Old Jun 14, 2009, 10:50 AM
fnlrun is offline
Find More Posts by fnlrun
Capitalist
fnlrun's Avatar
United States, CA, Redding
Joined Sep 2008
right around 60 amps on the white on. And that big 4 blade prop doesn't help
fnlrun is offline Find More Posts by fnlrun
Old Jun 14, 2009, 11:00 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Watts, sir. Watts.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Jun 14, 2009, 11:35 AM
fnlrun is offline
Capitalist
fnlrun's Avatar
Joined Sep 2008
oopse, around 900 watts
i also have my parkzone corsair pulling almost 800
Old Jun 14, 2009, 05:38 PM
primco is offline
Find More Posts by primco
Joined Mar 2009
Originally Posted by Tooly
Attached: pic of a generic motor mount for the seawind, getting around the problem of the unusual hole pattern for the rimfire motors.
Motor is a Hyperion Z2213-16, which is pulling well on the stock 8x6 prop and still able to use the lightweight 1300 packs.
T
That's what I did as well. I think it's the simplest alternative as most motors come with an X mount and it ensures that I keep any thrust angles in the stock setup.
I needed to grind off the ends of the X so that I could fit the cowl and I needed longer screws so they would seat fully. Stock screws on most motors will only go in 1 or 2 threads deep with the ply in the middle.
primco is offline Find More Posts by primco
Old Jun 14, 2009, 10:22 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Originally Posted by fnlrun
...around 900 watts...
Cool! This one runs right at 1kw so it should fly fine.
mw (taking topic to 71" SW thread)
Old Jun 20, 2009, 10:26 AM
Bookstar75 is offline
Find More Posts by Bookstar75
Bookstar75's Avatar
Joined Feb 2005
Hi guys,
How is everyone sealing the gap around where the wing is mounted to the fuselage? I also noticed that when I screwed in the mounting screw, that the back of the wing would not screw down flush all the way, so I had to use some hot glue to keep it down. There was gaps where water could get into the fusealage all the way around that area, and so I used some blue colored electrical tape to seal it, that way it matches the blue on the plane. It looks like blue trimming.
Any other ideas of different ways of sealing the wing to the fusealage area that would be more affective then my method?
Thank you!
Bookstar75 is offline Find More Posts by Bookstar75
Old Jun 20, 2009, 12:08 PM
Fast Freddy is offline
Find More Posts by Fast Freddy
Madison, WI
Joined Feb 2004
FnlRun, Quote "My dad has both the GP and EF Seawind and I can't tell you how many times his canopy has blown off.....I'm so tired of swimming"
See P. 72, post 1069. If you construct these canopy hatch latches, popping canopy will be a non-issue and you'll be doing much less swimming!
Fast Freddy is offline Find More Posts by Fast Freddy
Old Jun 20, 2009, 06:41 PM
donjiskra is offline
Find More Posts by donjiskra
WAA-08 Pilot Eventually
donjiskra's Avatar
Darien,IL,USA
Joined Jul 2000
Heads up notice:
July 3rd, I plan on videotaping my Seawind's maiden flight. It has been midified with a second aileron servo in order to provide Flaperons on the first flight, then it will land and the transmitter will be changed over for Spoilerons for the second flight, since I haven't figured out a way to switch the Airtronic RDS8000 over from one to the other while in flight.
The three position switch works great. I can get Neutral, 50% and 100% deflection.
Will keep you guys posted.
Don
donjiskra is offline Find More Posts by donjiskra
Old Jun 20, 2009, 07:05 PM
EricJ320 is offline
Find More Posts by EricJ320
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
Sure you can Don, set the first position for flaps down, middle position for flaps neutral, and the third position for spoilers up. I used to do it with my RD6000, I'm sure it's the same for the RDS8000. Just use the end points to determine the amount of deflection in each direction. However you won't have two position flaps in that case.
Eric
EricJ320 is offline Find More Posts by EricJ320
Old Jun 20, 2009, 10:11 PM
fnlrun is offline
Capitalist
fnlrun's Avatar
Joined Sep 2008
Fast freddy--- Several more hobby king magnets fixed the problem. I did suggest the slide-lock but apparently that was to easy for my ol' man
Old Jun 21, 2009, 06:35 AM
donjiskra's Avatar
Darien,IL,USA
Joined Jul 2000
Eric,
Thanks, I'll have to try that.
Much appreciated.
Don
Old Jun 21, 2009, 07:21 PM
Bookstar75's Avatar
Joined Feb 2005
Anyone have an answer to how to seal the gap between the fuse and the wing?
Old Jun 21, 2009, 07:31 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
read the threads.............
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Jun 21, 2009, 08:33 PM
fnlrun is offline
Capitalist
fnlrun's Avatar
Joined Sep 2008
some people use clear box tape. I used regular green automotive tape. I'd like to find something in white though...
Old Jun 21, 2009, 09:29 PM
EricJ320 is offline
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
Someone listed a process by which to use silicone glue and plastic wrap to make a seal. It's somewhere back through this thread, in the 50's pages if I remember correctly.
Eric
Discussion Seawind By great Planes postusaf Fuel Plane Talk 9 Jun 03, 2012 06:08 PM
Rant Electrifly C-50 Brush ESC by GREAT PLANES guapoman2000 Power Systems 24 Mar 02, 2009 04:32 AM
Question Seawind by great planes postusaf Waterplanes 1 May 14, 2006 11:32 PM
Great Planes ElectriFly PT-Electric Trainer Kit 56" markmm Electric Plane Talk 14 Oct 04, 2005 03:08 PM
F/S Electric Cub by Great Planes Wing 59" Butch777 Aircraft - Electric - Airplanes (FS/W) 2 May 25, 2005 04:58 PM
