Old Jun 27, 2001, 09:44 PM
Brett is offline
Find More Posts by Brett
Westchester,IL 60154
Joined Jun 2001
9Z and JR Voyager E Setup Help Wanted Please
Can anyone give me the set up that they used for a 9Z WC or WCII and the voyager E. Thanks much, this is my first at CCPM and I just don't think that I touched on it all. The book is unclear.
Thanks Again
Brett is offline Find More Posts by Brett
Old Jun 27, 2001, 10:29 PM
Steph280 is online now
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
You are right the book is no help. It basically tell you what each function is, doesnt really say how they are applied. But with some tinkering I was able to figure it out.
I am using a Hitec super slim receiver, with JR 321 servos. Here are my setups.
in MDL/SWH menu:
SWH TYPE = SR3
AIL RATE= -50%
ELE RATE= -50%
PIT RATE= +50%
I got my AIL and AU1 reversed. Rest are NOR.
I forgot which servos goes where, but basically the 3 CCPM servos will go into AIL(1), ELE(2), and PIT(6) channels.
Hope this helps. Give me a shout if you need more help.
Steph280 is online now Find More Posts by Steph280
Old Jun 30, 2001, 07:29 PM
Brett is offline
Joined Jun 2001
Thanks for the help, what does that AIL, ELE and so on do at +50 +50 -50 and what will happen if the settings are changed there, I'm not sure I understand what those do.
Old Jul 01, 2001, 08:00 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
The elevator is opposite because of the way the servo's are mounted in the Voyager, if you make them all + then the elevator will not operate correctly and can't just be fixed with the reversing switch. The values are 50% I think because if you made them 100 you would use all your servo's rotation for the collective range then have none left for cyclic commands.
Chris True is offline Find More Posts by Chris True
Discussion Jr voyager e gyro help RCHSF Electric Heli Talk 11 Mar 30, 2007 06:13 PM
Sold JR Voyager E Needs help Simbo Aircraft - Electric - Helis (FS/W) 0 Dec 19, 2006 07:52 PM
Discussion very odd problem with Jr Voyager E, please help b3guyRC10 Electric Heli Talk 16 Aug 17, 2006 10:30 AM
JR Voyager E setup COOLDOG Electric Heli Talk 1 Jan 28, 2004 08:06 PM
JR Voyager E - setup, performance, etc ... Peter Khor Electric Heli Talk 32 Jul 20, 2002 07:39 AM
