Old Dec 04, 2008, 06:23 AM
Park_Flyer is offline
Find More Posts by Park_Flyer
Smarter than a 5th grader.
Park_Flyer's Avatar
United States, VA, Virginia Beach
Joined Jun 2005
Originally Posted by unloco2
Got a question, when we talk about down thrust on a midwing pusher, what do we mean? Is it the same as on a standard motor and prop on the nose, or does pointing the motor thrust line down force the plane nose to go up? Totally confused.
I would have to say that down thrust means the same regardless of the motor orientation you're mounting the motor, so that the thrust line points downward. This would be true for an aft-mounted pusher as well.
That said, adding down thrust to a mid-mounted pusher like this one seems kind of pointless. If you think about it, when the thrust hits the flat plate behind the motor, it will be diverted back to essentially a straight line following the top of the flat plate. For this aircraft, you should mount the motor with straight thrust lines.
Ben
Park_Flyer is offline Find More Posts by Park_Flyer
Old Dec 04, 2008, 10:46 AM
Guppy Driver is offline
Find More Posts by Guppy Driver
I believe in Kool Aid
Guppy Driver's Avatar
Glendale, AZ
Ben
Well...kind of. I inadvertently added some up thrust to my SU-27XXL when I replaced the original motor with a brushless. (Pointing the prop end of a pusher configuration up pitches the nose of the airplane up in flight as more power is applied) It flies fine and it's better than causing the nose to pitch down as the ground is ALWAYS down there somehwere.
You are absolutely right that mid-mounted pusher prop jets should have straight thrust lines.
Guppy Driver is offline Find More Posts by Guppy Driver
Old Dec 11, 2008, 12:39 AM
dvdykc is offline
Find More Posts by dvdykc
Joined Dec 2008
Originally Posted by jdsu
hello guys,
I maidened my f-22 yesterday in little wind (5-7mph). it flew beautifully.
this is my first scratch build foamie and first with elevon setup.
cg was right on spot as mehtioned in this thread before.
radio was little glitchy.
I had setup for very low rates so roll was slow.
will increate aileron little more and it will be lots of fun.
spec: triple stator park jet motor. APC 7x5ep , 35amp esc. 2 HS55 servo.
3s A123 cells from VXP battery (b&d) 1100mAh. it lasts about 8-9 mins and charges fast under 15mins at 4C.
overall weight about 16oz.. (battery alone is 5 oz.)
Hi there,
I have the same thing as your but have problem with the propeller. I also have the APC 7x5ep but the air flow was in different direct. How do you solve this?
I need the airflow in red arrow?
please help thank you
Regards
dvdykc
dvdykc is offline Find More Posts by dvdykc
Old Dec 11, 2008, 01:09 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Originally Posted by dvdykc
Hi there,
Regards
dvdykc
Just switch any 2 of the three wires between the ESC and the motor and the motor will spin the other way. Make sure the prop is installed in the right direction, i.e. with the small numbers denoting the prop size facing the front of the plane.
chewy
chewytm is offline Find More Posts by chewytm
Old Dec 18, 2008, 08:19 AM
sketchanderase is offline
Find More Posts by sketchanderase
new pic, same plane....
sketchanderase's Avatar
Dayton MN
you dont really need ailerons or rudder for this plane, i built one from these plans with a 20 inch ws 28 inch length and it flies really great with just the elevons.......
sketchanderase is offline Find More Posts by sketchanderase
Old Dec 18, 2008, 08:20 AM
Dayton MN
what paint is it on the one posted a few pages back?
Old Dec 18, 2008, 05:53 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
You're right, ailerons and rudder are not required. But I do recommend adding ailerons for the "fun" factor. And avoid rudder at all. Not needed and just adds weight and expense.
Which plane are you asking about on the paint? Which post #? If you mean post 743, it was done with Testors spray paint. Color 1930 for the light grey, 1992 for the dark grey.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Dec 18, 2008, 06:15 PM
Dayton MN
probably that post. I have a testors all purpose enamel spray paint in "dark aircraft Grey" would that be pretty much the right look?
Old Dec 18, 2008, 06:58 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Should be good. I posted the numbers of my paints. I've found those two colors just about right for the two-tone grey paint jobs.
Pat
Old Dec 18, 2008, 07:01 PM
Dayton MN
they llook awesome on that plane! it might not look as good on mine because mine is out of blu cor not depron but...........should still look pretty good, i like the blue color with the painters tape cockpit that we added to balance it better and make it look better.....
Old Dec 19, 2008, 07:23 AM
superinstaller is offline
Find More Posts by superinstaller
superinstaller's Avatar
United States, SC, Greer
Joined May 2006
Ailerons are the way to go , especially if you like slow speed control as well as nice rolls. This bird just flies way better with them! Also increased wingspan 3in and .5 to the back or the tails makes for a stronger hinge
superinstaller is offline Find More Posts by superinstaller
Old Dec 19, 2008, 04:11 PM
Cid156 is online now
Find More Posts by Cid156
Switzerland
Joined Sep 2008
Hello,
I want to built this model. But I want to use the motors, the prop and the ESC that I have in stock:
I have those motors:
http://www.hobbycity.com/hobbycity/s...idProduct=5353
http://www.hobbycity.com/hobbycity/s...idProduct=5482
http://www.hobbycity.com/hobbycity/s...idProduct=2069
I have a 18A ESC
And prop 8x4, 6x4, 4.5x4, 7x35, 7x5, 7x6.
And lipo 3s1000mah 25C and 2s1000mah 25c
Do you think that it is possible to use one of them ?
REgards
Cid156 is online now Find More Posts by Cid156
Old Dec 19, 2008, 06:58 PM
Joined May 2006
the top one would fly it. If you want cheap verticle climb power use this:
http://www.bphobbies.com/view.asp?id...7&pid=B2632603
Have two of these there awsome!
Old Dec 19, 2008, 08:16 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
I would say the top one with a 6x4 prop.
Originally Posted by Cid156
Hello,
I have a 18A ESC
REgards
jetcaptain is offline Find More Posts by jetcaptain
Old Dec 19, 2008, 09:31 PM
uniquexme is offline
Find More Posts by uniquexme
hobby-asia.com
uniquexme's Avatar
Malaysia
Joined Apr 2006
u mean that emax 2805 with 6x4? i assume that u use 2S rite? but i flew it on my zagi, i seems lack of power.
uniquexme is offline Find More Posts by uniquexme
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 01:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 05:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 10:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 02:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 09:39 PM
