Old Nov 27, 2007, 10:33 AM
tekajo is offline
Find More Posts by tekajo
Joined Oct 2006
I have a little screamer purple peril motor. 1550 Kv. 22 oz thrust with 8x4 prop at 16 amps. Motor weighs 25 grams. Any thoughts on using this motor in the seawind?
tekajo is offline Find More Posts by tekajo
Old Nov 27, 2007, 02:44 PM
DiveBombDave is offline
Find More Posts by DiveBombDave
Pull out early!
DiveBombDave's Avatar
Lexington, KY
Joined Jan 2005
Sounds like the right power into the right prop, and a good thrust figure. Being lighter than the stock ammo, you may want to consider the smaller side of the range, like a TP1320... but the motor is just an inch or two behind CG, so it won't change your balance that much.
Dave
DiveBombDave is offline Find More Posts by DiveBombDave
Old Dec 08, 2007, 02:30 PM
coolboarder is offline
Find More Posts by coolboarder
Plane on the Brain
coolboarder's Avatar
Joined Apr 2005
I got to say this was as fun as it was on water!
5" of fresh powder led to some 40-yard landings. With kingsflyers recommended cg i can get 13 minutes at acceptable lipo discharges with little aerobatics, however most are 9min aggressive
coolboarder is offline Find More Posts by coolboarder
Old Dec 08, 2007, 05:58 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
Agreed!.. We got 3-4" of fluffy (not stuffy) snow a few days ago.. I had as much fun ON the snow as I did flying that day... I must have shot 20 touch and goes in 5 min.. then crazy snow taxiing at high speed with lots of skips and jumps just for fun... I was grinning ear to ear.. More fun than my stormlauncher, that's for sure! Actually it's MORE fun on snow than on water.. takeoffs are MUCH faster usually only needing 10' or less.. landings produce a nice spray of snow etc. etc.
tic is offline Find More Posts by tic
Old Dec 09, 2007, 11:16 AM
Maineiac63 is offline
Find More Posts by Maineiac63
Maineiac63's Avatar
Blissfield, Michigan
Joined Apr 2005
Hopefully I'll get my seawind soon and together so I can do some flying off snow before the lakes thaw out. I really enjoy snow flying - been doing it for many winters with floats and skiis on all kinds of different planes. Yup, sure is a blast. Jim
Maineiac63 is offline Find More Posts by Maineiac63
Old Dec 12, 2007, 09:27 AM
tdab is offline
Find More Posts by tdab
tracey=Col Frank Fitts
tdab's Avatar
Carolina's
Joined May 2004
Have you guys seen the new GWS 3-bladed HD props? I am going to order some in 9x5 and 8x4. Seems like they will look great and be perfect on the GPSW
Dr Kiwi is doing tests now and they look very promising.
Tom
tdab is offline Find More Posts by tdab
Old Dec 12, 2007, 09:47 AM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Tom, who has them? Don't see them on the BP website.
Pete
peterv is offline Find More Posts by peterv
Old Dec 12, 2007, 10:29 AM
tdab is offline
tdab's Avatar
Carolina's
Joined May 2004
Hey Pete, check here: http://www.rcgroups.com/forums/showthread.php?t=781035 for the details. Looks like caliberhobby and they are good.
It is further down the page.
Tom
Old Dec 12, 2007, 06:03 PM
Plane on the Brain
Joined Apr 2005
8" 3 blade will be good for the seawind. I'm looking forward to it.
Let me know when they create the 8/6
Old Dec 15, 2007, 08:11 AM
sheleb is offline
Find More Posts by sheleb
Sudbury, Ont. Canada
Joined Apr 2005
Hi Guys, I've got a couple questions concerning battery size which I hope I can get advise for before I place my order.
1) For those satisfied using the TP 1320 with suggested motor & prop - are you using the Deans mini 2-pin connectors, or something bigger like the mini 4-pin or Ultra connectors? (The reason I'm asking is that I already have two TP 1320's with 2-pin mini connectors, which I use in planes with lower amp draw than the Seawind will probably need, but would like to try to use them in the Seawind.)
2) For those satisfied using the larger 1700-2200 mah batteries, what kind of battery weights are we talking, 140-180g?
It seems like such a big difference to go from a 85g battery (TP1320) to a 170 or 180g battery & still balance the CG and have similar flight characteristics.
I'm thinking that if my 1320's with 2-pin mini connectors won't cut it, then I'd go with a TP 2000 Pro Lite which weighs 120g, and Deans 4-pin or Ultra connectors. Would this be ok?
Any advise would be greatly appreciated!
Bill
sheleb is offline Find More Posts by sheleb
Old Dec 15, 2007, 08:14 AM
tic is offline
tic
tic
thunderscreech
tic's Avatar
Joined Dec 2000
I'm using a 1500mah battery, balances perfectly.. Deans ultra connector
Old Dec 15, 2007, 08:35 AM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Bill, your batt is OK but would stick with the Deans Ultra connector. The mini is good for about 10 amp draw and the stock setup depending on the prop will draw 14 to 17 amps. The lighter batt will allow you to fly slower. Use the heavier batt for windy conditions.
Pete
Old Dec 15, 2007, 09:39 PM
no stick is offline
Find More Posts by no stick
Ohio
Joined May 2003
Bill, I'm using TP 1320 with Mini Deans connectors and a 25 amp Cool Running ESC configured with Deans Ultra. There are adapters you can make yourself or available here:
http://www.espritmodel.com/index.asp...OD&ProdID=5871
Ed
no stick is offline Find More Posts by no stick
Old Dec 16, 2007, 05:24 PM
tic is offline
tic
tic
thunderscreech
tic's Avatar
Joined Dec 2000
We had 1/4" of freezing rain and sleet last night and this morning.. The ground was crunchy under foot but very slippery on the surface.. No snow base at all, icicle grass blades sticking up... I figured this would be a really fun surface for the seawind and it was.. I was zipping around the yard having a great time, shot a bunch of touch and goes and finally landed for good after ten minutes.. I was shocked and appalled when I noticed bb sized dents all along the leading edge of my wing.. I turned the plane over and was horrified to see the "boat" section of the bottom was all tore up.. That plastic is VERY thin, maybe 1/32". I tore through it and then large slices of foam were torn out underneath as deep as 1/8".. The ice on the grass was too hard for it and I tore it up badly and lost a fair amount of foam from the rear bottom of the fuse as well.. I am on my second coat of lite filler and then will sand again, paint on some thinned epoxy and paint.. A lot of work for 10min. of fun.. Be warned..... Snow is fine, ICE is not
Old Dec 16, 2007, 07:36 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
yup, I can sympathize.
...I've had ice sand it's way all through the bottom of depron and balsa Twinkles. Most annoying. You'll end up with a ranking of snow's to fly off of. Another interesting one is there's a state between powder and slush where it's so clingy the plane wont be able to move.
The ice is groovy after the next snow though. The ice/softened-and-refrozen-snow has leveled the ground off, risen above the grass and sticks etc, if you get even an inch of snow, the result is fantastic... the super form crust holding up the powder... very firm yet super slidy to play on. If it would have been calm today, this is what I would have had to fly on.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Discussion Seawind By great Planes postusaf Fuel Plane Talk 9 Jun 03, 2012 06:08 PM
Rant Electrifly C-50 Brush ESC by GREAT PLANES guapoman2000 Power Systems 24 Mar 02, 2009 04:32 AM
Question Seawind by great planes postusaf Waterplanes 1 May 14, 2006 11:32 PM
Great Planes ElectriFly PT-Electric Trainer Kit 56" markmm Electric Plane Talk 14 Oct 04, 2005 03:08 PM
F/S Electric Cub by Great Planes Wing 59" Butch777 Aircraft - Electric - Airplanes (FS/W) 2 May 25, 2005 04:58 PM
