Old Jun 12, 2012, 05:17 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by crxmanpat View Post
How many servos are you using tracknoob? If only 2, how are you getting a brownout on your RX?
Pat
Sorry, brownout was bad (wrong!) choice of terms. I am using a single HK $6 receiver, ESC BEC is driving two servos only. So I have plenty of power for servos and receiver, but had signal loss in exactly the same spot of our field, at exactly the same orientation of plane, on two homebuilt foamies now. Different type and rating of ESC o nthe planes, so that is definitely NOT the problem.
We have a huge cell array and antenna tower in one corner of the field, and it has long been a suspect (or scapegoat!) for a lot of issues people have had (never with Futaba, though, and so far, never with DSMx.)
Each time we had the issue, we lost all motor RPM, and plane stayed in last flight position (failsafe), with no throttle or elevon control possible.
Upon approaching the crash site minutes later, we now observe elevons back to working and motor now responsive, and even with SOLID led on the receiver!
The solid led was a puzzler, until after today's crash. I turned everything back on at the pits bench, then turned off my transmitter. As in flight, the elevons go unresponsive, throttle goes to zero, and the led goes off. But here is the unexpected part (for me, anyway) -- leaving the battery on the plane plugged in, turning the transmitter back on, once the new bind occurs, we get a SOLID led -- not flashing.
I know Spectrum themselves has a dozen different varieties of these little receivers and some of them flash, some don't, some have two leds, etc. I started to make my own look-up table with descriptions of fade, brownout, frame loss, and what each one did for each type of event - if anything.... but when I saw that DSMx doesn't indicate anything for fades and frame loss, I finally just gave up on the idea.
What I would say is that we won't fly another foamie out there without a satellite, or at least a reciever with antenna diversity, and actually, I would feel even better still going to the new DSMx receiver, since that is true frequency hopping, and spread spectrum.
I have a DX8, and I have the TM1000 telemetry too, so what I thought I might do (but have been too lazy to do so far) is to first learn how to set up the system to indicate signal quality metrics on the screen, then use a plane to basically 'survey' our field by flying in different sections at different heights, and observing the data.
tracknoob is offline Find More Posts by tracknoob
Old Jun 12, 2012, 06:12 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by tracknoob View Post
...I am using a single HK $6 receiver...
I think I just narrowed down your problem!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old Jun 12, 2012, 06:15 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Pat
heh heh I hear ya!
We are cheap %#@!%!^#^ around here.....
cheap and stubborn.....
But we *can* learn.....
Old Jun 12, 2012, 07:46 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
That's why I'm glad I stuck with XPS. Converted my JR 9303 to 2.4 and the full range 6-ch Nano is only $30.
Pat
Old Jun 12, 2012, 07:52 PM
A 4's forever
wildwillie63's Avatar
United States, IL, Marion
Joined Jun 2011
Has any one tried this receiver Redcon CM-921 2.4Ghz DSM2 Compatible 9-Channel Receiver ?
wildwillie63 is offline Find More Posts by wildwillie63
Old Jun 14, 2012, 12:07 PM
chuck-e-Jeez
Jeez's Avatar
The Netherlands, GE, Zutphen
Joined Mar 2012
Took my first flight with onboard camera today. From the ground I thought it was much smoother. Next time I'll hit the dual rates I think.
Tomhe F-22 parkjet onboard (4 min 41 sec)
Jeez is offline Find More Posts by Jeez
Old Jun 15, 2012, 05:37 AM
superinstaller's Avatar
Columbia ,sc
Joined May 2006
Leds anyone?
Just a hundred or so leds.
superinstaller is offline Find More Posts by superinstaller
Old Jun 15, 2012, 09:07 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
My small one is pretty well lit up.
Pat
Old Jun 15, 2012, 09:56 AM
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
That's really cool guys! I would like to try that one day.
jetcaptain is offline Find More Posts by jetcaptain
Old Jun 15, 2012, 11:45 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
It's actually very simple to do. I was intimidated to do it myself, but then I just bit the bullet and ordered lights. Was so simple I wish I'd done it sooner.
My build was detailed in my Mini F-22 thread.
Pat
Old Jun 15, 2012, 01:13 PM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
That is sweet. How is the orientation at night? The orientation seems like it would be a factor on this shape of plane > vs a T shape plane. I guess you might not fly it too far out if it is the small one.
Bombay is online now Find More Posts by Bombay
Old Jun 15, 2012, 04:47 PM
Columbia ,sc
Joined May 2006
It helps alot if theres some on the verts, huge difference!
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
If you notice, I did red/green in the proper aviation orientation (red on left, green on right, when viewed in the sky just remember "red, right, returning"), and then blue/white on the bottom. No issues with orientation at all.
If anything, these lights are a little too bright. I find I can't look directly at the plane for more than a minute or so, then have to kinda look off to the side of it, not directly at it, otherwise my eyes will start to water. Weird, huh?
Pat
Old Jun 15, 2012, 04:48 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Also true! Hard to tell in my pics above, but I do have it on the verticals as well.
Pat
Old Jun 15, 2012, 04:50 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
PS - 168 12v LEDs on mine!
Pat
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
