Latest blog entry: Nico Hobbies
Nice job!
I have more fun flying mine in the wind. ![]() Pat |
Nothing new for now, still working on getting ready for the AMA Convention.
![]() Pat |
Joined Aug 2012
Wondering if anybody has any ideas for mods to these (excellent) single prop vectored thrust aircraft to reduce the torque reaction?
I have a whale of a time with my Mig-29 (from the other thread) but find that with Tailerons only, run out of right aileron when trying to go very very slow. I see that with a twin prop model with no torque reaction it is possible to slow to a hover......I can't see how you would be able to do that with a single prop? I am doing a mod at the moment to put some angled vertical strakes on the upper and lower part of the fuselage with the aim of reducing the torque roll....see how it goes! |
On these models, there is almost no torque factor. Failure to turn is typically caused by one of two things:
1. CG too far fore or aft. 2. Too little airflow over the control surface. #1 can be solved by correcting the CG. #2 can be solved by adding power. ![]() I have had mine in a high alpha near-hover, applied full right aileron, and it still tracks to the left. While I'm sure torque plays a small part in this, there's really not much you can do about it, except to make it a twin with counter-rotating props. Pat |
Joined Aug 2012
Interesting. Aircraft is nicely trimmed straight and level at all power settings, slow down and I have to feed in more and more right stick. In fact, that is the limiting factor to how much I can slow up.
Got plenty of control throw and plenty of power - about 400w on a 6x4 and tailerons to drawing. CRX, I wasn't sure why you say there is virtually no torque factor, but go on to describe the same flight characteristics that I am getting. Surely torque reaction is the only factor that could cause this isn't it, or maybe it's my understanding of the terminology. I recently flew a VF F-15 that I put together for a friend and it does exactly the same. |
The closer the prop is to the CG of the plane, the smaller the torque affect is. Just look at the difference between a mid mounted motor and a tail mounted. Or any plane with a very powerful motor on the nose.
I can launch my F-22 at full throttle, with a slight toss at 45°, and it will fly straight away without any turn to the left. But I can't do that with any of my tail mounted pusher jets. Those I have to give a big shove and be ready for some right aileron until it gets up to speed. I'm not saying there's no torque in mid mounted motor planes, but it is way less at slow speeds than others. Now, I once had an F-15 that would not turn right to save its life, even with some speed on, and even though it seemed well trimmed and balanced. If I tried to turn right it would kind of knife edge until I was forced to turn left. Moved the CG further forward and the issue completely disappeared. Pat |
Joined Aug 2012
That is interesting. I think I have a theory.
In any aircraft the torque reacted back through the airframe is equal to the amount of torque needed to drive the prop. So that won't change for any motor configuration. However, for a mid-mounted motor there is the aft fuselage which is present (and isn't for a forward or rear mounted engine). The effect of this is to react the rotating component of the propwash (i.e. kill/disrupt the swirl effect) and if you think about it, the effect on the airframe opposes the effect of the motor torque. I can't imagine why the relationship with the C of G is a factor, but I am convinced that the flow straightening effect of the aft fuselage section must significantly reduce the reaction torque from the motor. Sound feasible? |
I made a simple 18" WS EPP profile version with a hextronik 3000kv. First flight had bad torque to the left on full power. Bench test showed the whole frame was twisting from motor torque. A depron stiffiner plate across the bottom took most of the torque out. Flys sweet now. Any chance your airframe is twisting?
| Thread Tools | |
| Video f-22 with average pilot | leadfeather | Electric Plane Talk | 1 | Apr 24, 2008 12:49 AM |
| Video RCSuperPowers F-22 with Vectoring Thrust | RCSuperPowers | Electric Plane Talk | 25 | Feb 18, 2008 04:00 PM |
| Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) | meteor | Electric Ducted Fan Jet Talk | 30 | Feb 09, 2005 09:57 AM |
| Wattage F-22 with ducted fan | The Blue Max | Electric Ducted Fan Jet Talk | 11 | May 10, 2003 01:13 PM |
| f-22 with jeti brushless | ivorz | Foamies (Kits) | 14 | Oct 01, 2002 08:39 PM |
