Had 5 good flights today
Well I got my Raptor out again today and flew 3 tanks through it. I think I have the carb adjusted about two clicks on the rich side of optimum power. I can hold my finger on the backplate for about 6 seconds so I guess I'm good. The wind was gusting to 30 mph which was nothing to the Raptor as compared to the Blade-400, the raptor would just sort of move alittle bit "like Snuffalufagus on Seseme Street
" and that was about it. I am burning 7.8 oz of fuel in ten minutes doing ff flight and hovering and the head speed is about 1700 RPM. Is this good? fuel tank is stock and the engine is a TT.39 with 13 tanks of fuel run through it. Well after the Raptor, I got out the Blade and tried to hover in that same wind Wow! What a handfull it was, but I still kept it up and practiced nose in hovering in high winds for a couple of packs and all is good seeing that me and my helis all came back in one piece. Whoohoo I love my Rappy!! Hope yall had a good flying day!
Ontario, Canada
I used to get the ocasional brownouts. Untill I found the culprit. I am sure most have seen one of THESE Well I have learned the hard way that this effect is similar to what happens with belt driven tail rotors on our Heli's. The rubber belt spinning around fast in the tail creates a build up of static that occasionaly will discharge on either the Gyro, a tail servo or the RX. Should this discharge make its way to the RX, it will shut it down for a moment. Then the RX will come back on. In most cases you will regain the servo control for an attempt at autorotation. But the motor will either still be trying to initialize or will be in it's slow spool up phase before you make it down. A fix? I have been spraying the belt and both Main and tail gears with a Silicon spray. I apply it on the gears using a Qtip (Cotton Swab) and I spray the belt by sticking the tube in the right side slot. Little shots while spinning the blades. This usualy lasts about 20 packs / flights. I inspect the belt (and Heli) after each flight and if the belt looks wetish <-- is that a word? then I leave it. If it looks dry I repeat. I have not had a single power interuption ever since. Those that have "Random power failure" or brownout, may be having a static discharge problem causing it. Then again, it could be. - Signal loss (Low TX bat) - Faulty RX - Faulty ESC - Severed wire - Short circuit due to vibration wear - and other. Just wanted to share my invisible, untraceable, I checked everything else and it looks fine, Ahhh Haaa I found it, fixed it, and now its flying great story with you. ![]() http://www.youtube.com/watch?v=So_N2QjjyaM&NR=1
Steve, i fly a raptor too. I air on the cautious side and make sure there is always a healthy amount of blue smoke coming from the exhaust. The oil makes a mess but i have ran gallons and gallons of fuel through mine without issue. If you dont already have one i would recommend a header tank as well.
Header Tank neccesary?
I have plenty of smoke coming out but I don't have a header tank as of yet other than removal of air bubbles during 3d flight and a little extra fuel what other purpose does it serve and is it neccesary to have one for just hovering and ff flight? Another guy at thee field has the same heli as mine but with a OS.32 and his runs at a higher head speed and is much more responsive than mine. How is the Power on the TT.39 compared to the OS.32 ? And what is the max safe speed to spin the TT 550MM woodies with glued root ends? Thanks in advance!! PS I did fly 3 packs today through my Blade-400. I was going to fly my Raptor, but after I had it loaded in my car the clouds came and it rained servos and tailbooms for about an hour and a half so by the time it quit raining it was almost dark so I didn't have time to even get it out of the car , so I just flew my Blade around and chased the neighborhood cat around alittle
I had the OS 36 ( i think) before i upgraded. My dad had the TT motor and there is a huge difference. I think a header tank is just a safety device that (in case you do run out of fuel in the main) Gives you plenty to land and whatnot. Its easy to tell when you have hit the reserve, the HS goes up a bit along with the pitch of the motor. I have no idea about HS with the raptors. I ran 100% for the longest time with an old set of woodies without issues. I upgraded to some Carbon blades and havent looked back. Oh and autoing the raptor compared to a 450 is like a dream. You might be interested in reading this, defines a H tank a little better than i do: http://www.heliproz.com/DBCheaders.html J |
| Thread Tools | |
| How late did YOU fly tonight? | Tres Wright | Parkflyers | 41 | Mar 12, 2011 06:53 AM |
| I flew EVERY DAY This Week, What did You FLY? | Lv2Fly | Electric Plane Talk | 4 | Jun 29, 2002 11:47 AM |
| What did YOU fly today? | Tres Wright | Parkflyers | 45 | May 28, 2002 05:34 PM |
| What Did You Fly Today? | boomerace | Parkflyers | 46 | May 01, 2002 11:23 PM |
| Superbike (Mike) did you fly your Honey? | hmhoshi | Electric Sailplanes | 15 | Jul 01, 2001 06:27 PM |
