Old Sep 03, 2007, 06:14 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Not bad! Seems easily fixed!
As for the cause? Was it windy? The bank could of caught the wind and whipped it over.
Could of been a glitch.
Servos still good?
Sorry bout the crash, it happens, just sucks when it happens to one of your Favorites.
Atom1025 is offline Find More Posts by Atom1025
Old Sep 03, 2007, 06:17 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
glitch?
it is a tough bird alright.
punkrockd is offline Find More Posts by punkrockd
Old Sep 03, 2007, 06:45 PM
methos is offline
Find More Posts by methos
methos's Avatar
Canada
Joined Jun 2006
Yeah it was windy, maybe a strong gust caught it, although it seemed like an rx glitch... I dunno.
Yes it is easily reparable, it's all cosmetic except the back of the battery box, which will just take a small amount of glue to fix. and the servos are all fine.
It is definitely one tough bird, I was sure it was demolished, the thump it made when it hit the ground was sickening. I spent 20 min checking it out all over for damage and mushy spots, and there were none! I really could have threw it back into the air and flew it.
One of my packs were slightly deformed, but I straightened it out, and it seems fine.
What a day, I was sure I was going to post here that my wing was destroyed.
Talk about luck hey?
Ed
methos is offline Find More Posts by methos
Old Sep 03, 2007, 08:16 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
rx
Was it a berg rx?
ck
klique is offline Find More Posts by klique
Old Sep 03, 2007, 09:10 PM
methos is offline
methos's Avatar
Canada
Joined Jun 2006
yes
Old Sep 03, 2007, 09:30 PM
klique is offline
Mum is the word!
Joined Jun 2003
Enough said ,sorry dude there is a reason why I tell people not to use them
I love castle but I hate bergs.
ck
Old Sep 03, 2007, 10:12 PM
methos is offline
methos's Avatar
Canada
Joined Jun 2006
I'll have to pick up an Electron 6 I guess.
I really don't want this to happen again, I won't be so lucky next time I bet.
Old Dec 02, 2007, 11:58 PM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Methos,
I ordered myself a 36" Sportster and was curious if you could pass along your final setup . I have read and heard from Adam that you have tried quite a few different props. What are you most happy with?
My thought is that I would use the Microdan motor as well since you seem to have been really happy with it. What prop and batts would you recomend?
Also, what is the cleanest / lightest / easiest method for mounting thise motors? It appears as though you have a custom mount.
Scott
P.S. I'm jumping the gun a bit as I probably won't start building until the new year...
reefboy is offline Find More Posts by reefboy
Old Dec 03, 2007, 11:36 AM
methos is offline
methos's Avatar
Canada
Joined Jun 2006
Well I don't really have a "final setup" yet but I can tell you what I'm using right now;
MicroDan 2505 Speed motor
APC 4.75 x 4.75 prop
2 x 2100mAh 7.4v 18C lipo's in series (and about 5.5 - 5.75 oz of lead)
E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC (60 amp to make room for more power) This ESC has a built in Switching BEC capable of handling up to 6s !
Hitec Electron 6 RX
This power system pulls 38 amps static, about 500 watts and has a pitch speed of about 150mph. It pushes the Sportster well beyond 120mph.
The limiting factor in this system is the weak packs, I'm pushing them to the max at 38 amps, but I know the motor can take more power.
BUT... I'm about to upgrade
I have 2 x Poly RC 2500mAh 7.4v 25c lipos ordered from CK that I'm going to implant into the Sportster and change the prop to an APC 5x5.
This setup should pull over 45 amps(closer to 48amps), and over 650 watts with an estimated pitch speed of about 165 mph and over 50oz of thrust It won't have long flight times, but It's going to be scary fast for a thin little 36" Sportster. I can't wait!!
Yes I have a custom motor mount, and the only thing I can suggest, it to keep an eye on this thread, interesting things are happening: MicroDan 8mm adapter for 28mm Ritewing Mount
Hope that helps.
Ed
Old Dec 03, 2007, 01:11 PM
reefboy is offline
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Thanks Methos. All good information!
Sounds like it will be a blast when I finally get around to it
What is your current AUW?
Old Dec 03, 2007, 01:47 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Here is some info Ed(methos) passed along to me. Thought it would be helpful.
Originally Posted by methos
AUW is 29oz, The throws for elevator are 1/8" up 1/8" down on both high and low rates. (any more and it will snap out of a loop at full elevator)
The throws for the Ailerons are 3/16" up and 3/16" down in low rates and 1/4" up and 1/4" down on high rates. It rolls like crazy on high rates
Old Dec 03, 2007, 07:58 PM
reefboy is offline
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
1.7:1 thrust ratio mmmmmmm with speed to to boot
To bad I'm a major slacker and this will take me forever. But gotta start planning sometime.
Discussion RiteWing 36" Sportster "Demon" Helicool Flying Wings 1 Jul 18, 2007 11:21 PM
Yippee! My new CK 6s DEMON jarvis2542 Flying Wings 7 Sep 03, 2006 09:02 AM
My new toy: a ritewing arrow raptor22 Slope 23 Jul 18, 2005 12:45 AM
My new creation 36" wing jschick Foamies (Kits) 11 Feb 12, 2004 09:28 PM
Questions about my wally B-36...I'm new to foam. Boba_Fett Foamies (Kits) 8 Jun 11, 2002 03:36 PM
