Old Aug 11, 2007, 09:00 PM
Bobnormal is offline
Find More Posts by Bobnormal
Aim to Misbehave
Bobnormal's Avatar
United States, CA, Upland
Joined Mar 2006
How to Tile with Photoshop
I'm not sure how to do this in photoshop I'm running ver.7 any help?
Bob
Bobnormal is offline Find More Posts by Bobnormal
Old Aug 11, 2007, 10:30 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
Cmon anything>?
Old Aug 11, 2007, 11:10 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Are you trying to print tiled plans? Or something do else?
There isn't really a good way to tile print, but you can get the job done by using the Position options in the Print menu.
First check that Scale is set to 100% rather than "Scale to fit media".
Uncheck the "Center image" box.
Now change the Position values to get the preview image into one corner, print it, then offset your way around leaving an inch or two of overlap. You may want to add a few temporary horizontal and vertical reference lines to the image file to make it easier to assemble.
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Aug 12, 2007, 12:35 AM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
thanks
Bob
Old Aug 12, 2007, 04:18 AM
Xptical is offline
Find More Posts by Xptical
Your user title is suggestive,
Xptical's Avatar
Warner Robins, GA
Joined Apr 2006
This site has a ton of video tutorials for photoshop:
http://revision3.com/pixelperfect
Xptical is offline Find More Posts by Xptical
Old Aug 12, 2007, 11:32 AM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Bob I do not use Photoshop. I use another image editor. This is a down and dirty way that may help. I will sometimes grid off an image into 7.5" X 10" inch pattern of lines. Then I can print out the separate areas with the lines showing on each sheet. Then trim the sheet to the lines and join them up. It is not pretty, but would work great for scaling aircraft plans.
Probably someone with some experience with Photoshop will have a better idea.
Ray
............Edit.........
Oops, just read Matt's post and he already covered my suggestions.
High Flyin' is offline Find More Posts by High Flyin'
Old Aug 12, 2007, 12:04 PM
callmeishmael is offline
Find More Posts by callmeishmael
AMA 42867
callmeishmael's Avatar
Joined Nov 2003
FWIW, I have worked in Photoshop - for money - since ver 3.0. PS has never implemented a Tile Print option for large images. You can, of course, get tile printing in Adobe Acrobat for "only" $299. The only methods I came up with for tiling images were labor intensive, required a different layer for each tile, and required some serious eyeballing.
callmeishmael is offline Find More Posts by callmeishmael
Old Aug 12, 2007, 03:09 PM
trashbug is offline
Find More Posts by trashbug
trashbug's Avatar
United States, OH, New Franklin
Joined May 2004
It's not free but it's inexpensive...........and it will last forever!
Good Luck,
TB
trashbug is offline Find More Posts by trashbug
Old Aug 12, 2007, 08:43 PM
brucej is offline
Find More Posts by brucej
Good glue is evil
melbourne australia
Joined Sep 2003
Lot of variables in your question but here is a real cheap and dirty method
save your picture as a bmp. (if its a acrobat file cut and paste the plan)
open it in windows paint
Paint will do an auto "tile" when it prints if the picture is bigger than one page
brucej is offline Find More Posts by brucej
Old Aug 12, 2007, 08:56 PM
ZZ Prop is offline
Find More Posts by ZZ Prop
ZZ Prop's Avatar
United States, MS, Olive Branch
Joined Sep 2006
Adobe Illustrator will tile print. It is also a great program for making graphics, drawing plans, templates for lettering etc. Has a lot of drawing aids, grids and stuff. You can also scale plans by importing them and resizing. It's not cheap and is a bear to learn to use but it will do a lot of stuff.
ZZ Prop is offline Find More Posts by ZZ Prop
Old Aug 12, 2007, 10:40 PM
Skinner46 is offline
Find More Posts by Skinner46
Florissant, MO
Joined Mar 2003
Bob
What make of printer do you have? Some printer models, Epson, Canon will have a poster printing mode. If yours does the tiling is realitivly simple. Make sure print size is set to 1:1 (add register marks if you like, but, not necessary) tell printer to poster print and you have it.
BobK
Skinner46 is offline Find More Posts by Skinner46
Old Aug 12, 2007, 11:24 PM
Cheekers is offline
Find More Posts by Cheekers
Joined Dec 2006
I don't use Photoshop, but if you use Microsoft Office Professional, you have MS Publisher which can tile pages. Create a new blank document and set the page size to a custom size that is at least as tall and wide as you will need (in inches). Then when printing, specify how much overlap you want.
Cheekers is offline Find More Posts by Cheekers
How to deal with Peace Activists 101 boomerace Life, The Universe, and Politics 10 Apr 07, 2003 06:37 PM
How long with my HE's last in my Hacker? hoverkid87 Batteries and Chargers 0 Mar 07, 2003 09:32 PM
How Show With Filter? royp Site Chat 2 Sep 22, 2002 07:02 PM
How to build with CA? Ninjak2k Beginner Training Area (Aircraft-Electric) 4 Apr 11, 2002 10:28 PM
How long with a 7.2V geared 400 last on 10cells Ryan Nau Power Systems 4 Jul 21, 2001 07:39 AM
