I think you're on the right track. Depending on the amount of spoiler, you may even need to mix in a little up elevator to keep the nose up on landing.
McD |
Latest blog entry: LEDs on my T-28
Eric,
It's a great program. I've been using it for many years as a reference. How exact is it? Well it gives me a pretty good "ball-park" performance guide, that I find to be pretty close to actual performance. I like the fact that you can input changes and evaluate, before going out to the field. It has never disappointed me. You can check out their website at: www.slkelectronics.com/ecalc/index.htm Yes, you are correct, I had to remove the Rimfire "motor mount" and replace it with a plywood piece for the Axi motor. The Rimfire uses three holes and the Axi uses four. Not a big modification. Don |
Spackle,
You should check out the Seawind review here: http://www.rcgroups.com/forums/showthread.php?t=703822 Watch the videos and you will see that it is recommended for intermediate skill level pilots. It may be a bit much for a 1st aileron plane. That being said, IF you have an experienced pilot that can put you on a buddy box till you get used to the plane, then the Seawind may work for you. McD |
You've made it look mighty easy Don. Let us know how how she flies with the mod.
McD |
| Thread Tools | |
| Discussion Seawind By great Planes | postusaf | Fuel Plane Talk | 9 | Jun 03, 2012 06:08 PM |
| Rant Electrifly C-50 Brush ESC by GREAT PLANES | guapoman2000 | Power Systems | 24 | Mar 02, 2009 04:32 AM |
| Question Seawind by great planes | postusaf | Waterplanes | 1 | May 14, 2006 11:32 PM |
| Great Planes ElectriFly PT-Electric Trainer Kit 56" | markmm | Electric Plane Talk | 14 | Oct 04, 2005 03:08 PM |
| F/S Electric Cub by Great Planes Wing 59" | Butch777 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 25, 2005 04:58 PM |
