Old Aug 06, 2008, 06:26 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Hey guys-
Just started throwin' an F-22 together.. I haven't dealt with depron too much, just curious as what you guys are painting these things with?
Thanks!
Jeff
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Aug 06, 2008, 07:02 PM
Park_Flyer is offline
Find More Posts by Park_Flyer
Very, very, very hugely smart.
Park_Flyer's Avatar
United States, VA, Virginia Beach
Joined Jun 2005
Originally Posted by Tram
Hey guys-
Thanks!
Jeff
I asked for and received an airbrush for Christmas. I use airbrush paints, which though water-based acrylics, are more permanent than typical craft-type acrylics. I'm no expert at it, but it works well enough for what I do - military-type camo. I coat the plane with aerosol WBPU after painting.
Ben
Park_Flyer is offline Find More Posts by Park_Flyer
Old Aug 06, 2008, 08:03 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Hey guys-
Thanks!
Jeff
Jeff,
For a quick and fairly nice paint job (from about 4 feet) get some acrylic craft paint and thin it with windshield washer fluid. Get a good soft paint brush and paint away. If you are a little more pickier, use the same method but spray it on with a airbrush.
jetcaptain is offline Find More Posts by jetcaptain
Old Aug 06, 2008, 09:50 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
I pre paint my foamies with a coat of PVA glue and talc powder+water. Sand to smooth finish. Then light coat with water based floor varnish. Spray with Acrylic paint followed by a final thin coat of water based floor varnish. Gives good finish and protects the foam well.
Depending on how many coats and sanding you do as to how good the finish will be. As usual the finish is in the preparation.
clive45 is offline Find More Posts by clive45
Old Aug 07, 2008, 03:08 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Just curious what kinda weights everyone is getting with the bare airframe?
I am at 4.7oz..
Planning on using HXT900's, Berg 4L and some 1500 or 2100's 3S packs.. Still looking for a motor..
Old Aug 07, 2008, 03:51 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Tram, that sounds pretty light. I think my AUW is in the 10-12oz range with a Loong 1300 3s battery and a LS Super Park Jet motor.
rmgmag is offline Find More Posts by rmgmag
Old Aug 07, 2008, 03:55 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
rmgmag - How do you like the performance on your setup?
A buddy just reminded me of the LS SPJS I have.. Thinkin' about using it..
Old Aug 08, 2008, 07:40 AM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I like it a lot. No problems at all. Floats around nicely at low speeds and moves pretty quick at higher throttle settings. I only have an 18 amp esc (battery stays cool), so I think it's cutting down my top speed. One of these days I'm going to try a 25 amp esc to see what happens....
Old Aug 08, 2008, 11:14 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Sounds like I'll have to give it a shot.. What prop are you running?
Old Aug 08, 2008, 01:17 PM
Park_Flyer's Avatar
Joined Jun 2005
I'm pretty sure that an esc will not affect your top speed, unless it is cutting out at full throttle. That said, if you're using a 6" prop, then you're likely not getting as much as you can out of the LSSPJ. I'm running one on another park jet with the recommended 7x5 APC. It pulls just shy of 19 amps and really kicks.
I may swap it out sometime. I'd like to see what it does on this jet as a way of comparing its performance to the 2212-6 park jet motor.
Ben
Old Aug 08, 2008, 01:25 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Ben-
J
Old Aug 08, 2008, 05:12 PM
Park_Flyer's Avatar
Joined Jun 2005
Ben-
J
I'm running a LSSPJ on another park jet with the recommended 7x5 APC.
On my F-22 I'm using the 2212-6 with an APC 6x4.
Ben
Old Aug 08, 2008, 06:53 PM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I'm running a 7x5 but it seems like it maxes out on the rpm end at about 3/4's throttle, that's why I'm thinking that the ESC is kicking in. I don't have a watt meter, so I really don't know how many amps it's pulling.
Bob
Old Aug 13, 2008, 02:08 PM
Kangaman is offline
Find More Posts by Kangaman
Kangaman's Avatar
North Hollywood
Joined Jun 2006
F22
Just finished mine. it is my second from plans build.
Used blue core
2 x HS 55
Motor 28 - 26 1900kv from hobby city - pushing 200 watts at 17 amps (static)
2100 15c 3cell common scense lipo - pushed way forward
AR 6100 rx
dynam 25amp esc
6x4 apc
weight 18.1oz
maiden hopefully this weekend.
Anything I need to know before launch?
Paul
Kangaman is offline Find More Posts by Kangaman
Old Aug 13, 2008, 02:38 PM
frednjess is offline
Find More Posts by frednjess
That Guy Who Flies Wings.
La Vista, Nebraska
Joined Mar 2007
Good looking plane Kangaman. Make sure you've got the CG correct, advance the throttle to 3/4 and let her fly. Then you can try to figure out how to wipe that stupid grin off your face.
frednjess is offline Find More Posts by frednjess
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
