![]() I fully agree that there are different pleasures in different sorts of models. |
Latest blog entry: Polaris Aileron Pushrods
![]() One thing I don't like about flat bottom hulls like the Polaris is the lack of the fun that can be had from a seaplane model skimming along up on the step, all forces in balance, the V of the hull leaving a small wake. I much prefer a model with a well designed v shaped hull and equally well designed step that rewards the modeler with nice handling on the water. The purely flat hulls are just not as satisfying on the water......They skip like a flat rock. |
I'm a relative newb. and have no building experience.
The front piece of my motor mount needs to be replaced. Can I buy this piece, or the whole box, or will I have to make something myself ? I searched GP and hobby shops online. I couldn't find anything listed for the Seawind but maybe it's a "generic" box that I could buy somewhere ?
Bummer - I poked around and didn't find anything either. Although it might be a bit of a challenge, you could probably use pictures and what's left of your box to make a new motor box with some basic cutting tools, a bit of light ply, and epoxy.
Best of luck, Josh |
Latest blog entry: Proud Poppa of a new Cal Grad! :)
Joined Sep 2006
Seawind Motor mount
Another way is to cut away the motor mount entirely and use a back mounted motor. That way you start from scratch, make sure everything is glued (use toothpicks into the foam) and lightweight balsa block as a spacer. It also gives the option of a wider selection of motors. Too many mounts have failed, mine included, to fly the Seawind EP without more glue or a complete mod.
That sounds like a good idea. I've never built any models so a suggestion/link for a mount that I could buy would be really appreciated. I see that there are threaded holes at the back of my motor (Rimfire 40) and I think I could handle switching the mount if I knew what I should start with, even if I had to modify it a bit.
I replaced the front part of the motor mount on a Seawind. Don't worry about the fancy half-moon cut-outs... just drill some holes there so some air can get through. Making the front part of the motor mount will be very easy if you have a piece of the right thickness plywood. When you have the mount exposed, be sure to check the other glue joints/and or apply a little extra epoxy to be sure it stays together. I'm over in Whitehall, NY and go to Rutland shopping fairly often. Let me know if you run into trouble. Good flying, desmobob |
I finally maidened my Seawind, it went OK. Two more flights completed as well. It was pretty windy up higher during my maiden, which I didn't expect because the water was so smooth. Tall trees were blocking wind down low. The plane seems really squirrelly to me, but I think most of that was because of the wind. It was super fun to fly though. I can't wait for some more good weather and more flights. I wan't to learn to make smooth no-skip landings consistently. Take-offs were no problem though, I did use a lot of up elevator as suggested by so many here.
| Thread Tools | |
| Discussion Seawind By great Planes | postusaf | Fuel Plane Talk | 9 | Jun 03, 2012 06:08 PM |
| Rant Electrifly C-50 Brush ESC by GREAT PLANES | guapoman2000 | Power Systems | 24 | Mar 02, 2009 04:32 AM |
| Question Seawind by great planes | postusaf | Waterplanes | 1 | May 14, 2006 11:32 PM |
| Great Planes ElectriFly PT-Electric Trainer Kit 56" | markmm | Electric Plane Talk | 14 | Oct 04, 2005 03:08 PM |
| F/S Electric Cub by Great Planes Wing 59" | Butch777 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 25, 2005 04:58 PM |
