Old Aug 13, 2012, 07:51 PM
Gonzo 1971 is offline
Find More Posts by Gonzo 1971
This is BAT country!
Gonzo 1971's Avatar
United States, MI, Ovid
Joined Nov 2003
Thank you! I am not sure of the weight. I was assume a little heavy. I used epoxy mostly then sprayed with Minnwax polyurethane. Then painted with Rustoleum spray bomb. I will have to see about weighing it. This is the easiest plane ever to catch. I can do it pretty consistently. Those loops were pretty low! I would say about 10' up. Almost lost it today. I switched models (DX7) and it did not bind or load the program right. Only had one elevon working. I gave it the wiggle test, must not have been paying attention! I flew in circles and landed in a tree to save it (kinda by choice ) then it fell down unscathed! Whew- Did a re-bind and it was off as usual. Kinda weird, I never had that happen before.
Gonzo 1971 is offline Find More Posts by Gonzo 1971
Old Aug 15, 2012, 03:14 AM
vfrumusa is offline
Find More Posts by vfrumusa
Joined May 2012
Hi all, I'm going to build this fantastic model too, but I'm a little bit confused about the right choice of the power system.
You know, original Steve Shumate's plans consider a motor that is no more in commerce and HK has no the exact parts, so I had to find out something similar.
As far as this is my first experience in build up foamies (I know that I started with a complex model), I would like to have your feedback about my choice:
-D2830-11 1000kv Brushless Motor
-Turnigy dlux 30A SBEC Brushless Speed Controller w/Data Logging (2s~4s)
-Turnigy 1500mAh 3S 20C Lipo Pack
-Master Airscrew propeller 7x4
Looking at your posts now I'm a little bit concerned about the motor and the lipo battery, I guess they're a little bit undersized.
About servos I choose the following:
Hitec HS-82MG Micro Metal Gear Servo (for the thrust vectoring)
Turnigy TG9 9g / 1.6kg / 0.12sec Micro Servo (for all others)
Last but not least: the plans foresee a carbon reinforcement in the wing as usual for foamies. From the drawings it is not clear to me if it is a rod or whatever, I decided to use a carbon fiber 3mm square tube, I guess that this could work.
I'm going to place the order, could you please give me a feedback about and suggestions as well?
vfrumusa is offline Find More Posts by vfrumusa
Old Aug 15, 2012, 07:01 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
1100kV is to low. You probably need something like 2200kV. Otherwise your propeller will be too big to be used in the slot. If you use smaller probsl, then it will not generated enough power.
chewy
chewytm is offline Find More Posts by chewytm
Old Aug 15, 2012, 10:32 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
If you are ordering from HK, get the 2826/6 2200kv outrunner and use it with a 6X4E prop and 30A ESC. This is the same motor sold by RCTimer. And don't get the Turnigy TG9 servos, get the HXT900 instead. And the battery you have chosen would be fine, but I'd look for something that is 25C or better. But 1500mAh is good.
If you are in the US, I have a Suppo 2212-6 2200kv motor and 30A ESC combo, which is basically the same motor at the HK Turnigy. I have the 6X4E props too.
This is the tried and true setup for these pusher jets, and works great!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Aug 15, 2012, 12:48 PM
vfrumusa is offline
Joined May 2012
Thank you crxmanpat for your feedback.
I changed like this:
D2826-6 2200kv Outrunner Motor
Hobby King 40A ESC 4A UBEC (due to max engine current)
ZIPPY Compact 2200mAh 3S 25C Lipo Pack
guess it is working now, please let me know about.
Vince.
Old Aug 15, 2012, 03:16 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
The only other thing I'd change is the servos. The HXT900s are way better than the Turnigy TG9s. I use them exclusively in all my builds.
Pat
Old Aug 16, 2012, 04:02 AM
vfrumusa is offline
Joined May 2012
Ok, I already switched to them.
Thank you for your feedback!
Vince.
Old Aug 22, 2012, 11:31 PM
mav913 is online now
Find More Posts by mav913
GLMS
mav913's Avatar
Michigan
Joined Jan 2007
Here is my sons I built for him with the Model Plane Foam. I maidened it yesterday and despite being grossly under-powered she flew well. New motors are ordered now to correct that. All we have to do is build me mine and paint them. Thanks Tom for a great design.
mav913 is online now Find More Posts by mav913
Old Aug 23, 2012, 11:47 AM
Gonzo 1971's Avatar
Joined Nov 2003
Looks good Mav! Get a good motor on ther and it is a grin.
Question, is there a way to set up rates and expo on the elevon programming? I was trying to tame it down for my son. Tried and it has no effect,
Old Aug 23, 2012, 12:25 PM
GLMS
mav913's Avatar
Michigan
Joined Jan 2007
What radio are you using? If DX6i than just go into the dual rates and expo sub menu and set. I have everything set to the aileron switch, high rates set at 100% and lows set at 60% no expo at the moment but that will probably change.
John
Old Aug 30, 2012, 04:32 PM
alpea 41 is online now
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
The good 3d pilot I posted video of flying it a couple of pages back , has been practicing with it. Here's some low inverted harriers and just hucking around low in front and center...
20120829 0352 (1 min 3 sec)
alpea 41 is online now Find More Posts by alpea 41
Old Aug 31, 2012, 03:26 PM
articulatekevin is offline
Find More Posts by articulatekevin
United States, CA, Long Beach
Joined Sep 2011
nice flying. i woulda crashed at 1:20
articulatekevin is offline Find More Posts by articulatekevin
Old Aug 31, 2012, 03:45 PM
Gonzo 1971's Avatar
Joined Nov 2003
Do you have any pics of the rudder setup?
Old Aug 31, 2012, 03:57 PM
Gonzo 1971's Avatar
Joined Nov 2003
John
I did tbat with my Dx7. It did not seem to work. I am going to figure it out this weekend!
Old Sep 01, 2012, 11:22 AM
lucaferr73 is offline
Find More Posts by lucaferr73
lucaferr73's Avatar
Italy, Tuscany, San Marcello Pistoiese
Joined Jul 2012
CiÓ, arrivata tutta l'elettronica da HK inizio la costruzione
Ciao
Luca
lucaferr73 is offline Find More Posts by lucaferr73
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
