Old Dec 23, 2012, 07:45 AM
gatorb8 is offline
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
Originally Posted by crxmanpat View Post
Save yourself some time and trouble and build this one instead of the 75%. It's 66%, but the plans are ready to go. Just go to my first post (Post 10) to find the current plans.
http://www.rcgroups.com/forums/showthread.php?t=795691
Pat
thanks!
any chance you have it in a dxf file?
gatorb8 is offline Find More Posts by gatorb8
Old Dec 23, 2012, 09:41 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I do, but since it is one of the planes I sell, I don't give out the .dxf. Sorry.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Dec 23, 2012, 09:49 AM
Gonzo 1971 is offline
Find More Posts by Gonzo 1971
This is BAT country!
Gonzo 1971's Avatar
United States, MI, Ovid
Joined Nov 2003
How was the MicroDan on there? With Med little motor.
Gonzo 1971 is offline Find More Posts by Gonzo 1971
Old Dec 23, 2012, 10:57 AM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Pat
no worries, I have the orig DXF file, I can scale it easy, was just lazy!
Old Dec 23, 2012, 10:58 AM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
I love the uDan!
Especially when I push it past the limit and Dan can fix it!
Old Dec 23, 2012, 11:00 AM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Quick Build got a Quick Paint this morning!
I figure it is a test platform and may not last long so didn't want to much effort in it. 1 mini can of Krylon short-cut paint
Old Dec 24, 2012, 01:19 PM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
raining today so...............touched it up !
Old Dec 26, 2012, 03:44 PM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
bench tested it today
AUW 17.3 oz, 2505-2900 microDan, MAS 6x4, 2200 mah 3S nanotech, 35 Amps, 11.34 volts, 400 watts
I was gonna try 4S too, but the 3S numbers are scarey enough on 17 oz of flat foam
I have run this setup on a funjet and hit 110 mph, I think this one might evaporate......have to steer energy away from the crowd!
Old Dec 26, 2012, 05:25 PM
beemerdon is offline
Find More Posts by beemerdon
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
Has anyone tried the 2826/6 instead of the 2212/6 motor? The specs. look very similar and I was wondering which one had more power. I seem to have accumulated a couple of the 2826 motors and want to try them in this model. Thanks for any help.
Don
beemerdon is offline Find More Posts by beemerdon
Old Dec 26, 2012, 05:39 PM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Don
2826 looks a little more powerful
try it!
Old Dec 26, 2012, 08:11 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Don,
I have flown both. No appreciable difference between the two motors.
Pat
Old Dec 27, 2012, 06:12 PM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
Got to maiden mine today in full dress!
Really floats with 1800mah 3S
High speed was ok on 3S and not much faster on 4S, I was thinking the airframe had a lot of drag and is perfect on the 3S.
Flew great until a servo locked up and downed it!
F-22 Tomhe design (2 min 45 sec)
Old Dec 27, 2012, 09:02 PM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
after putting new servos in the F-22 I learned something new about my DX8 radio.....My 12FG will limit the throws end point adjustment on the servos when mixed. It appears the DX8 doesn't or I didn't set it up right. On max throws say with full up elevator I was giving the elevons a right turn and the servos go even further and stop at max mechanical throw limiting the servo and thus.....burning out a digital servo.
need to check max throws at the corners of the sticks for binding
Old Dec 27, 2012, 09:54 PM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
https://vimeo.com/56394876
I'll have to take that back about no difference between 3S and 4S due to drag cause tonight I noticed the prop was on backwards!
back to the field tomarrow!
Old Dec 27, 2012, 10:20 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I personally would not even bother using digital servos in this plane. As it's a belly lander it will get it's share of hard landings and unexpected "arrivals" to the ground.
I use good ol cheap HXT900s in all of my full sized pusher jets. Work just fine, and only cost about $3 each.
Pat
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
