Hi Rewstad --
I did the airframe / Hobby City build and I'm very happy with it. I'm using the Turnigy 2213-20 / 1050kv motor with the HobbyKing SS 30A Esc, HXT900 servos, some Zippy 3S/1500mah packs and the HobbyKing T6A 2.4G radio. Works great. While I've only seen one other Seawind EP in the flesh running the stock Rimfire motor, my guess is that mine has about equal performance. I would not call the Turnigy motor a hop-up. That said it's plenty fast and powerful as is, as you've no doubt read in the threads. I would be somewhat wary of overpowering this model as well, since lots of people have had the motor tear off the nacelle. This plane looks just fantastic in the air and gives pretty great performance compared to virtually anything with floats. I know you'll be happy. Good luck with the build. Dave |
Joined Mar 2009
I and another owner on this thread run this motor with a 9x6 http://www.headsuprc.com/servlet/the...lectric/Detail http://www.rcgroups.com/forums/showp...&postcount=836 Here's another turnigy that has a higher amp rating. Both of these will will work fine if you mount behind the firewall with the X mount in front of the firewall and use slightly longer screws. http://www.hobbycity.com/hobbycity/s...s_Motor_1000kv |
USA, FL, Poinciana
Joined Jul 2008
Will my motor be fine if I keep it at 8x6? I was looking for something close to the stock setup. I don't want to hop this thing up too much. I plan of flying it low and sometimes slow. I also don't want it to be too loud and disurb the neighbors. I have a fast delta pusher that goes 120mph and the prop spinning at around 25000rpm. This is what I would consider too loud. What about this one?
http://www.hobbycity.com/hobbycity/s...r_(Eq_AXi_2808) |
USA, FL, Poinciana
Joined Jul 2008
Glad to here the MUS is nice on floats. Where did you get your floats for her? Do you think the GWS floats will work? May have to put it on that instead of my supercub. Would be nice to gave 2 planes for the water so I can use one for retreival just in case. Being that I don't have a boat, I don't really feel like swimming in the water back here. Anyone here highly recommending the PNP route for the seawind?
Rewstad -- I can't speak to floats, but I would go for the RxR Seawind if the price was close. I recall Great Planes was offering a $30 mail-in rebate only on the RxR version this spring although I'm not sure if it's expired. Also some hobby shops have rebates for orders over a certain amount (Tower, for instance, often offers discounts to international buyers). Once you factor in one shipping charge instead of two, suddenly outfitting a bare Seawind with Chinese electronics isn't a great deal anymore.
The Great Planes electronics aren't bad, although I've been told the 25A Silver series ESC has a crappy low voltage cut-off algorithm. Installing the stock Rimfire motor in the Seawind is slightly easier than going with a non-stock powerplant due to its stupid 3-bolt mount, for which the Seawind is set-up. If you don't already have your own radio and Rx, though, then I'd go with HobbyKing or the like for your electronics so you can also order a cheapo 2.4G system. Those are my thoughts, for what they're worth (if you're looking for two cents you'll walk away with change...). Good luck. |
USA, FL, Poinciana
Joined Jul 2008
Tanks for your thoughts. I'm gonna do that. The RxR version is now in my future. It just seems easier all around. They even have easypay which helps me keep the money in my pocket for other things right now. Now I just have to order that corrosion x stuff.
USA, FL, Poinciana
Joined Jul 2008
I ordered the RxR version from tower. They have a $20 off coupon eligeble for this purchase and I also got free shipping. Doing the easypay option at less than $57 for 3 payments. I think I'll try my 2150's and 1800's first, but I may end up ordering some 1500's pretty soon. My 1800's have almost 80 cycles and im afraid the 2150's will be too heavy for my liking.
Joined Mar 2009
My Seawind pre-maiden flight photo
As always, I have a photo taken for my fleet album, prior to the first flight, just in case there is a problem.
Sure enough, after this photo, my test pilot had an uncontollable problem and dunked it. We're not sure what happened but it can be repaired. It was a beauty and will be once again!!!! Don |
I used the rimfire 1250 motor on my Seawind. I used the stock prop on it, I have a total of 4 of them that I balanced. It has vertical climb, looks really sweet in the air, I did some inverted flying, (which for me is a major accomplishment) a couple of rolls, a loop and had 5 great flights.
I will get another Seawind, I messed the wing up bad. The water rudder needs to be bigger, other than that, it is a very nice flying plane. I had an 1800 mah in it, I think I needed to move it back a bit. I will get another Seawind next spring, so that I can fly off the lake more next year. I got other planes I want before I go back to the Seawind. Corrosion X really works. I had water in mine, no problem. Conehead Orrin Eldred Honor, MI. |
Latest blog entry: Pictures of Toledo
A larger water rudder
Conehead,
I agree a larger water rudder is needed. Yesterday while doing pre-flight maneuvering I noticed a definite lack of water response as I increased the throttle, only when I slowed down the response improved. This lack of response at "speed" caused a problem. I wonder if others have noticed this. I have a friend who has this model and he takes off in about 3 feet but he has a more powerful motor and doesn't need a longer run before "rotation" . In my Seawind I have an AXI 2212/20, using a 3s 1500mah lipo with the stock GP 8x6 prop. this set-up produces 163 watts. I plan to use a 2200mah that produces 230 watts next time out. Has anyone else noticed a larger water rudder would help? If so what modification was made? Thanks, Don |
| Thread Tools | |
| Discussion Seawind By great Planes | postusaf | Fuel Plane Talk | 9 | Jun 03, 2012 06:08 PM |
| Rant Electrifly C-50 Brush ESC by GREAT PLANES | guapoman2000 | Power Systems | 24 | Mar 02, 2009 04:32 AM |
| Question Seawind by great planes | postusaf | Waterplanes | 1 | May 14, 2006 11:32 PM |
| Great Planes ElectriFly PT-Electric Trainer Kit 56" | markmm | Electric Plane Talk | 14 | Oct 04, 2005 03:08 PM |
| F/S Electric Cub by Great Planes Wing 59" | Butch777 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 25, 2005 04:58 PM |
