Old Aug 09, 2007, 04:06 PM
randynsaudi is offline
Find More Posts by randynsaudi
randynsaudi's Avatar
United States, LA, Blanchard
Joined Jan 2006
printed out the full sheet and saw how wide the lines are,, do we need to cut in the middle or inside or outside the the lines
randynsaudi is offline Find More Posts by randynsaudi
Old Aug 09, 2007, 04:32 PM
tomhe is offline
Find More Posts by tomhe
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Theoretically you should cut in the middle, but it all depends on how you transfer the plans to the depron. I recommend that you measure the slots. When cut right, they should be exactly 6 mm (0.236 inches) wide, in order to fit the matching notches.
tomhe is offline Find More Posts by tomhe
Old Aug 09, 2007, 05:23 PM
Joined Jan 2006
it maybe because the PDF is 51.86 X 41.44 and my plotter will only do 32 inches wide....
Old Aug 09, 2007, 05:33 PM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
I re-opened the pdf in Illistrator and set the line weight to .5, cropped the canvas to 36"x42" and re-saved it as pdf. Now the lines are razor thin.
Bill Bergman is offline Find More Posts by Bill Bergman
Old Aug 09, 2007, 06:19 PM
Joined Jan 2006
would you post the updated PDF??.. thanks.. is the wingspan the same?
Old Aug 09, 2007, 06:37 PM
MartinL is offline
Find More Posts by MartinL
Australia
Joined Oct 2000
Originally Posted by Bill Bergman
Looks great Martin. Are you using the thrust vector elevons? Can't tell in the picture.
Yes..linkages at the bottom.
MartinL is offline Find More Posts by MartinL
Old Aug 09, 2007, 10:00 PM
Houston, Tx.
Joined Jan 2003
"Yes..linkages at the bottom."
ah ha the camo works
Randy, I'll post it tomorrow from work.
Got the slots cut.....should have cut the fuselage slots at an angle.
Old Aug 09, 2007, 10:14 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
I'm cutting today. I think I'll try to cut the slots in the wing at an angle. Nice build by the way!
Old Aug 09, 2007, 10:15 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Hey Bill,
That is NICE did u cut that by hand? and is that the full size version
G-unit is offline Find More Posts by G-unit
Old Aug 09, 2007, 10:32 PM
Houston, Tx.
Joined Jan 2003
Actually this may be interesting. By bowing the deck it turns the slots in at an angle. This also give the profile a little more realistic look. I might try heat treating the deck to make a permanent bow.
G-unit, yes cut by hand and straight edge and it's full size. I'm gonna use rudders also.
Old Aug 09, 2007, 11:18 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Bill, do you think that cutting the slots straight might be a good thing, or should I try to cut them at an angle?
Old Aug 10, 2007, 02:19 AM
golem is offline
Find More Posts by golem
golem's Avatar
Maryland, USA
Joined Mar 2006
I'd like to thank you fellas for the replies regarding prop size and resulting handling characteristics. Torque was one effect I had not thought about but probably is a greater factor with these narrower wing spans.
Cheers,
golem
golem is offline Find More Posts by golem
Old Aug 10, 2007, 07:10 AM
Houston, Tx.
Joined Jan 2003
Tomhe,
I won't know till tonight when I get a chance to heat warp the deck. It might also add a slight undercamber to the center area of the wing.
Old Aug 10, 2007, 02:18 PM
Houston, Tx.
Joined Jan 2003
Oops, I all most forgot to post the line fix pdf...
Old Aug 10, 2007, 03:38 PM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
I've completed cutting the parts and test fitted them. I see now that I placed the bottom 6 mm below the side profile. It should have been in line with the side profile.
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
