Old May 29, 2011, 03:49 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Strange failure - first auto
a few days ago, I was flying my HK450 Pro, doing a few loops and flips, when the motor started to scream. Thinking the pinion had slipped off the shaft, I managed to flip to throttle hold and auto down into long grass without any damage. It turns out the pinion hadn't slipped - the motor shaft had broken off, and the pinion was still there loose, on top of the motor, a Turnigy Typhoon 2218. It seems odd to me that the shaft should break like that.
2Doggs is offline Find More Posts by 2Doggs
Old May 29, 2011, 04:11 PM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
2Doggs— motor shafts do break on several manufacturers' motors. I have had output shafts break on two Align 430L motors. Some people think that having the pinion too tightly pressed against the big drive gear contributes to these failures.
zen@lanset.com is offline Find More Posts by zen@lanset.com
Old May 29, 2011, 07:53 PM
Frenche is offline
Find More Posts by Frenche
ooooh yeah
Frenche's Avatar
Ballarat, Victoria, Australia
Joined May 2004
I doubt the pinion has anything to do with it, to get it tight enough to put enough sideways loading on the shaft to weaken/snap it would make for a horrible gear mesh and an amp hungry motor. Most likely it's crappy steal and not quite perfect machining, especially with the cheaper motors that causes the failures
Frenche is offline Find More Posts by Frenche
Old May 29, 2011, 07:59 PM
minicopters is offline
Find More Posts by minicopters
Joined May 2011
I lost a pinion gear on my copter but they sent me a new one with a screwdriver no problems since. Unfortunately plastic, but still very strong.
minicopters is offline Find More Posts by minicopters
Old May 29, 2011, 08:14 PM
Joined Jan 2007
It's hard to imagine a plastic pinion gear on anything larger than an indoor micro heli.
I got a little airtime at the Berkeley Marina this afternoon. First I flew my first test flights with an Easy Glider Pro powered sail plane. A few short hand launches, then turned on the power to get high enough to really crash it! There were so many kites in the area that I put it away and flew old reliable T-rex 450 SE #1. As always the kids came running so I landed it for a little show-and-tell and decided to call it a day.
Old May 29, 2011, 09:20 PM
micronut is offline
Find More Posts by micronut
dont play with rc anymore
micronut's Avatar
United States, MO, St Joseph
Joined Feb 2005
Originally Posted by arbilab View Post
Your plains winds should be a lot like ours, micro. (I was born there [stl] and live here.) Even CALM wind has gusts.
I guess I'm used to windy conditions...gusts up to 5mph or so over the "steady" wind speed are pretty normal around here, so that doesn't bother me at all. 10-20mph gusts are no fun, though.
micronut is offline Find More Posts by micronut
Old May 29, 2011, 10:03 PM
Joined May 2011
The helicopters I have cant fly in any wind whatsoever, guess I have a lot to learn about remote control copters! lol
Old May 30, 2011, 02:11 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
This was my first motor shaft failure, and quite a surprise. I'd never tried to do an auto on a 450 before. The shaft broke at the retaining clip groove, where there would be stress concentration. I wonder if it was fatigue failure. The pinion is obviously not perfectly balanced, since it uses a single steel grub screw. My maingear mesh was actually a bit on the loose side - I was intending to tighten it up. Previously, the same motor was suffering from the front bearing spinning in the housing, and after I sorted that out with some CA, there was evidence that the shaft was spinning in the inner race. Maybe that weakened it. All of the above are no doubt cheap motor issues, but at $12 a pop, they're almost disposable. Maybe I'll treat myself to a Scorpion one of these days!
Old May 30, 2011, 02:44 PM
sandos is offline
Find More Posts by sandos
Sweden
Joined Jan 2010
Flew a 4s for the first time on my 450. I will probably slowly shift to 4s, because it now has awesome POWER! Wow, the climbouts are like twice the speed compared to 3S. Well ok, maybe not but it is much faster. It also seems to drain the battery real quick though
Now I "only" need to finally get the tail to never let go, which it does sometimes. I also really need to know if my one-way bearing is up to the task, because something is slipping under load. I'm guessing the belt, but I'm still not sure.
sandos is offline Find More Posts by sandos
Old May 30, 2011, 04:12 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
you might check the one way - or at least the mainshaft cover. On my HK 450 Pro, the cover wears out quite quickly, though it normally first shows up as the OWB jamming. The clone metal is far too soft, though i've yet to try an align part on it.
Old May 30, 2011, 09:37 PM
Luvmyhelis is offline
Find More Posts by Luvmyhelis
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Here are the remains of my last flight with my 6s modded heli. Found it though!
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old May 30, 2011, 11:15 PM
RCnGuy is offline
Find More Posts by RCnGuy
What's Nitro?
RCnGuy's Avatar
United States, IL, Schaumburg
Joined Dec 2007
Ouch. I thought the "Fly Mentor" was supposed to prevent that kind of thing?
RCnGuy is offline Find More Posts by RCnGuy
Old May 31, 2011, 01:13 AM
Luvmyhelis's Avatar
Joined Oct 2010
I had it almost turned down to 0. I was hotdogging right after taking my afternoon bash of pain meds, and did one of the most stupid acts of my flying history and got it lost over the treeline. Our weather is on a historic cold streak in the northern U.S. and opportunities to fly have been rare. So when a break happened in the weather I took it. Bad move all the way around. Had the FM been turned up this honestly would have never happened. It is an amazing system. Now I am upping this to an fbl build with an SK-720.
Should be interesting.
Old May 31, 2011, 06:20 AM
Hyvok is offline
Find More Posts by Hyvok
Joined May 2010
I'd look in to 6S before shifting to anything. Seems to be fairly common (long topic on helifreak about running 6S on 450 pro). Some dude even had 8s on his.
Hyvok is offline Find More Posts by Hyvok
Old May 31, 2011, 11:49 PM
drakonis is offline
Find More Posts by drakonis
AMA 743519 Team Heliproz Pilot
drakonis's Avatar
United States, WA, Granite Falls
Joined Mar 2006
hovered my scale project today. without scale body. just in the testing phases. so far 2 failures. my cascade type tail rotor failed on the bench due to an out of balance issue (need to make another shaft) and then during a hover the belt drive gear (plastic) melted during one of the hovers, luckily i was mere inches off teh ground. i found one that was aluminum and replaced the gears. its better but the belt got trashed in the failure so i need to replace the belt. sheesh what a pain. a 5 blade head sure sounds awesome at speed. after i make another shaft for the tail it should be better. it did not have enough authority on the tail.
drakonis is offline Find More Posts by drakonis
How late did YOU fly tonight? Tres Wright Parkflyers 41 Mar 12, 2011 06:53 AM
I flew EVERY DAY This Week, What did You FLY? Lv2Fly Electric Plane Talk 4 Jun 29, 2002 11:47 AM
What did YOU fly today? Tres Wright Parkflyers 45 May 28, 2002 05:34 PM
What Did You Fly Today? boomerace Parkflyers 46 May 01, 2002 11:23 PM
Superbike (Mike) did you fly your Honey? hmhoshi Electric Sailplanes 15 Jul 01, 2001 06:27 PM
