Espritmodel.com Heli Air
Old Jun 18, 2012, 10:28 AM
chuck-e-Jeez
Jeez's Avatar
The Netherlands, GE, Zutphen
Joined Mar 2012
It already has a spar :-D, but it could do with an airfoil. 5mm depron does flex with this wingspan
Jeez is offline Find More Posts by Jeez
Old Jun 18, 2012, 12:31 PM
hondarider98's Avatar
Canada
Joined Jul 2010
I used elmers foam board for my f-22 and the wings feel super strong. They don't bend at all. Should I add one just to keep moisture from warping them?
hondarider98 is offline Find More Posts by hondarider98
Old Jun 18, 2012, 12:51 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Do you mean add a spar, or add a KF airfoil?
If spar, I always recommend adding a spar, not matter how stiff the foam feels. You be surprised at the amount of stress you can put on this airframe.
If KF, I say it doesn't need it. Some guys say it flies better, I say it flies just fine without.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old Jun 18, 2012, 12:52 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Oh, and next time you use Elmers, I suggest soaking the paper and removing it. Because as you say, if it gets wet it may warp.
Pat
Old Jun 18, 2012, 02:56 PM
Switzerland
Joined Sep 2008
I went out today without wind it was so boring...
I am using a emax 2805 2840kv with a 4.75x4.75 and 3s. I should have a good speed with this config
The plane is only 80% scale but I think the prop is too small and it is hide by the profil of the plane
Cid156 is offline Find More Posts by Cid156
Old Jun 18, 2012, 03:06 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
The profile shouldn't be "hiding" the prop, even on the smaller size. The one in my avatar is about 65% of this one, and I use a GWS 4.5x3 prop and it works just fine.
Are you sure the prop is on correctly (front of the prop facing the front of the plane)?
Pat
Old Jun 18, 2012, 03:16 PM
Switzerland
Joined Sep 2008
Yes checked the video. It was done with a old battery
F22 depron... (2 min 48 sec)
I need maybe another prop with less pitch to get more trust
I just check with drive calculator
With the APC 4.75x4.75 I have 380gr 140km/h and 19A
With the GWS 5x4.3 I have 653gr 140km/h and only 16A
3A less for 300gr trust more...nice
Old Jun 19, 2012, 03:47 PM
chuck-e-Jeez
Jeez's Avatar
Joined Mar 2012
Pat,
I've got your motor (the suppo 2212-06 2200 kv) in the FF-117. Goes fantastic on a 2200mah 3S! Motor temp is 50 Celcius, and battery about 37. Forgot to measure the ESC, but was handwarm on all flights
On a 6x4 APC prop it does 115 km/h, yet more than 10 minutes of flying time.
I couldn't be happier!
Video (if that's okay in the F-22 thread...)
Taking the FF-117 parkjet for a spin. (3 min 1 sec)
Old Jun 19, 2012, 05:01 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Man that thing is fast!
Pat
Old Jun 19, 2012, 06:10 PM
superinstaller's Avatar
Columbia ,sc
Joined May 2006
Yep, I tried the no spar version. Everything was great and after about 10-12 hard flights the wing totally gave pulling out of a 5G dive. Got a total of 10-12 flights on that one, I would always use something to keep wing flex under control!
Also Vids of foam F117s are always ok!
superinstaller is offline Find More Posts by superinstaller
Old Jun 19, 2012, 10:22 PM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Originally Posted by Jeez View Post
Pat,
Nice. Where are the plans or build thread for the 117? I feel the need.
Bombay is offline Find More Posts by Bombay
Old Jun 19, 2012, 10:33 PM
A 4's forever
wildwillie63's Avatar
United States, IL, Marion
Joined Jun 2011
Go to rcfoamfighters.com for the plans.
wildwillie63 is offline Find More Posts by wildwillie63
Old Jun 20, 2012, 08:39 AM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Thanks! Many great looking plans/planes.
Old Jun 24, 2012, 04:06 PM
Switzerland
Joined Sep 2008
So I try the gws5x4.3. I do not see a difference but the esc has cut two times.
I will check the amp draws with the apc4.75x4.75 and the gws 5x4.3
F22 depron with a Emax2805 on 3S and GWS5x4.3 (2 min 40 sec)
Old Jun 24, 2012, 10:32 PM
Gravity Sucks
Somewhere in the Nations Capital
Joined Sep 2007
Hi Cid156,
I've not used the emax motor, but isn't it a 2S motor? Check the picture below - you might be using too many V's and pulling too many A's for this motor....
2S and 12-14 A (<60 sec) recommended. Not sure on the reliability of those specs though, so if you have a better source of info for the motor maybe follow that, but just a thought!
Cheers,
ResQ
ResQ is offline Find More Posts by ResQ
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
