Old Aug 06, 2007, 11:56 AM
davef27 is offline
Find More Posts by davef27
Chester, UK
Joined Nov 2005
Where to get voltage regulator 5v
Iím looking to build/buy a voltage regulator (5v). Iím looking to power the video transmitter from a 3s li-po battery and was wondering if anyone can point me to a suitable UK based supplier.
I donít mind soldering or assembling components, but I just havenít figured out where to find one.
Any guidance/advice appreciated.
Dave
davef27 is offline Find More Posts by davef27
Old Aug 06, 2007, 12:47 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
You should be able to get the parts for that in most any hobby electronics shop. Alternatively mail oder from e.g. http://www.farnell.co.uk/, or www.conrad.com, or other suppliers that seem OK if you Google for '"electronic component" uk'.
Arthur P. is offline Find More Posts by Arthur P.
Old Aug 06, 2007, 01:43 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
If you're in the US you can get them at Radio Shack for less than 2 bucks. That's where I got mine. They have a diagram on the package to tell you where to solder the wires.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Aug 06, 2007, 01:46 PM
davef27 is offline
Chester, UK
Joined Nov 2005
Thanks guys.
I've just been on to the Farnell web site. I had no idea it was that easy.
3 pins 2 x capacitors and you're done..... or am I missing something?
Old Aug 06, 2007, 03:42 PM
robe_uk is offline
Find More Posts by robe_uk
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
you are in the uk so you may have a maplins store near you www.maplins.co.uk
robe_uk is offline Find More Posts by robe_uk
Old Aug 06, 2007, 04:10 PM
GliderGuideMan is offline
Find More Posts by GliderGuideMan
Kite flying SCRAPS member
GliderGuideMan's Avatar
Hampshire, UK
Joined Apr 2004
or you could try a UBEC such as the one on BRC Hobbies website. I use one to power my Canon A620 from my flightpack, it works a treat and you can get them for around 8 quid!!
Cheers
DaveB...>
GliderGuideMan is offline Find More Posts by GliderGuideMan
Old Aug 06, 2007, 04:26 PM
Hellbore is offline
Find More Posts by Hellbore
RC Airplane Crasher
Mesa, AZ
Joined Jan 2007
I used a TI switching voltage regulator to powwer my camera, it's more efficient than the junky linear regulators you get at Radio Shack, plus it can handle 1 Amp continuous and not get hot at all.
Hellbore is offline Find More Posts by Hellbore
Old Aug 06, 2007, 08:56 PM
DiveBombDave is offline
Find More Posts by DiveBombDave
Pull out early!
DiveBombDave's Avatar
Lexington, KY
Joined Jan 2005
When powering a video transmitter, the switching regulators create a pattern of interference lines (called Moire' lines). Though less efficient and less tolerant of higher voltages, the cheap linear regulator adds no interference to the video signal. I use a buffered LM2905 on a heat sink for my planes that I care about the recorded video. On planes I'm just using the video downlink to frame shots, etc, I cheat with a switcher.
Dave
DiveBombDave is offline Find More Posts by DiveBombDave
Old Aug 07, 2007, 02:00 AM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Originally Posted by davef27
Thanks guys.
It's really that simple
David
PS. I run mine off a 2-cell 1350mAh Tornado LiPoly pack.
Hogster is offline Find More Posts by Hogster
Old Aug 07, 2007, 02:12 AM
Pull out early!
Lexington, KY
Joined Jan 2005
... power the video transmitter from a 3s li-po battery .... Dave
I've had problems with heat using a 7805 on 3s.
Dave
Old Aug 07, 2007, 02:19 AM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Yeah, go for a 2s pack. Otherwise you're dissipating (12-5)*(current draw) watts across something 10mm square! Say you're drawing 300mA, that's 2.1W .... good for warming your fingers when you handle it, but a waste of energy! With a 2s setup it would be nearer to 0.75W which is more reasonable.
I'm running a 10mW 2.4GHz transmitter AND my A620 off a 2s pack with a 7805 and it barely gets warm.
Cheers,
David
Old Aug 07, 2007, 04:18 AM
Gray is offline
Find More Posts by Gray
Smile & wave
Gray's Avatar
Lancing West Sussex
Joined Jun 2005
I use this little device from Perkins, not a bad price ether!
http://www.jperkinsdistribution.co.u...s%20and%20accs
Gray.
Gray is offline Find More Posts by Gray
Old Aug 07, 2007, 04:38 AM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Hmmm What do you use that for Gray? With those specs I would assume it's a switching regulator, which a downlink might not like ...
David
Old Aug 07, 2007, 05:35 AM
Gray is offline
Smile & wave
Gray's Avatar
Lancing West Sussex
Joined Jun 2005
David,
I use it to power the A620 in the EZ* and uses the main lipo pack for power input with the BEC powering the RX.
Iíve not had the opportunity to use it with a downlink though!
Gray
Old Aug 07, 2007, 02:07 PM
Hellbore is offline
RC Airplane Crasher
Mesa, AZ
Joined Jan 2007
Dave, the moire lines you mentioned, do you think they would occur when just using the regulator to power a digital camera recording video?
That is what I'm doing, and I have not noticed moire lines, but do you think they could be there and I just haven't noticed them? Could they be lowering the quality without me knowing it? How easily can they be seen?
If I post one of my aerial videos could you tell me if you see any interference in it that could be caused by this?
x250 Where to get Lightweight Decal or graphic paper? costath Electric Plane Talk 4 Nov 25, 2013 07:13 AM
Does anyone know where to get Panasonic "high voltage" 3000s in the UK? Ben C Electric Plane Talk 2 Jun 30, 2002 06:07 AM
7.2-7.5V Voltage regulator Bleriot Power Systems 4 Dec 13, 2001 12:22 AM
Where to get decals? mikeb33 Electric Plane Talk 6 May 18, 2001 04:02 AM
Where to get RC and flying books Red Baron 47 Electric Plane Talk 2 May 08, 2001 06:59 PM
