Old Jun 02, 2001, 10:58 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Night Flying
Has anyone converted an ECO 8 for night flying?
RC Man is offline Find More Posts by RC Man
Old Jun 03, 2001, 04:14 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
You can put night opps on the fuse, and blades can be purchased with lights now.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jun 03, 2001, 08:29 PM
RC Man is offline
United States
Joined Feb 2001
Fred,
I have not seen night blades that will fit the ECO 8. Please tell me where I can purchase them.
Old Jun 03, 2001, 10:52 PM
MicroRotors is offline
Find More Posts by MicroRotors
3D Toy Designer
MicroRotors's Avatar
USA, CA, Hesperia
Joined May 2001
You dont need to buy any over priced blades. You can make then very easy for around $8.00
Parts list:
2 Watch batteries
5' fine coil wire, 100" spool is about 3.99
2 LED's
2 Micro switches
Blade wrap
All of this stuff can be bought at radio shack or a electronics surpluse store.
Directions:
1}. Remove the covering off your existing blades.
2}. CA one wire on the trailing edge of your blades, and the another on the leading edge.
3}. Drill or carve out a hole the same diamiter as your LED into the tip of tour blades at the C/G.
4}. Solder the leading edge wires to the + side of the LED and the trailing edge wire to the - side.
5}. Glue the LED with hot melt, silicone or Goop so it can be removed and replaced if needed.
6}. Glue your watch battery to each blade as close to the grip as possible with hot melt, silicone or Goop.
7}. Solder the wire to the battry at the + side in the center, and a small piece to the side of the battery. This is the - side .
8}. Wrap your blades with the blade wrap.
9}. Solder the wires to the micro switch and use a small band of blade wrape around the switch leaving just the rocker part exposed.
10}. Balance the blades as usual, and attach the blades back the the grips.
Thats it, 30 min. max time spent. Now go spend the $$$$ you saved on something better.
Hope this helps
MicroRotors is offline Find More Posts by MicroRotors
Latest blog entry: My New Toy!
Old Jun 04, 2001, 02:09 AM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Very cost effeicient!
Old Jun 04, 2001, 01:05 PM
Dangerous Dick is offline
Find More Posts by Dangerous Dick
Dangerous Dick's Avatar
Cheshire, England
Joined Mar 2001
I just picked up the 'official' light kit for my Picollo nat the weekend, and have now fitted it. Just got to wait for it to go dark now and I can really pkay!
It is surporising how easy it actually is to get the blades to light up at night on any heli using the above method - go fot it, just try them in the daylight first to make sure you won't get any surprises!!
I did try to use a seperate battery on my Nexus last year by using the swashplate to carry '+' and the main shaft to carry the '-' but it was VERY fiddly and not very succesful, putting the batteries in the blades is a WHOLE LOT easier!
Richard.
Dangerous Dick is offline Find More Posts by Dangerous Dick
Old Jun 24, 2001, 01:30 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
In the winter and spring I fly my ECO more at night than daytime. No lighted blades or light rope though, just flying it bare under the lights in my back yard.
I think I'll try MicroRotors idea and convert a set of woodies for night use.
Which LED's and watch batteries have you had succuss with ?
No need to re-invent the wheel/night blade, right ??
Kevin Murray is offline Find More Posts by Kevin Murray
Old Jul 01, 2001, 10:54 AM
USA, NC, Greenville
Joined Dec 1999
MicroRotors - What number battery and LED did you use ?
Old Jul 01, 2001, 11:19 PM
WilliamSettle is offline
Find More Posts by WilliamSettle
Triad of Fun
WilliamSettle's Avatar
Little Rock, AR Triad: Windy, ECO 8 and E3D
Joined Nov 2000
You all have probably seen this before but check out http://www.inetport.com/~davisele/night.html for the coolest night flying blades I've ever seen.
This guy uses 8 LED's and a computer in the blades for a moving display. He can display the RPM of the rotor in block text!
WilliamSettle is offline Find More Posts by WilliamSettle
Old Jul 01, 2001, 11:39 PM
USA, NC, Greenville
Joined Dec 1999
Very cool.
Night flying- What a Hoot! J.Critchfield Parkflyers 7 Oct 02, 2001 12:45 AM
NEAT Fair night flying??? Dave Wenzlick / Slickraft Electric Plane Talk 7 Sep 18, 2001 04:05 AM
Night flying slowflyer J.Critchfield Parkflyers 9 Jul 02, 2001 11:28 PM
Development of Night Flying Electroluminescent Kit Being Seen Tech Electric Plane Talk 28 Jun 21, 2001 10:51 AM
Zagi Night Flying injunnut Foamies (Kits) 0 Apr 28, 2001 11:21 PM
