This thread is privately moderated by KiwiKid, who may elect to delete unwanted replies.
Old Aug 08, 2007, 06:38 AM
KiwiKid is offline
Find More Posts by KiwiKid
I need adult supervision
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Indoor F-27 Stryker
Recently threw together an indoor Stryker. Its the fourth one off the production line, but the first for indoor. Built it over two nights. The fins are made of 3mm depron so are one crash wonders, but I just keep a supply of replacements handy, although I haven’t had to use any yet. Just made up a card board template from a standard Stryker fin and can knock out a depron fin in no time. Elevons are 6mm depron with a thin c/f strip c/aed to the trailing edge to give rigidity. I am just using a 280 brushed/geared motor set up as I had three sitting around doing nothing. When these are used up I will replace with an outrunner.
I have also used it very successfully as a ridge soaring glider. The motor is just stick mounted with two screws so comes off in about 30 seconds and then you have a very good ridge soarer. Just fly it on the ridge with a 650 mah battery which would probably last all day.
AUW for indoors is 10.5 oz and it is a barrel of laughs. Need to get some more around so we can try indoor pylon racing. Another benefit is that you can fly it in restricted areas outside which is a plus.
Heres some pics, the white Stryker is the indoor ship, the bomb dropper is a converted std Stryker which is alot of fun. We have competitions at my club field aiming at targets. I also drop a parachute and lollies from it. The "Vulcan" is a roust about park flyer, medium weight and very agile with a brushless outrunner set up, while the "Flanker" is a heavier drag racer set up for maximum speed at the field, powered by a brushless inrunner.
Heres a link to some info posted awhile ago by "blucor basher". He said "Saw Mike Conalley flying a Stryker indoor last season, looked cool, so I did one for myself. 9.8 oz. w/ StrongRC 17T CD Rom motor wound by Mark Greer (member Aeronot), GWS 7035 prop, TP 480 3S. HS-55 servos, T-bird 9 esc. 6mm depron elevons and 3mm depron fins, $19 Stryker B replacement foam body. Flies like a feather, too fast for indoors if you open it up."
http://www.2kool4u.com/stryker/strykervids.shtml
Theres some other interesting Stryker stuff at that site - have a look around.
EDIT 12/07: Just posted a vid of the "Vulcan" hooning around down at the park. Link is here: http://www.rcgroups.com/forums/showthread.php?t=781817
KiwiKid
KiwiKid is offline Find More Posts by KiwiKid
Old Feb 15, 2009, 10:11 AM
Michael Johnson is offline
Find More Posts by Michael Johnson
Proud member of AAA
Michael Johnson's Avatar
Joined May 2007
The canopies look great, especially the last one posted. I really like that paint scheme. Lexan vertical stabs on the one with wheels?
MJ
Michael Johnson is offline Find More Posts by Michael Johnson
Cool Indoor F-27 Stryker KiwiKid Scratchbuilt Indoor and Micro Models 5 Aug 07, 2007 12:26 AM
F-27 Stryker?? thor4944 Foamies (Kits) 133 Nov 30, 2004 07:29 PM
ParkZone F-27 Stryker maiden flight/review MGBGTRacer Parkflyers 99 Jul 17, 2004 05:04 AM
ParkZone F-27 Stryker for $60 rc_ron Parkflyers 24 Jul 13, 2004 07:37 PM
Alert Park Zone F-27 Stryker Kado Parkflyers 24 Jun 27, 2004 02:14 PM
