Old Aug 09, 2007, 10:33 PM
poker_run is offline
Find More Posts by poker_run
Joined Jul 2007
decorating and painting EPP
What is used to decorate and paint your epp plane?
Poker
poker_run is offline Find More Posts by poker_run
Old Aug 09, 2007, 11:27 PM
LuckyDay is offline
Find More Posts by LuckyDay
EPP Addict
LuckyDay's Avatar
Nashville, TN
Joined Jan 2006
Paint works... I have seen some mix paint with thinned goop for extra strength. I used acrylic paint on the F-15 cockpit.
I have had decent luck covering EPP with Econokote/Oracover (F-15, Wild Wing). Just spray with 3M77 or similar prior to covering, and EPP can take higher iron temps than EPS. Colored packing tape works ok too, better on wings than on full-fuse type planes.
Need to keep it light? Try Sharpies. That's right... markers. See the FauxFlea in the avatar. They do tend to fade and rub off on your hands though, much less permanent.
LuckyDay is offline Find More Posts by LuckyDay
Old Aug 10, 2007, 08:48 AM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
We've used 'shortcuts' paints from Wal-mart (small yellow can) and it is safe for just about every type of foam that we've tested, and also Krylon H2O paints... My Skyray is primarily gray (H2O) in color with some Florescent orange (shortcuts) accents for orientation...
Other than that, we do use sharpie for drawn in canopies, panel lines, etc...
Use whatcha got!
msmith is offline Find More Posts by msmith
Old Aug 11, 2007, 09:01 PM
Joined Jul 2007
thanks. Do you suppose monokote and Ultrakote would work too?
Poker
Old Aug 12, 2007, 07:17 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Poker: Check the temperature... Econokote is fairly low, but you still have to be much more careful than with wood.
Gene Bond is offline Find More Posts by Gene Bond
Old Aug 12, 2007, 09:03 AM
Joined Jul 2007
ok. Thanks.
Question Painting EPP zippogeek Foamies (Kits) 9 Mar 21, 2015 11:57 AM
Discussion Cleaning Blue FFF prior to decorating / painting VWmad Foamies (Scratchbuilt) 8 Apr 08, 2009 12:57 PM
Discussion Painting EPP? Tram Foamies (Kits) 12 Jun 27, 2007 12:06 AM
