Old Nov 17, 2002, 03:01 AM
Sloper Mario is offline
Find More Posts by Sloper Mario
Seņor Meember
Sloper Mario's Avatar
Joined Sep 2001
800mAh 7 Cell 5/4 AAA packs good for messing around?
This may be a really stupid question so bear with me for a moment. I'm getting my VIP together and was thinking about battery combos. From my lurking/reading I've pretty much decided on 7 cell Hecell packs for most of my flying. However I have a stack of Wattage 7 cell 800mAh 5/4 AAA packs that I use in my Hawk. They weigh ~3.75oz and work fine in my Wattage Hawk w/sp400. I was wondering if these would be suitable for use in the VIP as well? Obviously they have lower output so I won't be setting any speed records but I'm thinking maybe their lighter weight would compensate and perhaps allow decent flying at a more relaxed pace. Am I way off base with this? Let me know.
Mario
Sloper Mario is offline Find More Posts by Sloper Mario
Old Nov 17, 2002, 09:08 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Re: 800mAh 7 Cell 5/4 AAA packs good for messing around?
Cell capacity has nothing to do with the amps a cell can put out or the power that is delivered by a motor attached to different cells. The motor will take the current it needs until the cells are discharged. The only difference will be that the duration of flight with the lower capacity cells will be less than with the HECells.
So yes. The smaller cells will work fine in the VIP and will probably give you a better overall performance because they're lighter.
DaveSawers is offline Find More Posts by DaveSawers
Old Nov 17, 2002, 01:26 PM
Seņor Meember
Joined Sep 2001
Thanks for the reply Dave. I guess I didn't use correct terminology. I understand that mAh rating has nothing to do with cell resistance. By output I was referring to the motor's ability to draw power from the battery without performance degradation. Also, what do you mean by "better overall performance"? Most of the pylon folks in here define performance in terms of speed and retention of speed in turns. Certainly lighter wing loading has its advantages but speed usually isn't one of them is it?
Mario
Old Nov 17, 2002, 05:17 PM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
The internal resistance of a cell can make a BIG difference in the output of the motor, since V=IR. With a motor drawing I current, if R gets bigger, the voltage drop V gets bigger to compensate. A large voltage drop across the battery means less voltage available for the motor. Small V at the motor=slower speed, since it's voltage that drives the motor.
Unlike slope soaring, where gravity is your source of acceleration, e-pylon uses only the propeller for acceleration. Therefore, heavy means slow, not fast. This is because the heavier the model, the more energy is wasted just to get it moving. Furthermore, matters are made worse when you want to turn. The heavier the model, the higher the lift coefficient required to make the turn. The higher the lift coefficient, the higher the drag... and the more speed is lost.
So if you can find two batteries capable of delivering the current you need at the voltage you want... then the lighter of the two will result in the faster airplane.
good luck,
-David
davidfee is offline Find More Posts by davidfee
Old Nov 18, 2002, 12:22 AM
Seņor Meember
Joined Sep 2001
OK so I'm a sloper boat anchor! Thanks for the good explanation David!
Mario
Old Nov 19, 2002, 08:55 PM
Tim2000 is offline
Find More Posts by Tim2000
Guest
California
Joined Jan 2002
I read somewhere in ezone that these cells may go as high as 10 amp? am I correct here?
Tim2000 is offline Find More Posts by Tim2000
Old Nov 21, 2002, 01:00 AM
Seņor Meember
Joined Sep 2001
I don't really know Tim. Actually my friend has an ampmeter. I suppose I could do a static test to see what they'll do. I'll post the results.
Mario
For Sale Wattage 5/4 AAA 8 cell NimH batteries for sale shschon Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 05, 2006 10:36 AM
Another 5/4 AAA cell source ... Peter Khor Batteries and Chargers 9 Apr 05, 2003 11:07 PM
Where is a Good & Cheap place to find 5/4 AAA Nimh loose Cells? mrebman Batteries and Chargers 1 Feb 14, 2003 11:06 PM
15 Packs-7 CELL 8.4 Volt GP 370 MAH austinelse Aircraft - Electric - Airplanes (FS/W) 1 Dec 14, 2002 03:45 PM
Rave 5/4 AAA 800 mah cells $2.75 per cell. RobDog Parkflyers 0 Jan 30, 2002 10:00 AM
