Old Jan 04, 2010, 12:39 AM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
Another question guys, If I were to scratch build this plane how many pieces of depron will I need? Looks like it is broken up length wise. Does this mean I can use the 27.5 x 19.5 sheets from Grayson or do I need the full sheets?
DH
CaptDH is offline Find More Posts by CaptDH
Old Jan 04, 2010, 06:10 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
A single full sheet is best. Then you can cut out the main body as a single piece by placing it diagonally across the middle,and then fit the other pieces around the edges.
Harrow is offline Find More Posts by Harrow
Old Jan 04, 2010, 08:10 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Darrin:
We were only using the 2200mah in the static tests. In flight, we are using 3s 1550mah 30c. However, many folks are using the 2200's in flight. It does appear that this 28" wingspan can handle the extra weight...although the flight characteristics will change at least slightly.
I agree with Harrow. A single full sheet is best. The sheets I am using are ~32x49. If that isn't feasible, you can get away with using smaller pieces by gluing them and reinforcing them with the carbon and epoxy method...but you will end up with a heavier plane.
Bombay is offline Find More Posts by Bombay
Old Jan 04, 2010, 08:49 AM
beemerdon is offline
Find More Posts by beemerdon
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
Looks like my next project!
Don
beemerdon is offline Find More Posts by beemerdon
Old Jan 04, 2010, 05:35 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
This plane can be built with a 39x27.5 sheet, and a 39x13 sheet. I cut the main body out in two sections, with a "V" cut from the wing break back towards the motor mount.
I have flown my 100% with both 1350 and 2200 lipos. Performance is about the same with both, but a little more duration on the 2200.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 04, 2010, 06:30 PM
06flex is offline
Find More Posts by 06flex
Joined Jan 2009
I have the 100% and the 130% version of this plane and they both fly great. I keep hearing about the 66% version. This sounds great for one that I can keep in my jeep. I have searched the thread but can not find a tiled pdf for it. Does it exist? If not could someone post it please. I have not figured out how to resize the orginal pdfs yet.
06flex is offline Find More Posts by 06flex
Old Jan 04, 2010, 06:32 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
06flex:
Can you point me to the 130% version? Would that be a 36" wingspan?
Rob
Old Jan 04, 2010, 10:49 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
See post 1404 for a link to a build thread with plans for a 66% plane.
Pat
Old Jan 05, 2010, 05:13 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
1300 or 2200 ?
You do less damage when you crash with a 1300 compared to a 2200.
Old Jan 05, 2010, 12:23 PM
Blueangels4 is offline
Find More Posts by Blueangels4
orlando FL
Joined Aug 2005
well my F-22 is finally dun!,.. I used the christmas break to finish it,.. All I have to do is paint it,.. the AUW is 15.6oz,.. and I fired it up in the garage and man whatta ton o' thrust I am making a few revisions to the tailerons and how they are connected to the body,..but yeah otherwise,.. just waiting for it NOT to freeze here anymore for the maiden!
i am usin' a 1350 lipo
Blueangels4 is offline Find More Posts by Blueangels4
Old Jan 06, 2010, 06:52 PM
Glider-man is offline
Find More Posts by Glider-man
RC SAPRANOS
Glider-man's Avatar
At the field in 10...
Joined Jun 2008
Good luck for the maiden!
Glider-man is offline Find More Posts by Glider-man
Old Jan 06, 2010, 07:02 PM
RC SAPRANOS
Glider-man's Avatar
Joined Jun 2008
Now a question to toss out there... have any of you got your raptors to hover, the guys with ailerons probably have - My raptor hovers like a 2m long IMAC plane, with spoilers on.
I want to know if hovering or high alpha is something raptors are unusually good at, or do most deltas possess this ability?
Old Jan 06, 2010, 08:43 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
High alpha, definitely. Hovering, not usually...not to my knowledge. Let's see some vid.
Old Jan 06, 2010, 08:46 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Mine does a great extreme high alpha, but I've never been able to hang it. If I get it pointed straight up, it usually winds up flipping over on itself in about .5 seconds.
My F-16XL can just about hover straight up though.
Pat
Old Jan 06, 2010, 09:30 PM
RC SAPRANOS
Glider-man's Avatar
Joined Jun 2008
Maybe not a 'complete standing still' hover but I defiantly have had it almost 90 degrees for a few seconds, yeah high alpha seems to come stock in the F-22 package!
... I thought about having a delta that does jet-plane manoeuvres at the same level of 3D planes, capable of extremely low speeds - possibly leading to a Cobra! (the holy grail)
I may just have to get a vid, I'm in the process of re-covering the plane though, so maybe next month.
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
