Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
Old Aug 07, 2007, 01:58 PM   #1
Callsign: Jolly Roger
Printed Warbirds and more. Part 2
Well the origional thread for this is still back in the Kit forum due to its age but some had mentioned that it might see more interest if moved into its proper place.
Origional thread here:
http://www.rcgroups.com/forums/showthread.php?t=342625
In anycase. The series of Printed warbirds is a great way to have a superb looking plane without great expense. Attached below are my copies of each of the designs. The P-40 and the Avenger I've reworked to clean up the prints. No changes other than flattening the wing (Yes flat wings, we have found that they work better for our flying styles. The Airfoil wings add some lift but as we do allot of 3D or combat we find the flat wings better for our preferences) Other than that though I've not changed the designs keeping the spirit of the origionals as intact as possible. I'm loading the JPEGs, and PDF's I've made of each.
To build them Print, and trim. Use the prints to cut your foam. Build using carbon fiber in both the wing and the Fusulage. The usual method for the fusulage is to use a 3/32 Tube in the fusulage and to attach the 3/8ths motor mount stick on the end of the CF. I've redone the wing mounts on the planes I've redrawn for a flat wing. Most of the flyers I've flown with have found the Airfoil design added little to the lift and a fair bit to the effort it took to building the plane and even led to unbalanced wings when the bend of the airfoil was not evenly made.
Make sure to check the Birddog posted by kdahlhaus on the bottom of page 2, Also check out the p-38aa post at the top of page 2 by bEbop.
Edit for October 10:
Leadfeather and Firetrapp have teamed up to add a great new dimension to this line of planes with thier F-22. http://www.rcgroups.com/forums/showthread.php?t=753146
Make sure to see at the bottom of page one where leadfeather has managed to Thrust vector his motor. I've long been a fan of RCSuperPowers thrust vectored planes (I have one of his f-22 kits) but this design adds not only elevator thrust vectoring but rudder vectoring as well.
Edit for May 8, 2008
Beaux has added the Hawker Tempest to the line of Warbirds available.
http://www.rcgroups.com/forums/showt...32#post9716482
Edit for August 5, 2008
kdahlhaus has added a Polikarpov I-16 http://www.rcgroups.com/forums/showp...&postcount=631
December 2008 Some long overdue edits.
JoseyWales has done a nice redition of the P-47
http://www.rcgroups.com/forums/showt...8#post11149568
BlazerB52 has contributed a number of planes on pages 57&58
http://www.rcgroups.com/forums/showt...724566&page=56
ChrisK has done a nice Hawker Sea Fury on Page 55
http://www.rcgroups.com/forums/showp...&postcount=825
And a 30 inch FW-190 on page 81
http://www.rcgroups.com/forums/showp...postcount=1201
As well as his orgional 40 Inch model.
http://www.rcgroups.com/forums/showp...&postcount=551
JoseyWales has also done quite a bit of work redrawing the Japanese Zero at 300 DPI on Page 54 (Two versions)
http://www.rcgroups.com/forums/showt...724566&page=54
Flyboy878787 has added a Stuka to our collection.
http://www.rcgroups.com/forums/showp...postcount=1234
Heymak has tiled the Spitfire for us. on page 74
http://www.rcgroups.com/forums/showp...postcount=1105
Pickel72 has drawn a new P-40 design with some great detail work. Page 65 (Tiled to 11x17)
http://www.rcgroups.com/forums/showp...&postcount=975
Seagraves has "untiled" the fusulage for this one.
http://www.rcgroups.com/forums/showp...&postcount=985
BlazerB52 has added a few more for us. Spitfire Variants and Supermarine Seafire on page 59
http://www.rcgroups.com/forums/showp...&postcount=883
  • Name: 30405LeesP51.jpg
Description: This is the one that started it all.  A bit pixellated but still an impressive work. This is the one that started it all. A bit pixellated but still an impressive work. 105.2 KB · Views: 3254
  • Name: 30405TimsZero.jpg
Description: Got to have at least one bad guy (well at least from the american view) for Air combat with Got to have at least one bad guy (well at least from the american view) for Air combat with 82.1 KB · Views: 2678
MyDigitalParadis is offline Find More Posts by MyDigitalParadis   Reply With Quote
Old Aug 07, 2007, 02:09 PM   #2
Now for the one's that I have thus far redrawn.
The avenger is scaled to print at 40 inch wing span. Printing the PDF at 90% will give a 36" wing. We found though that of all the planes in this series that the Avenger with a 40"+ wing to have the best glide capabilities and had good flight charactaristics including inverted flight.
  • Name: Avenger_72_dp1.jpg
Description: This was actually my second effort at reworking a print plane.  Lot's of work here in Illustrator to include the rivet work. This was actually my second effort at reworking a print plane. Lot's of work here in Illustrator to include the rivet work. 101.8 KB · Views: 2182
  • Name: TimsP40_LightTanDarkGreen copy.jpg
Description: My first effort at redoing one of Tim's work. My first effort at redoing one of Tim's work. 86.3 KB · Views: 2271
Old Aug 07, 2007, 02:13 PM   #3
A few pictures of our local use of these great planes.
The prints have been very popular and my access to large format printers makes it very easy for me to produce the prints.
  • Name: alexp51_3.jpg
  • Name: jdsp51.jpg
  • Name: jdsp51_2.jpg
  • Name: LeesZero2.jpg
  • Name: P51CombatLaunch1.jpg
  • Name: P51CombatLaunch2.jpg
  • Name: P51LowPass2.jpg
Old Aug 07, 2007, 02:44 PM   #4
This is a much shrunk version of my latest effort based on one of my favorite planes. I'm working on an origional plane design though before I release The design in general.
Edit: Adding in Josec's Lavochkin La-7
  • Name: Stars_N_Stripes.jpg
  • Download La734.pdf La734.pdf (153.3 KB, 2551 views) JOSEC did a great job adding this beatiful print to our collection.
Old Aug 07, 2007, 03:09 PM   #5
kdahlhaus's Avatar
Great to see the new start. There was also a full-fuselage version of the P-40 at:
http://www.rcgroups.com/forums/showt...highlight=p+40
'Michael in Toronoto' Hellcat:
http://www.rcgroups.com/forums/showthread.php?t=879639
No pics, but SteveC68 posted
a nice Spitfire: http://www.rcgroups.com/forums/showp...&postcount=935
tiled: http://www.rcgroups.com/forums/showp...postcount=1105
a P-51b: http://www.rcgroups.com/forums/showp...&postcount=930
BlazerB52:
Japenese ???
http://www.rcgroups.com/forums/showp...&postcount=848
Mig3: http://www.rcgroups.com/forums/showp...&postcount=852
Assorted Spitfires: http://www.rcgroups.com/forums/showp...&postcount=883
Joseywales:
P-47: http://www.rcgroups.com/forums/showp...&postcount=860
Awesome detailing of the original Zero: http://www.rcgroups.com/forums/showp...&postcount=796
ChrisK:
FW-190:
40" http://www.rcgroups.com/forums/showp...&postcount=551
30" http://www.rcgroups.com/forums/showp...postcount=1201
Hawker Sea Fury: http://www.rcgroups.com/forums/showp...&postcount=825
Grumman F-8F Bearcat: http://www.rcgroups.com/forums/showp...&postcount=538
Douglas A1H SkyRaider:
http://www.rcgroups.com/forums/showp...&postcount=536
Zipped prints: http://www.rcgroups.com/forums/showp...&postcount=537 (higher resolution)
IAR-80:
http://www.rcgroups.com/forums/showp...&postcount=755
kdahlhaus:
Polikarpov I-16: http://www.rcgroups.com/forums/showp...&postcount=631
Dc-3 http://www.rcgroups.com/forums/showp...&postcount=510
Pickle72:
ParkFlyer Pete Skin:
http://www.rcgroups.com/forums/showp...&postcount=545
Tiled pdfs are 2 posts below this one
Very Detailed P-40: http://www.rcgroups.com/forums/showp...&postcount=975
Cartoon P-40: http://www.rcgroups.com/forums/showp...&postcount=575
Beaux:
Hawker Temptest: http://www.rcgroups.com/forums/showp...&postcount=469
TOG (?):
Bird Dog
http://www.rcgroups.com/forums/showp...3&postcount=29
In the original thread there is an Army green version as well.
Electronick:
misc airliners and ww-1 biplanes - not profile, but printed folded fuse?
http://www.rcgroups.com/forums/showp...&postcount=504
Josec
BF-109 (from scratch!)
http://www.rcgroups.com/forums/showp...&postcount=199
tiled (thanks Segraves): http://www.rcgroups.com/forums/showp...&postcount=202
Josec
Lavochkin LA-7:
http://www.rcgroups.com/forums/showp...&postcount=182
(tiled by Segraves) http://www.rcgroups.com/forums/showp...&postcount=185
Segraves:
FW-42 from luft 46: http://www.rcgroups.com/forums/showp...&postcount=328
Stevec68:
Fw190D-9:
http://www.rcgroups.com/forums/showp...&postcount=923
Neons:
Posted the Komet build. http://www.rcgroups.com/forums/showp...postcount=1177
Skins are from http://www.radiocontrolesing.com.mx/
Flyboy878787:
JU-87 Stuka:
ChrisK:
35" P-47 Thunderbolt
http://www.rcgroups.com/forums/showp...postcount=1241
Other skins from http://www.radiocontrolesing.com.mx/:
[imghttp://www.radiocontrolesing.com.mx/imagenes/imagenes/panther%202%202ll.jpg[/img]
Last edited by kdahlhaus; Feb 04, 2010 at 07:28 PM. Reason: added plans/pics up to post 1241
kdahlhaus is offline Find More Posts by kdahlhaus   Reply With Quote
Old Aug 07, 2007, 03:16 PM   #6
Yea that is something I'm hoping to work on adding top and bottom graphics. I'd like to come up with an EPP design for the full fusulage.
Old Aug 07, 2007, 03:47 PM   #7
Team Compass USA
Send a message via AIM to brian94066 Send a message via MSN to brian94066
that's cool, free plans ^_^
brian94066 is offline Find More Posts by brian94066   Reply With Quote
Old Aug 07, 2007, 03:50 PM   #8
Frankenstein recycled packs
rampman's Avatar
OMG - this is COOL. MyDigitalParadis, YOU ROCK.
Rick
www.CommonSenseRC.com
rampman is offline Find More Posts by rampman   Reply With Quote
Old Aug 07, 2007, 04:10 PM   #9
Thanks, but it's not my idea orgionally. I've just worked on cleaning them up as they are enlargements of small hand launched gliders that used to be printed on letter sized paper. I hope to see some new Pictures of planes built by others soon.
Old Aug 07, 2007, 04:29 PM   #10
gpw
Foamie Guy
Silver Member
gpw's Avatar
Send a message via AIM to gpw
If these could be printed on something like Tyvek , might add a tremendous amount of strength to the airframe ...anybody tried that yet ???
gpw is offline Find More Posts by gpw   Reply With Quote
Old Aug 07, 2007, 05:09 PM   #11
Team Compass USA
you can keep things simple by printing them out to a size that you want, cut out the parts on any kind of material you want for your plane, then glue the printed paper onto it, making an instant cool looking war bird ^_^
Old Aug 07, 2007, 05:36 PM   #12
Originally Posted by MyDigitalParadis
...The series of Printed warbirds is a great way to have a superb looking plane without great expense. Attached below are my copies of each of the designs. ...
Great work, MDP!
1. Perhaps the parts could be rearranged for double-sided printing directly onto the material for the model, as in the MicroPitts and MicroMoth.
2. Another alternative, print onto tee-shirt transfer material, and iron the transfers directly onto the parts for the model.
Cheers and thanks,
Bill Segraves
segraves is offline Find More Posts by segraves   Reply With Quote
Old Aug 07, 2007, 05:42 PM   #13
Again I din't start these designs just worked to clean them up. Sorry I'm just not one to steal someone elese thunder. That said thanks for the Kudos. See the origional thread for the who and what started all this. (Idamann, T1mux and WCFlyer)
The T-shirt idea is a great one if the foam can take the heat of the ironing. Reversing the images is easy enough. If someone tries it definitely post back the results. It would be much lighter than gluing on paper and the prints fade if left in the sun too much.
Old Aug 07, 2007, 06:26 PM   #14
kdahlhaus's Avatar
Some of the planes originated from the printed peanut flyers at this site:
http://users.joplin.com/~wcflyer/freedir.htm
Old Aug 07, 2007, 06:34 PM   #15
Mario 2007's Avatar
The series of Printed warbirds is a great way to have a superb looking plane without great expense. .
Are you using a specific large printer for foam sufaces? or simply printing the design on paper and applying it on to the foam sheet? I've got several original airplane designs and coming up with more, that could use a quality printer. I've had success printing high quality on decals and applying that to foam, but my dilema is finding a quality printer that will print directly to depron, in particular on larger sheets 2x4ft or 4x8Ft and leave a high quality, vivid color and finish. Some commercial printed foamie planes have a sort of washed out finish, and multicolor bleed, not what I am looking for. If anyone knows of a printer or company that specializes in printing on depron foam surfaces, let me know.
Thanks.
  • Name: MIAMHUR18S.jpg
Mario 2007 is offline Find More Posts by Mario 2007   Reply With Quote
Video 3DFoamy.com Super Caps part 2! Midairs and more flyfalcons Airplanes - Electric Videos 1 Jul 10, 2006 10:54 PM
For Sale A handful of STUFF Part 2... added more. Blaze.45 Aircraft - Electric - Power Systems (FS/W) 17 Apr 09, 2006 12:41 PM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 03:00 AM
Hornet CP .... finally ... part 2 cyhyam Electric Heli Talk 90 Aug 05, 2001 10:40 PM
MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) MicroRotors Electric Heli Talk 10 Jul 27, 2001 04:19 PM
Congratulations SimpleM!
