Old Jan 22, 2013, 07:50 AM
Webmaister is offline
Find More Posts by Webmaister
I like Fast Warbirds
Webmaister's Avatar
United States, GA, Atlanta
Joined Nov 2011
looking for speed?
Originally Posted by kremecheze View Post
my revolver with a rimfire 46, 12x8 prop on 6s 5000 40c packs only does about 115, and it puts out close to 1700watts. how are you getting 125 on only 1300 watts...def let me know how it goes, i'm looking to get a little more speed out of her next season. i was even thinking about going with a 12s 3000mah setup just cant find the right motor
I played around with several motors and the most success I've had so far is with a Scorpion HK 4025 740 spinning a MAS 11 x 10 prop. This motor can handle up to 10S. I have it installed in a Hangar 9 P40B which weighs in around 8.5 pounds. Just on 8S (2 more cells to go), the onboard Voltron measured top speed at 151 mph. The only video I have so far is this crappy one where the head cam was off center. Going to take some more videos when I get her back out. I order these motors from Innov8ative Designs. Jordan, who works there, will swap the shaft around and install a 6mm shaft for a little extra cash. At the very end of the video, I check the Voltron. Here's the 151 mph run:
151 MPH Hangar 9 P40B (8 min 46 sec)
Webmaister is offline Find More Posts by Webmaister
Old Jan 22, 2013, 12:34 PM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
i couldnt find the 4025 740 motor, can you post a link to it
kremecheze is offline Find More Posts by kremecheze
Old Jan 22, 2013, 12:35 PM
kremecheze's Avatar
Joined Jun 2007
found it...didnt realize it was a heli motor
Old Jan 22, 2013, 12:46 PM
kremecheze's Avatar
Joined Jun 2007
ecalc shows close to 150amps on 11x10 thats kinda high for ta plane this size..you would have to use atleast 5000mah packs
Old Jan 22, 2013, 01:45 PM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
I hope that plane has been modded for speed or its not long for this world. No H9 warbird will last to long at those speeds.
gewiens is offline Find More Posts by gewiens
Old Jan 22, 2013, 03:45 PM
Webmaister's Avatar
Joined Nov 2011
Yea I was worried about that. I brushed extra epoxy inside all the ribs as far as I could reach on each side before assembling the wing. The wing also uses ply as a wing joiner instead if a tube. Seems pretty solid and I could see any flex looking at the stills.
regarding the amps, I'm only pulling about 90 amps. I have a 4000 5S and a 4000 3 cell run in serial.
I also modded a FMS 1450 MM foam P51 with this same setup. I added extra carbon spars and some fiberglass with a one wing mod. With the drag it has I can only get 132 mph out of it. It has about 30 flights on it and is running a Castle Ice 100 but other than that, the same setup.
132 MPH Airfield P51 Mustang (7 min 7 sec)
Old Jan 23, 2013, 02:17 PM
ehskds is offline
Find More Posts by ehskds
Now you see it...
ehskds's Avatar
United States, KY, Henderson
Joined Feb 2006
I realize every one here is into making this bird electric but I had to share that I'm dropping in the new evolution 10cc into this. When I finally get to fly it ill let you know how it goes.
ehskds is offline Find More Posts by ehskds
Old Jan 23, 2013, 08:41 PM
afjetmech is online now
Find More Posts by afjetmech
afjetmech's Avatar
United States, NC, Rocky Mt
Joined Mar 2009
Looking forward to that.
afjetmech is online now Find More Posts by afjetmech
Old Feb 12, 2013, 12:42 PM
ehskds is offline
Now you see it...
ehskds's Avatar
Joined Feb 2006
Don't know when I'll get the chance to fly it. May be a while.
Old Feb 24, 2013, 09:56 PM
Leadbottom is offline
Find More Posts by Leadbottom
Leadbottom's Avatar
Long Beach, California
Joined Nov 2009
I have spoken with three people with Revolvers saying they ripped the landing gear off on their first or second landing. They all recommend I replace the entire under belly with 1/4" plywood and lots of epoxy. I think I will just in case.
Leadbottom is offline Find More Posts by Leadbottom
Old Mar 09, 2013, 09:59 AM
tlr-boise is offline
Find More Posts by tlr-boise
Boise, ID
Joined Dec 2008
Hi. Back starting at post 132 is a couple posts and series of pics that show how I fixed the landing gear. Hope it helps you.
tlr-boise is offline Find More Posts by tlr-boise
Old Mar 18, 2013, 05:38 PM
Sweetrex is offline
Find More Posts by Sweetrex
Addicted to my hobby
Sweetrex's Avatar
United States, NV, Las Vegas
Joined Sep 2009
I just finished reading through the thread. I can't wait to get mine built up. So far I've got a Rimfire .46, Castle Ice Lite 100 ESC, a variety of props (Xoar & APC), a 6S 3300mAh Turnigy A-SPEC Battery (90C-130C?), 2 Turnigy Nano-Tech 4000mAh Batteries, and a couple of good Hitec servos...oh, and of course I will have the DuBro landing gear on it as well.
I'm accustomed to flying fast wings, Funjets, etc. but never anything this heavy. I fear that my home field has an inadequate runway (250 ft, carpeted) so I may be venturing off to a different part of town to fly it or at the very least, maiden.
It appears that this plane is a well built rocket. This should be interesting. (fingers crossed)
Sweetrex is offline Find More Posts by Sweetrex
Old Mar 18, 2013, 05:43 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
I would highly recommend trying it somewhere else first.
Old Mar 18, 2013, 10:19 PM
Boise, ID
Joined Dec 2008
Sweetrex,
Are you accustomed to flying a slick, fast plane that will tip-stall in a nano-second if you try to turn base to final too slow? In my (admittedly limited) experience, this plane will do that.
If you have a 250' carpeted runway, you might do just fine, although you might take up about 200' of it, unless you touch down right at the end of your runway. Gewiens' experience is evidently similar to mine, i.e., my landings have tended to take up the whole runway, but that's primarily because I can't seem to touch down until just before midway of a 500' long blacktop runway.
With yours carpeted, you might do just fine. You might consider dialing in some exponential, and keep the speed up until you fly it down to just over the end of the runway.
Best of luck to you! Let us know how your flights go. This is a terrific plane, but personally, it kept me on pins and needles every time I flew it. Pretty dang responsive, and probably was a bit beyond my abilities.
I do think the videos show the plane can land within a 250' runway.
Old Mar 18, 2013, 10:26 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
Yep. If you can touch down right where you want it will work but mine is running on 7 and 8s which makes it even heavier. I go way way out on final to bleed off speed in a straight line. If its calm I almost have to go into the next area code to bleed off enough speed.
Discussion Great Planes Revolver .46-.70 Ep Arf Jim T. Graham Product Announcements 9 Jul 30, 2012 06:44 PM
Discussion Great Planes Revolver E&T78 3D / Fun Fly Fuel Planes 2 Aug 01, 2007 11:47 PM
Great planes Slow Poke?? Steve H. Electric Plane Talk 22 Apr 03, 2002 01:31 PM
--------- Great Planes Lear Jet conversion ----------- Kolchak Electric Plane Talk 1 Jun 30, 2001 10:28 AM
Great Planes/Futaba Contact Sabrejock Electric Plane Talk 0 May 23, 2001 06:45 PM
