Old Jun 27, 2008, 04:30 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by capt
Very nice decals, where did you find them?
Jason Edgar has come up with some great decal sets that are available for download from 6mmFlyRC. See here. These can be scaled down to fit tomhe's birds as well.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Jun 27, 2008, 11:33 PM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
Yep the decals were from 6mmflyrc.
Well I got to test fly this morning with ailerons. Much much better
nac is offline Find More Posts by nac
Old Jun 28, 2008, 12:15 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Cool, Thanks for the info.
capt is offline Find More Posts by capt
Old Jun 30, 2008, 08:31 AM
morgantwin11 is offline
Find More Posts by morgantwin11
Joined Mar 2007
Originally Posted by rick88ss
Which motor will give better performance on the F22 (faster)?
Towerpro 2409-12T or Grayson 2212-06?
What's the fastest anybody has flown this plane without it breaking apart?
Im flying the F-22 with the Grayson 2212-06 and it has rediculous power! Im guessing its goes about 55-60 mph. The only way I can safely go full throttle is straight up. Im using 20oz torque 9 gram Hextronic servos from Hobby City on my tailerons, and these do not have the power for the big tail surfaces! I was running a 5.5 x 4.5 prop and switched to a 6x4. Wow verticle greatly improved with virtually no speed difference! It seems that these flat plate foamies have an tremendous amount of drag, and take alot of power to go very fast. I would say go with the Grayson for speed, and if verticle is you goal, either motor with blast it out of site!! I would like to build one for speed sometime, you def need to make the tailerons smaller and remove the thrust vectoring tabs, in my opinion. You can easily develope tail surface flutter at full throttle!! These Tomhe designs are great!! Good luck with your F-22.
MorganTwin11
morgantwin11 is offline Find More Posts by morgantwin11
Old Jun 30, 2008, 09:03 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
MT,
I use a Grayson with a 6X5.5 prop. My F-18 has true unlimited vertical with that, even with a heavy 2200 lipo on board!
How are you hinging your control surfaces? If you're using tape, are you taping both sides (top and bottom)? That should keep the surfaces from fluttering. At least, I've never had flutter on any of mine, and the F-18 simply screams.
Pat
Old Jun 30, 2008, 10:57 AM
Joined Mar 2007
crxmanpat,
Im actually using ca cloth hinges for all the control surfaces. I dont really trust hinge tape at these speeds. To be honest, I have not experienced flutter yet, but I do not have enough servo power; the plane hardly responds at full throttle straight and level, and Im afraid I would quickly induce flutter if I dont pull back the throttle. What kind of amps are you pulling with your 6x5.5 prop? My 6x4 is really heating up my motor and speed control.
Old Jun 30, 2008, 05:34 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I'll have to check the amp draw. I'm also at 1800' ASL, so that has a bearing on performance, as well as the extremely low humidity levels we have.
And I have no issues with control response at WOT. I use very tacky packing tape (the 2" wide variety) on the top hinge, and 3M sctoch tape underneath. Works well.
Pat
Old Jul 01, 2008, 04:36 PM
HSV_Freak is offline
Find More Posts by HSV_Freak
Joined Jun 2008
Here my F22 hes not complete, electics comes in few days.
Nice work and nice plan. Very cool design.
HSV_Freak is offline Find More Posts by HSV_Freak
Old Jul 01, 2008, 04:42 PM
ihor14448 is offline
Find More Posts by ihor14448
ihor14448's Avatar
Strongsville, OH
Joined May 2007
hey guys, what motor should be used on this baby? high or low kv?
ihor14448 is offline Find More Posts by ihor14448
Old Jul 01, 2008, 04:51 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
You want something that will turn a smaller prop at a higher RPM. Stay away from anything in the 900-1000Kv range. Best to go with something in the 2000-3000Kv range.
But it all depends on what type of performance you're looking for. I flew my original F-22 and Mig-29 on a Scorpion 2205-32 (1950Kv) with a 7X5 prop and they flew fine, but not all that fast. I then bumped up to a Grayson Park Jet 2212-06 motor (2200Kv) on a 6X5.5 prop and they are nice and fast.
Pat
Old Jul 01, 2008, 05:33 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
i dont want fast, but i want manuverable, and quick turning, if i build the ful 100% version what prop will i have to use?
i have this cheapo motor lying around
http://www.hobbycity.com/hobbycity/s...less_Outrunner
its 1400kv, will it work?
i mostly fly 3d and all of my motors are around 1000kv range
Old Jul 01, 2008, 06:26 PM
rick88ss is offline
Find More Posts by rick88ss
Miami,FL
Joined Jun 2007
That motor is way too small if you ask me. Maybe if you scale down the plans it might work.
rick88ss is offline Find More Posts by rick88ss
ihor14448's Avatar
Strongsville, OH
Joined May 2007
how much should i scale down?
Old Jul 02, 2008, 01:16 PM
toughitaliankid is offline
Find More Posts by toughitaliankid
Joined Feb 2007
I took my 2212-6 turning a 6x4 out and remounted a 2217-6 turning a 8x4. Dropped to a lower kv motor and bigger prop, but raw thrust is much greater. Acceleration is better, top speed is the same.
toughitaliankid is offline Find More Posts by toughitaliankid
Old Jul 02, 2008, 01:37 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
How did you get it to fit? I could barely get a 7" prop in there (had to cut the prop canyon almost to the verticals). Try a 6X5 or 6X5.5 on that 2212-6 motor. I love it.
Pat
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
