Old Aug 08, 2007, 04:04 AM
faraz99 is offline
Find More Posts by faraz99
Joined Jul 2007
Diy Altimeter With Pic
can any one provide me the code and schematics for altimeter with mpx4115 sensor.
faraz99 is offline Find More Posts by faraz99
Old Aug 08, 2007, 05:45 AM
fredhs is offline
Find More Posts by fredhs
Germany
Joined Nov 2005
Hi,
although the information is not specifically what you were asking for, it should help getting you started:
http://topaflyers.com/kites/altbuild.html
Regards,
Fred
fredhs is offline Find More Posts by fredhs
Old Aug 08, 2007, 08:09 AM
MikeDD is offline
Find More Posts by MikeDD
Joined Nov 2003
Check in Components section here for some altimiter projects.
http://www.elkhart.net/~miked/Ulinks.htm
MikeDD is offline Find More Posts by MikeDD
Old Aug 08, 2007, 10:43 PM
GlennS is offline
Find More Posts by GlennS
Flying 3 mistakes high
GlennS's Avatar
Melbourne, Australia
Joined Jun 2004
check this one out:
http://www.jbgizmo.com/page27.htm
It uses a PIC12F675.
I built it and it worked fine. Ended up adding a header for an LCD display to read it out on the ground.
Glenn.
GlennS is offline Find More Posts by GlennS
Old Aug 12, 2007, 02:44 AM
Cyb is offline
Cyb
Find More Posts by Cyb
Cyb
Belgium
Joined Sep 2003
I also made a small altimeter with Pic + mpx4115A. http://www.ploumen.be , it's in french.
Cyb is offline Find More Posts by Cyb
Old Sep 16, 2007, 02:40 AM
gEcky is offline
Find More Posts by gEcky
Joined May 2005
Originally Posted by GlennS
check this one out:
Glenn.
Hi GlennS,
did the code from jbgizmo work without any modifications? I tried it with my P16pro programmer and winpicprog software but it din work... .hex was compiled using MPLAB v6.3 that i installed ages ago
With my limited knowledge of ASM, i managed to write a routine to flash the red n green led... this shows tt the PCB is ok...
Appreciate any help...
gEcky is offline Find More Posts by gEcky
Old Sep 16, 2007, 03:39 AM
GlennS is offline
GlennS's Avatar
Joined Jun 2004
Its been a while since I made it, but cant remember any problems with it. I had a look at the source (its still on my PC) and cant see any changes I made on the leds only version.
I ended up adding some code to drive a 16x2 LCD display.
I used a JDM style programmer and icprog to program the chip.
BTW as described, the resolution is about 30ft per count on that unit. You could improve that with a scaling op-amp stage.
Glenn.
Old Sep 16, 2007, 04:10 AM
gEcky is offline
Joined May 2005
Glenn.
Thanks! I'll relook at the code again
Old Sep 17, 2007, 08:58 AM
gEcky is offline
Joined May 2005
Don't find anything wrong with the code. Anyone else has built this ( http://www.jbgizmo.com/page27.htm )altimeter successfully?
Old Sep 23, 2007, 03:42 AM
gEcky is offline
Joined May 2005
upz...
Anyone built one?
DIY ESC with PICīs - is possible? fr3d Micro Helis 4 Dec 06, 2004 03:39 PM
Problems with the Pic Pro ScotY Micro Helis 15 Sep 27, 2003 09:25 AM
GWS P-51 mustang F/S with pic look waytoofast Aircraft - Electric - Airplanes (FS/W) 0 Jul 21, 2003 11:20 PM
My sunday smash and crash :-) With pic Puddlemaster Parkflyers 2 May 25, 2003 09:56 PM
"Thou shal not" with a Pic Pro Eco8gator Micro Helis 2 Feb 10, 2003 07:10 PM
