Old Jul 31, 2011, 09:42 AM
ewoodcox is online now
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
nice looking fleet KCinNC
I swapped another GP750 on my EXI500 plastic, tail still has a tinny wag on occassion but the heli flies nice. I put 3 paks just flying around the yard...unfortunatly, the rest of the day is a work day so I will be grouned.
hope everyone is getting air this weekend
ewoodcox is online now Find More Posts by ewoodcox
Old Jul 31, 2011, 11:30 AM
clicky is offline
Find More Posts by clicky
UK
Joined May 2007
I can, now, officially say that I started learning piro flips! Why? Easily - the more I try to do them, worse then end up! Last were really horribly all over the place
But, slow (and faster), controlled inverted pirouettes are slowly coming together - I can, now, do them sustainably - even with Protos if high enough!
clicky is offline Find More Posts by clicky
Old Jul 31, 2011, 12:14 PM
chronic is offline
Find More Posts by chronic
chronic's Avatar
Alberta, canada
Joined Apr 2009
Good stuff clicky! My friend started off learning half piro flips to inverted, and then slowely learned the last half. Now he's almost at the point where he can do two or three full piro flips smoothly and in one area. Its exciting to see and it sounds fricken cool!
chronic is offline Find More Posts by chronic
Old Jul 31, 2011, 12:48 PM
p4ddy is offline
Find More Posts by p4ddy
RC4Life not just 4 xmas
p4ddy's Avatar
southampton uk
Joined Jun 2006
Piro flips are easier to learn if you start each flip at the same point each time. I start when it's tail in then start the 2nd half tail in aswell. This helps you get the cyclic timing correct aswell.
p4ddy is offline Find More Posts by p4ddy
Old Jul 31, 2011, 01:28 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
I just flew 3 packs with my new Spartan Quark. first pack I worked on the tail setup and trim. then flew the best 2 packs of my career. the precision and predictability are outstanding.
after bad experiences with two previous gyros (GY240 and GP780), the Spartan finally feels right. I actually think I finally flew the real thing as well as I can fly on the simulator. much more smooth and coordinated, a totally different comfort level.
It was so good, I rushed home and fast-charged two of my packs, went back again just before dusk. Two remarks:
#1 the spartan made the BA what it should've been from the beginning. Best heli purchase I ever made!
#2 damn it's hard to see the heli attitude in the dusk light. At times, the heli looked just like a flat black shadow against the evening sky.
Because of the light thing, I kept the second flight more conservative, but boy it's so easy to roll and flip if the tail stays in place.
Dr.M is offline Find More Posts by Dr.M
Old Aug 01, 2011, 05:31 PM
West Monroe NY
Joined Feb 2009
2 paks in my TREX250 this morning
Old Aug 01, 2011, 06:14 PM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
Yesterday I rushed to a flying field at the end of the day, took out T-rex 450 SE #1, did the Scorpion motor lube thing and tri-flowed the mechanics. Wind dropped to nil while I did the pre-flight ... then I discovered I'd left the Tx switched on for a couple of days! Deep breaths, take a few minutes to appreciate the grass and light, then back home to charge the DX7 and hope I get some time to fly today.
zen@lanset.com is offline Find More Posts by zen@lanset.com
Old Aug 01, 2011, 07:45 PM
estarter is offline
Find More Posts by estarter
Berkeley, CA
Zen, install a bright LED light to remind you the Tx is ON, I have fogotten to turn off the Tx,drained the battery couple time.
Took the mcpx on a business trip, had 3 flights this moring and lost the main gear, picked up the bird after crash, usually the main gear get push down, this time it is gone, is there any hobby store around Reno, NV area carry mCPX parts?
estarter is offline Find More Posts by estarter
Old Aug 01, 2011, 08:29 PM
West Monroe NY
Joined Feb 2009
I do a control check prior to take off and a TX off check at the end.
Hope you got some air Zen
Old Aug 01, 2011, 11:21 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
I got one pack through my 450 and proved to myself that it is too small for me to fly at the club and also that the transmitter is not part of the trouble I am having with the 550. Man, that 450 gets far away much too fast, lol. However, I was able to do some troubleshooting on my 550EFL and may have found the reason for the crash last weekend and the two near crashes this afternoon. The ESC seems to be the part at fault and NOT the 3G system. I had disabled the internal BEC and went to an external BEC so I took it out of the system and put it back to the internal BEC. I had thought that it may have been the external BEC as I got a warning from my Skookum software about a brownout, bad ESC, or bad servos so I changed back to the internal BEC. When I spooled up, the initial hop in the air was great but suddenly the heli started to get a bit squirrely and I put it down with no crash. I had one other flight before (extremely short one) and it was also a heart stopper so I had to get to the bottom of it. I bought the full Skookum data viewer program so I can have a look at the two files for the flights to see what was happening at the receiver level. I now have a Phoenix HX 85 installed with the external BEC back in the system. There is a very small possibility of it being the remote Spektrum RX but there would be some indication of a signal loss that may have caused a system reset but the light has been on solid the entire time. I am getting a second remote RX to go along with this first one and that should eliminate any shadowing that may be happening at distance as the crash and these weird actions have all taken place with the heli no further away than 75 feet. At least I can fly my other helis with no worry about the TX being part of the mix. Hope tomorrow is a LOT better, lol. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Aug 02, 2011, 02:02 AM
clicky is offline
UK
Joined May 2007
I do sympathize with you. And you were much luckier than I was: mine DX7 packed up when I switched it on when got to the field. And, even worse was that time I didn't rush to fly the moment I got there, but just took time to enjoy it as day was fantastic and I was in the mood to fly. Just to pack up all the things back and go home And, from when I've seen so far - that DX7 is properly fried (it is not only a power supply/regulator as I really hoped)
BTW it looks like that you're not the first one to forget his TX switched on - software in DX8 starts yelling at you if you leave it alone for too long. All the beepers, vibrations and lights flash at you... I found it out only this Sunday when decided to move blade grips from 425mm Protos to 470mm one on the field (I stripped thread in blade grip for the link ball)
Old Aug 02, 2011, 02:17 AM
Joined Jan 2007
Yeah, I hardly ever do this, which obviously is not synonymous with 'never'.
Old Aug 02, 2011, 03:59 AM
porcupinepower is offline
Find More Posts by porcupinepower
Watching the wingtips
porcupinepower's Avatar
Australia, NSW, Sydney
Joined Jul 2010
Put a pack through my Sr and went inverted for the first time.
Couple of clumsy flips and a lot of circuits, loving the idea of 3-d.
porcupinepower is offline Find More Posts by porcupinepower
Old Aug 02, 2011, 11:04 AM
Speed Stick 3D is offline
Find More Posts by Speed Stick 3D
Supra!!!!!!
Speed Stick 3D's Avatar
Las Vegas Nv, USA
Joined Oct 2005
Well no more flying until Ircha, Going to save the helis.
Will be leaving at 7am on thursday with Ben WOOT!
Speed Stick 3D is offline Find More Posts by Speed Stick 3D
Old Aug 03, 2011, 09:44 AM
West Monroe NY
Joined Feb 2009
wish I could go to IRCHA, have lots of fun...
Been flying a pak or two everyday, great weather so I am missing allot of good flying. Flew a pak this morning in my TREX250....what a awsome flier
Hope folks are flying more than me
How late did YOU fly tonight? Tres Wright Parkflyers 41 Mar 12, 2011 06:53 AM
I flew EVERY DAY This Week, What did You FLY? Lv2Fly Electric Plane Talk 4 Jun 29, 2002 11:47 AM
What did YOU fly today? Tres Wright Parkflyers 45 May 28, 2002 05:34 PM
What Did You Fly Today? boomerace Parkflyers 46 May 01, 2002 11:23 PM
Superbike (Mike) did you fly your Honey? hmhoshi Electric Sailplanes 15 Jul 01, 2001 06:27 PM
