Unfortunately, I think that goes for most pilots
.One of my hard lessons was to fly the craft before I made it look pretty. The first one I've spent way too much time on cosmetics, only to see it crash after 30 seconds air-time. On another note, I found out that my DX6i has issues on the Europe power setting. The range check drops the link at about 3 meters, but on US setting (twice as much power) it reaches 30 meters like it should be able to. I'll be a radio pirate from now on! Rather risk the RC police than another brown-out. First coat of paint has been applied, tomorrow the next one. I'll make sure I'm ready for the weekend ![]() Perhaps some day I'll feel brave enough to put as much work into it as Gerrit, but not yet. It's given me lots of inspiration though ![]() Keep up the good work, guys! |
The Continuing story of the Big Red Bull Raptor
Hi folks,
Thanks for the support. I'm almost finished with the repair. Tomorrow I will start painting the lady. I want her to be (almost) as pretty as she was. At least she is stonger (and heavier) now. Here are some pictures of the repair. With a little bit of luck, and good wether, she'll fly next thursday. With the ailerons working correct this time! Bye !!! Gerrit.
Hello to you Jeez, I was thinking: What happened with the airballoon? I also want to know what you did with your radio. Can you easely change those settings. Does it work with a DX7? And about the paint job on the Raptor: I just like doing that. My brother told me many times: Go fly the damned thing, but I just want it to look good. Actualy it should have had a glas cockpit with a pilot in it, but I didn't find a pilot and the canopy I made out of a bottle wasn't that pretty at all. So I decided to go for a gray canopy and in a way I like it. Bye Jeez and keep on painting! Gerrit. |
Bye and keep up the good work! Gerrit |
Like your red plane. Good visible. Flies beautiful. Nice flying! Gerrit |
Wouldn't be very friendly of us to put a 400 liter bag on their roof ![]() This is the video (unfortunately I forgot I tilted the camera in picture mode, it all happened so fast!)
First (and unintentional) free flight with this model. The guy has been in the papers before, when another model of his went up without being anchored. This was within city limits, and as it went down it started spinning. From a far it looked very realistic, so the police received many calls about a balloon crashing! Luckily he recovered the balloon before the authorities arrived. On the second flight with the balloon, one of the strings snapped. Quickly followed by the other three, that now had to carry the extra weight. The bucket came down quick, but the balloon itself drifted off and landed in a tree, 5 meters up. We had to go to the hardware store to make something to get it down again. Explaining the people there what we intended to do with the stuff we needed was a lot of fun! All in all, quite the day! ![]() About the radio: The DX6i has a menu setting you can reach as follows: Menu (wheel press) > Scroll down to Setup List > Scroll down to Power Setting > Choose one of the following: - B-US 247 (200mW transmitter power) - C-FRANCE (don't know the power, but the weakest of the three) - A-EU 328 (100mW) I assume the DX7 isn't much different. I guess it will be next to range setting. Edit: After some Googling, it seems the Dx7 has no power setting, but different versions for Europe and US. However, the range difference should be far less than what I'm experiencing: http://rc.runryder.com/helicopter/t380350p1/ |
Just changed mine and the range test was awesome ,with a orange 6ch rx fitted with a satellite it got to 60 paces no problem (I am 6ft 3in so have long paces) That is a minimum 50% improvement . I learnt another thing about the DX6i that relates to this model , the elevon mixing limits servo travel to about 50% . To get full travel out of the servos you need to set up mix 1 as aileron mixed with aileron and set up mix 2 as elevator mixed with elevator . Set the right /left for aileron at 100% and for elev set up /down at 100% and see the difference it makes . I always wanted to know why I could not get the fast roll rates that I have seen others get , now I know . This is the vid that explains it all
Last week I added rudders to mine and its a blast , awesome spiral dives and makes flying this great model even better . I am using this as my airobatic trainer model and its taught me heaps Being on an angle the rudders do act as elevators as well but its still good fun. I also added the ailerons and will test them tomorrow , combined with the extra throws I have on the servos it should roll real fast now
The continuing story of the Red Bull Raptor
Hi folks,
Things go faster than I can edit on video. The Raptor has flown 4 times now. The first flight it crashed. I repaired the lady. I made some changes on the CG because the nose gained weight. Then I went back to the field for flight #2 en #3 (I've got two batteries) Here is the scary video of flight #2
That turned out to be OK although the Raptor was very hard to handle. She was all over the place. I couldn't get the elevator trim right so I took her down for a landing which turned out rather well. For flight #3 I did some changes with the setup of the radio. Changed the 'subtrim' for aileron and elevator so the basic trim was back to zero. Flight #3 was much smoother. Take off was good, I could fly straight lines now and the landing was fine. Although the flight seemed OK, I had to trim a lot elevator down and the Raptor wasn't easy to fly. I went home happy. At home I charged the two batteries, changed the CG 1 cm foreward and went back to the field. I wish I didn't. Flight #4 ende up into a crash again. grrrrrrr. She was uncontrollable. It took 50 seconds to break it into two pieces again. grrrrr. And the worst of it all: I just don't understand what I am doing wrong !!!! That was Yesterday. This morning, the 10th of may, I glued the two pieces together and I won't give up. The Raptor will fly!!! I consider to use some glasfiber for the top and the bottum now, but it's getting heavier and heavier. to be continued ...... Gerrit |
Ipoh, Perak Malaysia
Joined Jul 2006
With all the sub-trimming you are doing, have you check that EPA or ATV for the same elevator travel up/down when you pull on the elevator? Same thing for the linked ailerons. Seems the plane is rolling whenever you pull/push on the elevator. This would happen if your elevator travel is uneven for both sides.
Also, in some radios, changing the subtrims too much will result in unequal travel or end-points, for dual elevators controlled via 2 channels. This would be even worse for elevon models. chewy |
Thanks for your support. I don't know the terms EPA and ATV, but the travel of ailerons and elevator were equal on both sides, but I will check it again after all those changes I made. Thank you very much. I will get back with the answer. Gerrit |
| Thread Tools | |
| Video f-22 with average pilot | leadfeather | Electric Plane Talk | 1 | Apr 24, 2008 12:49 AM |
| Video RCSuperPowers F-22 with Vectoring Thrust | RCSuperPowers | Electric Plane Talk | 25 | Feb 18, 2008 04:00 PM |
| Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) | meteor | Electric Ducted Fan Jet Talk | 30 | Feb 09, 2005 09:57 AM |
| Wattage F-22 with ducted fan | The Blue Max | Electric Ducted Fan Jet Talk | 11 | May 10, 2003 01:13 PM |
| f-22 with jeti brushless | ivorz | Foamies (Kits) | 14 | Oct 01, 2002 08:39 PM |
