Old May 31, 2011, 05:43 PM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
So other than the $50 rimfire motor is there a good "less expensive" motor that would be good with this model? Maybe something from HobbyKing?
JGuilty13 is offline Find More Posts by JGuilty13
Old May 31, 2011, 06:30 PM
sozi81_ita is offline
Find More Posts by sozi81_ita
Joined Dec 2010
hello to all
just an info:
how many of you flies with a 2100 mAh lipo? my seawind now is a little bit nose heavy. Is it normal? could i fly? anyone has tried a bigger lipo?
do you advice to advance CG ?
thanks
sozi81_ita is offline Find More Posts by sozi81_ita
Old Jun 01, 2011, 12:12 AM
fairplane is offline
Find More Posts by fairplane
fairplane's Avatar
Canada, SK, Prince Albert
Joined Aug 2006
Read back 2 or 3 pages- you'll find your answer
fairplane is offline Find More Posts by fairplane
Old Jun 01, 2011, 07:42 AM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Originally Posted by sozi81_ita View Post
hello to all
just an info:
thanks
I use 2200 3-cell packs all the time. They fly just fine. I balance my Wind on the Carbon Fiber spar.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Jun 01, 2011, 09:01 AM
dghutt is offline
Find More Posts by dghutt
Halifax Electric Flyers Assoc
dghutt's Avatar
Halifax, Canada
...is there a good "less expensive" motor that would be good with this model? Maybe something from HobbyKing?
I use a Turnigy 2213-20 1050kv from Hobbyking that seems to work very well with the stock prop. If you want more horsepower and to spend even less you could go for the RCTimer 2830-8 1300kv. In either case you'll have to modify the firewall.
Dave
dghutt is offline Find More Posts by dghutt
Old Jun 01, 2011, 11:23 AM
ibips is offline
Find More Posts by ibips
Chicago, IL
Joined Feb 2010
kingsflyer,
Did you have to add any weight to the tail to use 2200s?
With a KDA22-15M motor (~67g), it balance a little nose heavy with a Blue Lipo 1300 mAh 20c (~140g) all the way to the front of the nose. I'm guessing your motor is heavier?
ibips is offline Find More Posts by ibips
Old Jun 01, 2011, 05:34 PM
Joined Dec 2010
i bought a seawind used (1 meter wingspan).. sorry for my question:
isn't a 8x3 propeller too insignificant?
wattmeter on my axi 1100 kv mounted on seawind shows:
60 watt , 5 amp!
please, which propeller do i need?
axi 1100 kv is good for you?
Old Jun 02, 2011, 01:43 AM
bob93447 is offline
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
I'm using the Super Tigre .10 (1200 kv) from Tower at $20. It powers the Seawind nicely at my altitude of 6200' using various 2 and 3 blade props; typically 8x6 and 9x5. I typically get >150 watts and I'm about to test a Master airscrew 9x7x3 that pulls a bit over 200 watts.
The only problem with the ST .10 is that one needs to remove the plywood motor mount and build up something a bit different.
bob93447 is offline Find More Posts by bob93447
Old Jun 02, 2011, 06:38 AM
kingsflyer's Avatar
Joined Sep 2005
Originally Posted by ibips View Post
kingsflyer,
I probably have a slightly heavier motor, I'm running an 9x6E APC prop, and I put the 2200 3-cell battery all the way back against the plywood servo mounting tray. No added weight to the tail.
If you use anything but the stock Rimfire motor, you will have to modify the motor mount.
McD
Old Jun 04, 2011, 04:53 AM
scoobysport is offline
Find More Posts by scoobysport
Joined Jun 2011
I have had this plane as well, unfortunately it crashed about 1,5 year ago when trying to fly/land from ice. I had a large rimfire motor in it for more oomph, lovely plane, flies well, can handle spirals/loops very well too
Now i'm doubting whether i should get this one, or convert the glow plane version to electric, or get the ICON-A5 large scale...
What would you guys suggest? I plan on using it for FPV a lot then.
scoobysport is offline Find More Posts by scoobysport
Old Jun 04, 2011, 07:17 PM
Joined Dec 2010
hello to all
just tried as suggeste a 9x5 apc propeller with a 1050kv motor .
2200 mAh lipo 3s. Just put lipo near ESC far away only 5 mm rudder / elevator servos. Wow it's perfect. Maybe A little bit heavier on nose ..
However : i would like to insert my gopro HD camera .. into seawind.
Has anyone experienced this mount?
I DON'T WANT to do FPV..
just record videos with GOPRO (100 gr)
i think to put gopro at the place of these 2 man inside cabin
and to put the lipo near the screw of wings ..
what do you think about?
Old Jun 05, 2011, 07:08 AM
Orion Pax is offline
Find More Posts by Orion Pax
Wisdom can not be granted.
Orion Pax's Avatar
Shreveport Louisiana
Joined Dec 2006
It has been a long time since I have flown this plane. She is all stock with a military paint job (The old one was getting really dingy). Its not done but its functional again. Its been crashed so it has gotten heavier. It sits lower in the water and it take full throttle to get her off but other then that she flies like normal. I get about 7 min on her with about 3 minutes to spare. She is very conservative on lipo usage. I still love this plane and hope to start flying more again.
Jasons SeaWind (7 min 21 sec)
Orion
Orion Pax is offline Find More Posts by Orion Pax
Old Jun 05, 2011, 10:11 PM
zeus3313 is offline
Find More Posts by zeus3313
United States, FL, Port St Lucie
Joined Jan 2010
My Sewind RXR will be here tuesday ...Now I need to get batteries. I have a couple of 3s 2200 laying around...I am looking to get a couple new batts (HK) what is the best size? 1600 as recomended or the 2200's any help would be great
zeus3313 is offline Find More Posts by zeus3313
Old Jun 06, 2011, 07:05 AM
va3mw is offline
Find More Posts by va3mw
va3mw's Avatar
Joined Sep 2008
If you start with 1000maH, you will get about 12 minutes of flying time on a new battery and non-water logged bird.
If you go bigger, the batteries are much heavier you will need calmer water to take off or she will start to porpoise and then might do a noise dive.
va3mw is offline Find More Posts by va3mw
Old Jun 06, 2011, 02:53 PM
Orion Pax's Avatar
Joined Dec 2006
1000 mAh will not give you 12min flytime.
My 2200 keeps me in the air for 7 min at half throttle and leaves me with 11.75 volts. That equated to about 3 extra minutes for go around or playing around in the water if I choose. As long as your lipo doesn't go below 11.4v you will not damage the lipo.
Before I crashed my Seawind the 2200 was just a tad on the heavy side but worked. I would recommend a 1800mAh if your plane is virgin and stock. However, if you have 2200's laying around you should be fine with those.
Discussion Seawind By great Planes postusaf Fuel Plane Talk 9 Jun 03, 2012 06:08 PM
Rant Electrifly C-50 Brush ESC by GREAT PLANES guapoman2000 Power Systems 24 Mar 02, 2009 04:32 AM
Question Seawind by great planes postusaf Waterplanes 1 May 14, 2006 11:32 PM
Great Planes ElectriFly PT-Electric Trainer Kit 56" markmm Electric Plane Talk 14 Oct 04, 2005 03:08 PM
F/S Electric Cub by Great Planes Wing 59" Butch777 Aircraft - Electric - Airplanes (FS/W) 2 May 25, 2005 04:58 PM
