Old Aug 13, 2007, 12:39 AM
oldtribefan is offline
Find More Posts by oldtribefan
oldtribefan
oldtribefan's Avatar
United States, GA, Kennesaw
Joined May 2007
Stunning models! I have never seen better. Thanks for sharing.
Kip
oldtribefan is offline Find More Posts by oldtribefan
Old Sep 05, 2007, 06:49 AM
Bob L is offline
Find More Posts by Bob L
Ypsilanti,Michigan
Joined Jan 2005
Breath Taking
Hello
You are a true craftsman,an out standing model in everyway.
Bob L is offline Find More Posts by Bob L
Old Sep 05, 2007, 12:16 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Can't imagine how I missed this thread....
Wait, it's been an event filled month.
Fantastic work,...
I like the rubber stamp step, and all the metal work.
Why/what is triple chromed? Does it make for a super hard or super shiny surface?
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Sep 05, 2007, 04:03 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Most all chrome is/should be "triple". What it really means is, start with a base metal part polished up real pretty;
1. Copper plate it and buff out the copper even shinier;
2. Nickel plate it;
3. Chrome flash on top.
The chrome is always way thinner than the base copper and nickel.
patmat2350 is offline Find More Posts by patmat2350
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Triple Chrome Plating
Generally, copper, nickel, then chrome.
From the internet:
"Triple Chrome Plating", "Quadruple Plating", "Double Nickel-Chrome"
As mentioned, decorative chrome plating always involves at least two layers of plating--a layer of nickel and a layer of chrome. But high quality plating requires a minimum of two layers of nickel. (There may also be a layer or two of copper underneath the nickel. And if the parts are plastic, there will be a layer of electroless nickel under that. If the parts are aluminum, there will be a zincate layer first, etc.)
Salespeople are always looking for advantage, and they will use any good-sounding terms they can get away with! There are no laws that define what triple chrome plating actually means, so salespeople will be prone to call their service "triple chrome plating" if there are a total of 3 layers of any kind of plating, or "quadruple chrome plating" if there are 4. So those terms mean little.
The most important issue for quality chrome plating (for outdoor exposure such as on a vehicle) is that it MUST have at least two layers of nickel plating before the chrome: namely semi-bright nickel followed by bright nickel. The reason for this involves galvanic corrosion issues. The bright nickel is anodic to the semi-bright nickel, sacrificially protecting it, spreading corrosion forces laterally instead of allowing them to penetrate to the steel. OEMs require very close control of this factor, and there is a test (the Chrysler developed STEP test) which large shops run daily to insure the right potentials. Control of this issue is probably the principal reason that today's chromium plating greatly outlasts the chrome plating of earlier times.
Experts argue whether copper plating provides any additional corrosion resistance at all, but with or without copper plating underlying the nickel, chrome on top of a single layer of nickel will not hold up to the severe exposure of a vehicle! Industry professionals call the two layers of nickel "duplex nickel plating", and that would be a much better term to use than "triple chrome" and such.
Chrome plating is hardly a matter of dipping an article into a tank, it is a long involved process that often starts with tedious polishing and buffing, then cleaning and acid dipping, zincating (if the part is aluminum), and copper plating. For top reflectivity "Show Chrome", this will be followed by buffing of the copper for perfect smoothness, cleaning and acid dipping again, and plating more copper, then two or three different types of nickel plating, all before the chrome plating is done. Rinsing is required between every step.
Kmot is online now Find More Posts by Kmot
Old Sep 06, 2007, 12:51 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
2. Nickel plate it;
Pretty much that in a nutshell. I used a guy in North Hollywood, CA., since retired. He would buff the raw fitting, copper plate, buff that, nickel plate, buff that, then drop it into a chrome tank, then buff that. The guy did great work. One thing about chrome plating, it will not hide imperfections. It shows everything. The copper coat can be a heavy coat to help hide stuff, but that leads to distorting details. Best case; finesse all imperfections before you take a part to a chrome shop. Buff, buff, buff. Polishing is the key. Oh yea, make sure to talk to the person that will actually be handling your part. The last thing you want is a car bumper expert handling a model part you just spent three weeks perfecting doing the dipping.
woodybob is offline Find More Posts by woodybob
Old Jul 07, 2009, 05:38 PM
H.Lauer is offline
Find More Posts by H.Lauer
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
WOW!! just spectacular Pat
Hows the Barrelback doing?
H.Lauer is offline Find More Posts by H.Lauer
Old Jul 07, 2009, 08:27 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Thanks Harry. The Barrel Back is collecting dust. Been busy on other boats.
I have this old VECO 35 Ocean Going Tug screaming at me. I'm thinkin' something like this.
Old Jul 08, 2009, 04:51 AM
H.Lauer is offline
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
I'd forgotten about that one... Great photo should/will come out great. Harry
Old Nov 02, 2009, 06:57 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
I'm really mad now. Here I am sitting here looking at two model runabouts with NOT ONE FLAW anywhere on the boat. There's not a single nail out of line or even a little wiggle in the trim. It's too perfect to be real. Must be photoshopped or sumpin. Ain't never seen models so well done eva in ma lifetime. Beautiful work both of you guys. I would even go so far as to call it spectacular and I don' give that to anyone. Pete
norgale is offline Find More Posts by norgale
Old Nov 02, 2009, 07:03 PM
Kmot is online now
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
aliens...
Old Nov 02, 2009, 07:25 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Thanks Pete...it's just a Dumas kit, slightly modified.
Old Nov 03, 2009, 11:39 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
I believe that I came up against this boat at one of the IMS shows in LA. If it's the one the pictures do not do Justus. It is just beautiful. It is a shame that the Krokers are gone I do have a boat with two in line. Fast, powerful, and smooth motors.
I think I'm starting to give away my age now.
GILL RC is offline Find More Posts by GILL RC
Old Nov 03, 2009, 11:42 AM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Ya I know ,it's just a kit and anybody can build a kit,even me. However the finish is what separates the men from the boys and you have to be a giant among men of model building. The extra details also makes the model and it's for certain that many painstaking hours of time were put into these models. A wonderful bit of work there WB. Congratulations on some very superb work. Pete
Old Nov 03, 2009, 11:55 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Thanks G. Need to see your boat with the top removed.
Thanks Pete.
Discussion Dumas 1940 Chris craft 19' barrelback riggerman Scale Boats 16 Oct 16, 2007 02:01 AM
Question Dumas 19' Chris Craft racer - Hull Painting Anton70 Scale Boats 10 Mar 29, 2006 07:25 PM
Dumas 1940 Chris-Craft Barrel Back Tom73 Scale Boats 10 Dec 18, 2005 04:28 PM
Wanted Dumas 1940 Chris Craft Barrel Back kit Airnut 2 Boats (FS/W) 0 Dec 15, 2005 04:15 AM
Dumas 1940 Chris Craft Barrel back kit richphoto Boats (FS/W) 2 May 12, 2003 09:29 PM
