Old Aug 13, 2008, 02:46 PM
Kangaman is offline
Find More Posts by Kangaman
Kangaman's Avatar
North Hollywood
Joined Jun 2006
Love it.
CG is 3.5 inches - correct
Paul
Kangaman is offline Find More Posts by Kangaman
Old Aug 13, 2008, 02:57 PM
Park_Flyer is offline
Find More Posts by Park_Flyer
Very, very, very hugely smart.
Park_Flyer's Avatar
United States, VA, Virginia Beach
Joined Jun 2005
Originally Posted by Kangaman
Anything I need to know before launch?
Give it a tiny bit pitch up trim, just in case the CG is a bit forward. If you have dual rates, set it up for around 60% for the launch, then turn it off once flying. A couple of times it porpoised a lot after launch - really twitchy.
I launch mine underhanded, grasping it between the "canopy" and CG, and tossing it slightly nose high, though you may want to see how Tomas launched his in his video above.
I have really high, 3D-like throw rates, with high expo set on channels 1 and 2, so I can fly it smoothly when I'm not doing tail slide loops, cobras, and tail stands - it is very responsive. You're going to love this airplane.
Ben
Park_Flyer is offline Find More Posts by Park_Flyer
Old Aug 13, 2008, 03:52 PM
tomhe is offline
Find More Posts by tomhe
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Here's a safe way to launch these kinds of planes:
Safe way to launch a pusher jet
tomhe is offline Find More Posts by tomhe
Old Aug 13, 2008, 03:53 PM
adamdb is offline
Find More Posts by adamdb
United States, CO, Denver
Originally Posted by frednjess
Then you can try to figure out how to wipe that stupid grin off your face.
That is the most difficult part of flying this plane for me!
I also usually launch mine with a click of up trim.
I think the cool thing about the thrust vectoring is that you instantly have control of plane. Normal parkjets with the motor on the back have to attain a little speed before the controls start working.
Adam
adamdb is offline Find More Posts by adamdb
Old Aug 15, 2008, 04:55 AM
Telectroboy is offline
Find More Posts by Telectroboy
Joined Mar 2008
Hello,
I've some videos on youtube.
Check this one...
F22 TOMHE depron rattrapé main (1 min 2 sec)
Telectroboy is offline Find More Posts by Telectroboy
Old Aug 15, 2008, 07:15 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Nice video Telectroboy
chewy
chewytm is offline Find More Posts by chewytm
Old Aug 15, 2008, 04:40 PM
Kangaman is offline
Kangaman's Avatar
North Hollywood
Joined Jun 2006
Successful maiden - - F22 now has 5 flights on her.
Not as fast as I had expected - using a APC 6x4 - - tried a 7x4 - amps were too high (22) and it did not seem that much quicker.
She sure does float nice when landing.
Paul
Old Aug 15, 2008, 04:47 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
If you want more speed you need to go to a smaller prop not bigger. bigger will give you more vertical not speed. Try a 5 X 5
clive45 is offline Find More Posts by clive45
Old Aug 15, 2008, 04:51 PM
Kangaman is offline
Kangaman's Avatar
North Hollywood
Joined Jun 2006
really - - can you explain Why?
Paul
Old Aug 15, 2008, 04:57 PM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Smaller prop revs quicker therefore more airspeed, bigger prop pushes more air but at slower speed, so the bigger prop is better for 3D and vertical pull/hover.
EDF's runn very high revs and small props to get good airspeed
Old Aug 15, 2008, 05:00 PM
Kangaman is offline
Kangaman's Avatar
North Hollywood
Joined Jun 2006
Thanks Clive - I have a 5x5 so I'll try that next time.
Paul
Old Aug 15, 2008, 05:30 PM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Thats cool, hope it does what you want. Lets us know how it goes
Old Aug 16, 2008, 11:57 AM
Joined Mar 2008
I use a 7x6 prop with a 1500kv motor.
It's quite good between torque and speed.
Old Aug 17, 2008, 03:05 PM
Kangaman is offline
Kangaman's Avatar
North Hollywood
Joined Jun 2006
Ok - OK I am a dufas...!!!
This was my first time using a pusher setup.
Guess what - - I had the propeller facing the wrong way.
Now that all is correct - this girl boogies - - Love it.
Paul
Old Aug 17, 2008, 04:43 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
"Numbers face forwards", works for all applications both tractor and pusher.
Glad you got it sorted. And yes, these planes do boogy.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
