Old Jun 21, 2009, 09:31 PM
fnlrun is online now
Find More Posts by fnlrun
Capitalist
fnlrun's Avatar
United States, CA, Redding
Joined Sep 2008
i don't know if I would silacone mine together....
What if you need to remove it. Now you have a mess
fnlrun is online now Find More Posts by fnlrun
Old Jun 21, 2009, 09:36 PM
Fast Freddy is offline
Find More Posts by Fast Freddy
Madison, WI
Joined Feb 2004
Silicone Seal in Wing Saddle Area
Spread a thin bead of silicone (window / bath silicone in a tube) along the wing saddle area of fuselage. Lay Saran or Glad wrap on top of silicone bead. Put wing on wing saddle area and tighten down screw. Let dry for 24 hours. Unscrew wing and remove clear wrap. You should have a watertight seal between wing and fuselage.
Fast Freddy is offline Find More Posts by Fast Freddy
Old Jun 21, 2009, 11:26 PM
Capitalist
fnlrun's Avatar
Joined Sep 2008
OK I just got schooled.
*runs out to the garage with wifes saran wrap and a couple beers*
Old Jun 21, 2009, 11:59 PM
Madison, WI
Joined Feb 2004
fnlrun,
Glad I could help. I just picked up a couple of used, bicycle inner tubes from my local bike shop. As an alternative approach to silicone bead method, I plan on cutting thin strips of rubber inner tubing and gluing them down on the wing saddle area. I'm building a model of the Short Sealand and want to try a different method. It seems to me that rubber sheeting would be the ultimate in keeping water out of a seaplane. I may be wrong. We'll see. A build log of this plane can be seen here:
www.rcgroups.com/forums/showthread.php?t=1051773
Old Jun 22, 2009, 09:36 AM
Capitalist
fnlrun's Avatar
Joined Sep 2008
what about useing the same weatherstripping that goes around the canopy on the .60?
Old Jun 22, 2009, 10:53 AM
Madison, WI
Joined Feb 2004
Not sure what the .60 Seawind uses, but my guess is the foam wing saddle tape where one side has adhesive. I also compresses after wing bolts are tightened down. I've tried that tape and it's great, except if you accidentally turn the plane upside down in the water. In other words, if the wind saddle area is submerged the foam tape is not waterproof. Granted, that's an extreme situation, but it does happen. It's hard to plan for all contingencies.
Old Jun 22, 2009, 09:20 PM
donjiskra is offline
Find More Posts by donjiskra
WAA-08 Pilot Eventually
donjiskra's Avatar
Darien,IL,USA
Joined Jul 2000
Thanks to EricJ320's PM advice, I can now select Flaperons or Spoilerons while inflight. AWESOME, can't wait to videotape the maiden flight, July 3rd.
Much appreciated Eric!!!!
donjiskra is offline Find More Posts by donjiskra
Old Jun 22, 2009, 09:25 PM
Capitalist
fnlrun's Avatar
Joined Sep 2008
don what size seawind you flying? Make sure and load it to youtube, not enough seawinds on there
Old Jun 23, 2009, 06:38 AM
donjiskra's Avatar
Darien,IL,USA
Joined Jul 2000
It's the GP Electric, 39.5" wingspan, version.
I certainly will post the video on YouTube, as I have with all my videos.
Don
BTW, here's a video of my Nitro PBY 75" converted to electric
PBY Conversion (8 min 37 sec)
Old Jun 23, 2009, 08:12 PM
Capitalist
fnlrun's Avatar
Joined Sep 2008
now that is a damn nice PBY!
Congrats on your flight!!!!!!!!
Old Jun 23, 2009, 08:29 PM
Madison, WI
Joined Feb 2004
Don,
Nice video/plane! What kit/ARF is that PBY?
Old Jun 29, 2009, 09:35 AM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
PBY! AWESOME video! Great commentary throughout! Loved it!
jodini is offline Find More Posts by jodini
Old Jun 29, 2009, 09:43 AM
realtimerecon is online now
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
Nice job ! That's what its all about,having fun ...RTR
realtimerecon is online now Find More Posts by realtimerecon
Old Jun 29, 2009, 01:18 PM
Bookstar75 is offline
Find More Posts by Bookstar75
Bookstar75's Avatar
Joined Feb 2005
Hello,
2 Quick questions.
#1. Will using an 8x6 prop make this plane a little faster versus using a 9x6 prop?
#2. By using an 8x6, even though its less thrust then the 9x6, will it be easier on the motor...meaning less chance of it heating up and burning out?
Bookstar75 is offline Find More Posts by Bookstar75
Old Jun 29, 2009, 08:32 PM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
2 Quick Responses
1. If the 8x6 and the 9x6 are turning at the same rpm, they will have the same airspeed. If your motor can turn the 8x6 at a higher RPM, then it may be faster. Depends on a lot of things like airframe drag and the area of the cross section of the fuselage behind the prop.
2. Depends on the kV of the motor. Use a wattmeter and measure the current draw with each prop.
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Discussion Seawind By great Planes postusaf Fuel Plane Talk 9 Jun 03, 2012 06:08 PM
Rant Electrifly C-50 Brush ESC by GREAT PLANES guapoman2000 Power Systems 24 Mar 02, 2009 04:32 AM
Question Seawind by great planes postusaf Waterplanes 1 May 14, 2006 11:32 PM
Great Planes ElectriFly PT-Electric Trainer Kit 56" markmm Electric Plane Talk 14 Oct 04, 2005 03:08 PM
F/S Electric Cub by Great Planes Wing 59" Butch777 Aircraft - Electric - Airplanes (FS/W) 2 May 25, 2005 04:58 PM
