Espritmodel.com Heli Air
Old Jul 07, 2008, 02:43 AM
slumberjer's Avatar
Changloon, Kedah, Malaysia
Joined Dec 2006
This is my F22 Cororaptor. Instead of depron..I choose coroplast as my building material. It's twice the weight from depron F22. Mine AUW is ~20oz.
Power plant setup APEX 2500kv with 5' prop, ESC 30A, Lipo 2200 3s1p 20C lipo. tested on the ground with just half throttle it can hover.
Will maiden this friday.
Is it enough with just elevon setup for this F22?
More details here
slumberjer is offline Find More Posts by slumberjer
Old Jul 07, 2008, 03:19 AM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Opinions differ. Shadegrown's model with only tailerons flies fine:
Profile F-22 with simple thrust vectoring (4 min 50 sec)
tomhe is offline Find More Posts by tomhe
Old Jul 09, 2008, 04:30 AM
Tampere, Finland
Joined Sep 2007
Tailerons only -setup provides good control even in low speeds, but if you want faster roll rate, you may want to add the ailerons as well. Some say that rudders help in high alpha maneuvering, but I have no problems controlling the plane in high AOA flight with tailerons only. Inverted flight high alpha is also possible!
Shadegrown is offline Find More Posts by Shadegrown
Old Jul 09, 2008, 09:43 AM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
yesterday i went to build this plane, and i was suprised to see that the plans were deleted no plane for me
ihor14448 is offline Find More Posts by ihor14448
Old Jul 09, 2008, 10:15 AM
American since 1947
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
You just have to dig a little deeper into tomhe' pages.
http://rc.tomhe.net/local--files/f-22/f-22-r2-print.pdf
birdofplay is online now Find More Posts by birdofplay
Old Jul 09, 2008, 11:11 AM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
thanks!
Old Jul 09, 2008, 11:50 AM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
That's correct. There is a link from post #1 to the F-22 page on my site, where plans in different formats can be downloaded.
Old Jul 09, 2008, 12:00 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
oh, i remember you had PDF attachments under the pics, sorry, my bad, i thought you removed them because companies are selling those kits
Old Jul 09, 2008, 12:36 PM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
No, I just moved them to my site.
Old Jul 11, 2008, 02:55 PM
C. George's Avatar
Anchorage AK
Joined Jun 2008
Thanks tomhe
I just maidened my plane for the first time! I put in a little up trim on lauch so I would not have to worry about the ground right off and the plane lifted into a very slow harrier and hung there until I got all settled and started trimming it out. A fella stopped his pickup and walked up to me while I was getting this bird trimmed and just started talking a mile a minute. A bit distracting but managed to talk and fly at the same time.
The plane looks great in the air and does things just like the real bird. Pull into high alpha and float around. Then just drop the nose and she starts accerllerating on her own. My build is very heavy (15.6 oz AUW) as I used hot glue for eveything including the spar. Only issue was that top speed was dissapointing. I went home and changed the 25 amp Speed Controler to the 30 amp that came with the Grayson Parkjet combo. Second flight she had very good vertical performance. As this is my very first flat foam build I did not know what to expect. I am very happy. Thanks Tomhe!!!
C. George is offline Find More Posts by C. George
Old Jul 11, 2008, 03:46 PM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
You're welcome. Now you have to show us pictures of your bird...
Old Jul 12, 2008, 05:11 PM
RacerX208's Avatar
Joined Apr 2004
I know this may have been mentioned some where before, but what is actually supposed to be the approximate angle, from the wing to the rudder? I have read the build doc about just "following the angle of the intakes" but since I've played with the tabs and have trimmed them a bit, I just want to make sure I've got them set up right. Using a protractor, and lining mine up with the intakes, the angle right now comes out to about 70 degrees....thanks in advance....
RacerX208 is offline Find More Posts by RacerX208
Old Jul 12, 2008, 07:03 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I've never measured mine. I just use the TLAR method.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old Jul 13, 2008, 01:18 AM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
I haven't measured the angle, but you can measure from this picture.
Old Jul 13, 2008, 09:58 AM
American since 1947
birdofplay's Avatar
Joined Dec 2005
Used CAD to measure that angle ...
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
