the screw even with the bottom.
Ed
Old Sep 19, 2007, 11:03 PM
Joined Nov 2002
I think I will be reinforcing my pylon and motor mount with carbon tube , Ive already seen one with the whole top with motor , and stab broken off
You can get netural cure silicon ...just cover where you dont want with saran and then after its cured trim the wrap and silicon with a brand new blade
Discussion Seawind By great Planes postusaf Fuel Plane Talk 9 Jun 03, 2012 06:08 PM
Rant Electrifly C-50 Brush ESC by GREAT PLANES guapoman2000 Power Systems 24 Mar 02, 2009 04:32 AM
Question Seawind by great planes postusaf Waterplanes 1 May 14, 2006 11:32 PM
Great Planes ElectriFly PT-Electric Trainer Kit 56" markmm Electric Plane Talk 14 Oct 04, 2005 03:08 PM
F/S Electric Cub by Great Planes Wing 59" Butch777 Aircraft - Electric - Airplanes (FS/W) 2 May 25, 2005 04:58 PM
