Old Dec 31, 2011, 09:02 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Originally Posted by ewoodcox View Post
Tonight I start building a cheap 450 to put in my UH-1 fuse, plan on making this FBL with the 3X1000 and a copterX FBL head. Man, that copterX stuff is real quality.
Happy New Year!!!!!!!
Happy DX8!
I've read that the CX FBL head has really short arms - think it was TexasClouds pointed it out.
My dog will be happy when everyone has used up their fireworks!
2Doggs is offline Find More Posts by 2Doggs
Old Dec 31, 2011, 09:10 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I wonder if KY has changed it yet. Looked like someone there just put a kit together not realizing the normal pro blade grips are different from the fbl ones.
ewood, I am going the other way. Started to build from ordered parts a 450pro for my third 3x1000
mhills51 is offline Find More Posts by mhills51
Old Jan 02, 2012, 08:38 AM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
Got one pack each on the 120SR and the Hausler450
I did wreck/crash the 120 and broke the skids
Black_heart is offline Find More Posts by Black_heart
Old Jan 02, 2012, 10:35 AM
ewoodcox is offline
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
well, no flying, the winds are howling and tonight artic air is supposed to leave us 2-4" with more in persistent snow bands, that generally means we will get more than most
I built my $18 wonder, it is ready for shakedown flights then I will install the bent boom for the UH-1, more flight tests then the fuse. With the weather, no telling how long that will take.
There appear to be two different copterX FBL heads, I ordered this one for $19 without swash and main shaft, same one with swash and shaft is ~$49, they also have another for $29, I think after taking this one apart I will order the $49 for all future FBL 450s I will compare this with my RXT head to see if the arms are shorter/longer or what
The 3X1000 is sooooooooo easy to set up, it will be interesting to see how it flies.
Hope everyone is getting air
ewoodcox is offline Find More Posts by ewoodcox
Old Jan 02, 2012, 11:03 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Thanks for posting the pics, Ed! It's interesting to see the bolt-on arms on that FBL head - it would make it easy for them to revise the arm length.
And we can add blade grip arm length to maximum servo driving frequency as the must-know info for 2012!
Old Jan 02, 2012, 03:35 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Flown 2 packs on my first FBL converted 450, and 2 packs with my new night blades i just finished.
This 450 with the lights really screams for an FBL upgrade. Its flies so crappy at the moment i barely dare to do a roll....
Night blade DIY version 4 (2 min 17 sec)
sp00fman is offline Find More Posts by sp00fman
Old Jan 02, 2012, 04:48 PM
ewoodcox is offline
West Monroe NY
Joined Feb 2009
nice night cruser spoofman where did you get your blades, I have been looking for night blades for a 450 for sometime.
Old Jan 03, 2012, 12:46 AM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
I build them in about 4 evenings.
Strips of copper tape and soldered in resistors and 0805 SMD LED's. Final finish with automotive clear coat and carwax.
Old Jan 03, 2012, 07:35 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
In today's news, A UFO was spotted in the Netherlands. People said it was much to fast for any airplane!!
Old Jan 03, 2012, 08:00 AM
clicky is offline
Find More Posts by clicky
UK
Joined May 2007
Someone doing crazy 3d with heavily lit helicopter?
In the strong winds, too?
clicky is offline Find More Posts by clicky
Old Jan 03, 2012, 11:25 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Governed
Whilst the UK suffered hurricane force winds today, we had crisp, cool, still air this morning. Three packs on the HK 450 Pro, first flying at HS2400 for close to 8 minutes, then HS2600 for 7, and HS2800 for 5:30. What a great governor mode the Superbrain ESC has....!
Edit: after checking the data logs for this mornings flights, it looks like there's less peak amps and a lot more voltage drop in the Zippy packs under load when the weather is cold - it was probably about 40f.
Old Jan 03, 2012, 04:21 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Flew my 250 for one pack and my trusty old tail servo burned up.
can't be to mad that poor servo had been on 2 450's and ended up
on my 250 only because the servo I got for it had to be returned.
Old Jan 04, 2012, 11:03 PM
powerstroke01 is offline
Find More Posts by powerstroke01
powerstroke01's Avatar
USA, CA, Ahwahnee
Joined Sep 2004
Flew 4 packs today. Mostly hovering with a bit of FF.
powerstroke01 is offline Find More Posts by powerstroke01
Old Jan 05, 2012, 11:02 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Fbl
5 packs this morning, in perfect, still, cool air and sunshine. I am just amazed at the performance of the CX 3x1000 FBL controller. I still need to work on the tail, but got rid of a right swing on positive pitch pumps by adding 20% collective to tail compensation. So easy to do at the field with the program box!
Having started out on the beginner model, #1, I decided to try #5, the "Extreme" model. Whew! I have never been able to get my HK 450 Pro to flip as fast with FB! I had to put in 30% expo on cyclic, and 80% rates in normal mode.
It seems like I can get the heli to flip and roll faster at HS2700 than I ever could at even 3000 with the flybar.
The tail is still loose, but I have some slop and a bit of binding to sort out before I fool around with the various gains.
Old Jan 06, 2012, 01:56 AM
clicky is offline
UK
Joined May 2007
Welcome to the FBL world! I had exactly the same experience about the speed of cyclics on my MT with ÁBeast. I dropped HS to around 2400-2600 and still have quite fast cyclics - much faster than 3000+ and very quick TT's green flybar paddles... With lower HS it is far less intimidating and as performant (less tic/tocs and similar)...
BTW I'm hoping that I'll be able to fly today. Started feeling withdrawal symptoms - didn't fly since Monday!!!
How late did YOU fly tonight? Tres Wright Parkflyers 41 Mar 12, 2011 06:53 AM
I flew EVERY DAY This Week, What did You FLY? Lv2Fly Electric Plane Talk 4 Jun 29, 2002 11:47 AM
What did YOU fly today? Tres Wright Parkflyers 45 May 28, 2002 05:34 PM
What Did You Fly Today? boomerace Parkflyers 46 May 01, 2002 11:23 PM
Superbike (Mike) did you fly your Honey? hmhoshi Electric Sailplanes 15 Jul 01, 2001 06:27 PM
