Well Thanks for starting this Thread Thomas B. There is a "plane load" of information in this thread. I read most of it before I got a chance to fly someone else's Seawind and after I did, I knew I could fly one myself. I got one, had some great flights and then smashed the wing. I ordered a new wing and another whole one, just in case. Well I now love the Seawind for a float plane.
Now I have to assemble my new Seawind. Had an incident the other night. Bad judgement. Again Thanks for the Thread, it has been very helpful. Conehead Orrin Eldred |
Latest blog entry: Pictures of Toledo
Shingle Springs, CA
Joined Jul 2007
.I have my tips trimmed and it works great. I even touhed down with a wingtip at the same time the fuse touched and it had no inclination to water loop. I does seem that you have to totally grease the landing to keep it from skipping. I only get a couple of those in probably every 10 landings. I think this plane will make me much better at landings though. |
Joined Jan 2009
Hey gang, I received my Seawind EP ARF yesterday and considering what to do about the motor. I actually have the recommended Rimfire motor (28-30-950) on hand, but in my humble opinion, this motor feels too small for a plane with an AUW of 24-26 oz.
Forgive me for not reading the whole thread. What's the consensus on using the stock motor? Left to my own hunches, I'd use something like the headsuprc 3530-11 -- something around 250 watts (continuous.) On the other hand, prop size is probably limited to 8 or 9 inches, so maybe a slightly higher Kv is called for (assuming 3S Lipo for power.) |
Eric |
I put the next size up Rimfire motor in my Seawind. More power than I really need. It will hang on the prop and go straight up if I can hold it there. I use the recomended prop, 8x6, I think that is what it is.
My Seawind under full power is way too fast for me. I fly most of the time about 1/4 to 3/4 throttle almost all the time. For just cruising about, 1/3 most of the time. Conehead Orrin Eldred |
I have the stock / recommended motor in mine, and IMHO it's perfect for the plane. I have a friend that tried putting a hotter motor in his, and the handling of the plane suffered greatly for it. Mine flies like it was designed around this motor, which I believe it was...
My two cents |
| Thread Tools | |
| Discussion Seawind By great Planes | postusaf | Fuel Plane Talk | 9 | Jun 03, 2012 06:08 PM |
| Rant Electrifly C-50 Brush ESC by GREAT PLANES | guapoman2000 | Power Systems | 24 | Mar 02, 2009 04:32 AM |
| Question Seawind by great planes | postusaf | Waterplanes | 1 | May 14, 2006 11:32 PM |
| Great Planes ElectriFly PT-Electric Trainer Kit 56" | markmm | Electric Plane Talk | 14 | Oct 04, 2005 03:08 PM |
| F/S Electric Cub by Great Planes Wing 59" | Butch777 | Aircraft - Electric - Airplanes (FS/W) | 2 | May 25, 2005 04:58 PM |
