Old Aug 10, 2007, 03:49 PM
RCSuperPowers is offline
Find More Posts by RCSuperPowers
Just one more flight...
RCSuperPowers's Avatar
United States, OR, Portland
Joined Sep 2005
Very sharp and clean! Thats going to go real nice in the air!
RCSuperPowers is offline Find More Posts by RCSuperPowers
Old Aug 10, 2007, 05:43 PM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Nice cutting job !!!!
I don't quite understand what you mean about the bottom and side parts.
Bill Bergman is offline Find More Posts by Bill Bergman
Old Aug 10, 2007, 05:50 PM
tomhe is offline
Find More Posts by tomhe
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
I'm speaking of the gap that is shown here. The bottom of the fuselage is 6 mm below the nose part of the profile.
tomhe is offline Find More Posts by tomhe
Old Aug 10, 2007, 05:58 PM
Houston, Tx.
Joined Jan 2003
Thanks. Did you cut your slots at an angle?
Old Aug 10, 2007, 06:32 PM
Houston, Tx.
Joined Jan 2003
Bowing the deck didin't work very well so I cut wedges out of the tabs and bent the tabs over to match the side/deck angle.
Old Aug 10, 2007, 06:52 PM
randynsaudi is offline
Find More Posts by randynsaudi
randynsaudi's Avatar
United States, LA, Blanchard
Joined Jan 2006
while i wait for the UPS truck with my depron order. i had some Dow 1/2 foam laying around so i cut out a scaled up version. going tp cut one out with the plans when the foam gets here.
Wingspan 40 inches
Length 56 inches
Weight with parts cut now have about 4 more parts and a lot of sanding 11 5/8 oz
Now to get a little carbon in her..
randynsaudi is offline Find More Posts by randynsaudi
Old Aug 10, 2007, 09:20 PM
savall21 is offline
Find More Posts by savall21
Go Sabres!
savall21's Avatar
Laurel, MD
Joined Aug 2004
Wingspan 40 inches
Length 56 inches
Let me know how yours works out. I built mine with a 36" wingspan and it will barely roll. Pitch response is ok but the lack of roll made mine unmanagable. I used a 7 inch prop and I didn't see any torque roll effects. My thought is the wingspan may be to large to be rolled by tailerons???
I was thinking of adding ailerons.
Any input is appreciated.
savall21 is offline Find More Posts by savall21
Old Aug 10, 2007, 10:08 PM
Joined Jan 2006
I may set it up like my Hobby Lobby Sukhoi SU-27 XXL with both ailerons and tailerons only way to go other than a servo for the elevators and two for the ailerons. the SU-27 XXL flys very well on it's set up, still have'nt really made up my mind the way i'm going to go. but it's going to be awhile as i work in Saudi Arabia 35 days on/ 35 days off and i leave out the first of the week, so there is 5 weeks before i can get back after it. i hope to get all the parts cut and fitted before i leave.
Old Aug 10, 2007, 11:13 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Yes, and I also cut the side panels at an angle. It worked well.
Old Aug 10, 2007, 11:17 PM
Houston, Tx.
Joined Jan 2003
Mine turned out OK but I wish I had cut them at angles.
Tomhe, is the an advantage to tailerons or would you be better off with elevator, ailerons and rudder?
Old Aug 10, 2007, 11:21 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
If the roll rate is too slow you can try adding ailerons as I mentioned in post #8.
Old Aug 10, 2007, 11:25 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Well, the obvious advantage with only tailerons is that it is so simple to setup. That's why I'm starting out that way. The YardBird F-22 seems to do well with only tailerons.
Old Aug 10, 2007, 11:32 PM
Houston, Tx.
Joined Jan 2003
I'm just guessing, but it seems that at slow speeds (specially when launching) that taileron with the mid-motor design would give you better roll control due to the prop wash over the tail control surfaces?
Old Aug 10, 2007, 11:44 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
That's what I'm hoping for. We'll have to wait and see.
Old Aug 10, 2007, 11:46 PM
Houston, Tx.
Joined Jan 2003
Does linking ailerons with tailerons have an adverse effect to elevator control?
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
